Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 07-13-2010, 11:49 AM   #1
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Default Epoxy Experts?
Looking for an epoxy for a little project, needs to be able to adhere aluminum together and withstand oil/fuel and temps up to 600 degree's. Any suggestions?
Token-Negro is offline   Reply With Quote
Old 07-13-2010, 11:56 AM   #2
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
Big-E is online now   Reply With Quote
Old 07-13-2010, 11:59 AM   #3
red5001
Member#: 33942
04.5 STI
wrb
3M makes some good prudcts There Scoth weld line may have something that will work for you. They had good customer support if you call them as well. They may even toss in a sample. They have a good info on there webpage as well
red5001 is offline   Reply With Quote
Old 07-13-2010, 12:05 PM   #4
Big-E
Member#: 123843
2006 WRX Sedan SGM
Old 07-13-2010, 12:11 PM   #5
Paranoid Fabrications
Member#: 140712
2008 WRX STI
why not weld?
Paranoid Fabrications is online now   Reply With Quote
Old 07-13-2010, 01:47 PM   #6
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Whole point is to build an clean enclosure so very few welds and those are only because off the economics of doing a full billet top with threads etc.
Old 07-13-2010, 03:08 PM   #7
madmax718
Member#: 172501
I would be hessitant to glue together anything that is subjected to fuel, even with the 3m stuff.
You can always Weld it, grind it, and polish it.
madmax718 is offline   Reply With Quote
Old 07-13-2010, 05:53 PM   #8
PERRIN_Jarid
Member#: 214449
IF you are going to JB weld/epoxy two surfaces together you might want to scuff up both surfaces for better adhesion.
PERRIN_Jarid is offline   Reply With Quote
Old 07-13-2010, 07:33 PM   #9
decke48
Member#: 178804
1998 lgt
could use devcon F (aluminum putty) or F2 (aluminum liquid) epoxy, has a good oil and gasoline resistance, fair methanol resistance
decke48 is offline   Reply With Quote
Old 07-13-2010, 09:12 PM   #10
charliew
Member#: 125304
600 degrees? there won't be any oil left I'm sure.
charliew is offline   Reply With Quote
Old 07-14-2010, 08:04 PM   #11
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Machinist wants 50$ per disk to make the caps used to make up each end of the reservoirs, sounds like i need a new machinist!
Old 08-18-2010, 04:00 AM   #12
AlpineE30M52
Member#: 222937
1986 325es S50 swap
Schwarz
Hey, I'm a machinist. Are you still trying to solve this? What are you looking to have made? PM me details.
AlpineE30M52 is offline   Reply With Quote
Old 12-11-2012, 12:29 PM   #13
ScoobieBlue18
Member#: 214557
1997 ej18t Impreza
Not WRB
Also look into both West system epoxy and Pro-set adhesives.
ScoobieBlue18 is offline   Reply With Quote
Old 12-16-2012, 12:56 PM   #14
sdmideas
Possible Scammer - Buyer Beware
Member#: 280920
2003 wrx
white
hysol - 60 or 120
sdmideas is offline   Reply With Quote
Old 12-16-2012, 11:45 PM   #15
kay95
Member#: 45494
95 impreza L awd
green
If it was me I wouldnt trust a adhesive past about 400 degrees F. Alot of epoxies arent rated for more than 300 or so degrees. Alot of the time even if the adhesive is rated to a high temperature over time the bond will break due to the different thermal expansion ratios.
If you want to join aluminum that is good to 600 degrees weld or braze it because you dont want fuel to leak at 600 degrees. That is quite the fire hazard.
kay95 is offline   Reply With Quote
Old 12-18-2012, 12:48 PM   #16
sdmideas
Member#: 280920
2003 wrx
white
^outdated info.
Epoxies used today in The aerospace industry have been developed for just that - aerospace. With huge temperature changes and strength to weight demands, today's aerospace epoxy offer more solutions than ever before. Are they cheap? No. Do they require special handling and curing techniques? Usually they do. Can you get samples from manufacturers? If you ask nicely. Will it withstand the temperatures I want? Just read the data sheet supplied with each adhesive, some will, some won't.
People continue to perpetuated the misinformation that epoxies and other adhesives are inferior to welding and braising while due to advances in technology within the last 20years the opposite is actually true.
Adhesives offer more control and even more flexibility when used for the proper application - just look at the euro fighter. It's not welded together.
Old 12-18-2012, 05:14 PM   #17
kay95
Member#: 45494
95 impreza L awd
green
Well I work on aircraft. Yes they use alot of epoxies. Now with that said when epoxies are used they are used with rivets, bolts or screws. I have seen alot of adhesives disbond even with good prep work. Also aircraft are inspected daily and very periodically for structural disbond due to the environment and high performance nature.
In aviation NO ONE would use epoxy to bond aluminum to aluminum to hold fuel to 600 degrees. If you get a leak at 600 degrees there are fuels that will auto ignite at that temperature. Needless to say that isnt safe.
Its not that adhesives couldnt do the job its that welding or brazing is MUCH safer. When it comes to fluids everything in aviation is welded or brazed because it wont leak at extreme temps, high vibration and pressures. Adhesives are not the proper application for fluids especially fuel.
Epoxy on Headlight tennis Car Care & Detailing 1 07-13-2010 12:05 PM
Check out my new epoxied floor! (and what's sitting on it!)(LONG) Blugin Texas Impreza Club Forum -- TXIC 56 12-12-2005 01:28 AM
Is there a liquid epoxy or plastic that hardens to a non-toxic barrier? Gravel-Fun Off-Topic 3 01-05-2005 04:44 PM
Garage Epoxy Paint, Who has done it? Bonefizz General Community 15 08-23-2004 02:53 PM
Epoxy + Plastic roffle Interior & Exterior Modification 5 08-17-2004 10:13 PM
