Old 07-13-2010, 12:06 AM   #1
danisfake
Member#: 194663
2003 Cobra
Sonic Blue
Default Spark plug socket rubber stuck on spark plug
Hey guys,
I could use some other peoples input on a tricky situation. I was changing the spark plugs on my 2005 WRX when something pretty awful happened. When changing the second plug, the spark plug sockets rubber piece came off without me realizing. I went to put the coil pack back on and it was pretty tough so I tried putting a little force into it when I realized that the rubber piece was missing on the socket. Long story short, its wedged in between the spark plug and pretty much has no way of getting out because it's covering the socket. So basically I put a socket in there and its not reachable or it just spins and spins and spins (cause of the rubber).
Any one ever experience this before? I feel like I'm pretty SOL on this one. Should I have it towed to a mechanic that can drop the engine and take care of it? I finished the other three with no problem but this one is just... well... stuck. I'm thinking of picking up a dentist pick and trying to grab it out that way. I already tried pliers, screw driver, and anything reasonable. It's really stuck.
Would running it be fine? Just taking some shots in the dark but I believe the coil pack will reach the spark plug but wouldn't the engine temperature melt the rubber around the spark plug causing problems? Would spraying WD40 in there have an negative affects?
Any ideas would be helpful.
Thanks
Dan
danisfake is offline   Reply With Quote
Old 07-13-2010, 12:12 AM   #2
djyox
Member#: 247009
2006 WRX
68hta, E85
I personnally would cut it off. I never use those rubber holder things anyhow. They are nice, but like you, I find them more of a problem than a help.
djyox is offline   Reply With Quote
Old 07-13-2010, 12:15 AM   #3
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Originally Posted by danisfake View Post
Hey guys,
Thanks
Dan
Long nose pliers should do the trick.
i_c_the_light is offline   Reply With Quote
Old 07-13-2010, 12:15 AM   #4
cmk82600
Member#: 248305
97 OBS
my custom mixed silver
dental pick, same thing happened to me, took all of 20 seconds to get ti out with the pick, i believe i had to bend the pick to have enough room
cmk82600 is offline   Reply With Quote
Old 07-13-2010, 12:19 AM   #5
danisfake
Member#: 194663
2003 Cobra
Sonic Blue
Thanks for the quick responses guys, I'll pick up both tomorrow and let you know how it goes. If its one thing I learned, if you use those rubber grommet things always check if they've fallen out after each plug. What a PITA today's been. 1 Hour to do all 3 spark plugs, 3-4 hours of trying to fish the stuck one out.
Old 07-13-2010, 12:25 AM   #6
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
If you don't have a pick, a hacked up clothes hang could work.
CKxx is offline   Reply With Quote
Old 07-13-2010, 12:31 AM   #7
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
^ A wire hanger is ALWAYS useful to have. Many a times have I used one...
OrbitalEllipses is offline   Reply With Quote
Old 07-13-2010, 12:32 AM   #8
4drcivicmaster
Member#: 211113
2004 STI
same thing happened to me! it sucked! i just used one of those hook tool things and got it out after hours of messing with it.
4drcivicmaster is offline   Reply With Quote
Old 07-13-2010, 12:43 AM   #9
fugazni
Member#: 236718
2007 Impreza WRX Wag
Urban Gray Metallic
It always sucks when something goes downhill during a spark plug change because it usually means a walk of shame to the auto parts store if you're not lucky enough to have another car in the driveway. Last time I changed my plugs, I had to walk to the store to get one of those extending magnet sticks to get the socket out after it came off the socket extension. And what sucks even more is the time lost trying to fix the problem with the improper tools because you don't feel like walking to the store.
fugazni is offline   Reply With Quote
Old 07-13-2010, 12:48 AM   #10
cmk82600
Member#: 248305
97 OBS
a tip to keep the rubber from falling out again, clean it real good and inside the socket too then a little epoxy or silicone to hold it in.
Old 07-13-2010, 03:49 PM   #11
danisfake
Member#: 194663
2003 Cobra
Sonic Blue
***UPDATE***
So I got the dentist pick thing today and that did wonders. First try I got it out.
Heres some pictures of the little bastard.
Car runs like a champ now
Thanks for the input everyone
Dan
Old 07-13-2010, 04:38 PM   #12
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Use two different spark plug sockets, one with the boot and one without. Use the one with the boot for removal, and the one without the boot for installation.
Old 07-18-2010, 03:48 AM   #13
batteryman
Member#: 209986
2006 WRX Wagon
Haha, the same thing happened to me on the last plug, man was it a pain to get out.
batteryman is offline   Reply With Quote
Old 07-18-2010, 04:27 AM   #14
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr jdm 6-spd JJtuned
When the rubber fails, the wire hanger ftw.
Dave D. is offline   Reply With Quote
Old 08-27-2011, 10:45 PM   #15
rand007
Member#: 225211
Default Thanks!
First of all, I want to confess my undying love for you guys. This happened to me today and after a substantial amount of cursing, frustration and cursing I ran out of good ideas, searched and found this thread at the top of the googles.
Using your advice, I crafted the following device out of some spare wire, which worked perfect. Hope it helps some future folks.
Saved my day all in all
rand007 is offline   Reply With Quote
Old 08-28-2011, 12:17 AM   #16
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
newbie using search...i like it
drewvdw is offline   Reply With Quote
Spark plug socket? Xtreme Racer Legacy Forum 3 03-26-2010 07:51 PM
Spark plug socket problems (not in FAQs) sagelwwa Service & Maintenance 3 06-15-2005 09:55 AM
2.5 Spark-Plug Socket jacksonww1 Legacy Forum 11 01-13-2005 03:15 PM
Spark plug stuck on 03 WRX knertified Service & Maintenance 15 11-08-2004 02:00 AM
E-town ppl: may I borrow a spark plug socket? Titanium Samurai Canada Region Forum 4 07-02-2003 12:35 PM
