Old 06-16-2002, 01:59 PM   #1
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Default Link 2 question
When I run PCLink the map only goes from 0kPa-110kPa. What happens when I go into boost? How do I tune those maps?
thanx,
-Chav
Chav is offline   Reply With Quote
Old 06-16-2002, 02:02 PM   #2
christoph1371
Member#: 1090
pm skywalker if you have detailed questions. I know he's on his computer now
christoph1371 is offline   Reply With Quote
Old 06-16-2002, 07:00 PM   #3
Chav
Member#: 3269
RSTi
k, fixed, but I have another question.
Now that I have the link installed I drove around the block on the base map and I am getting very very bad pinging at light throttle and everywhere from 1500rpm up to 3500rpm (i didnt go beyond that). The knock on the link doesnt go above 6 or 7 though. Can you tell me where the stock knock sensor is so i can tap it and see if it is working? Could this pinging i'm hearing just be a very very rich condition (O2 reads 88-90) and just be the gas burnning on its way out of the exhaust chamber? Last question is when I ease into the throttle the car stumbles for a sec then finally goes is this cause of the crappy vac line i have?
-Chav
Old 06-16-2002, 07:15 PM   #4
christoph1371
Member#: 1090
bill will answer in a while...we are bbqing now
Old 06-16-2002, 07:17 PM   #5
Chav
Member#: 3269
RSTi
you guys are lucky, I'm starving!
Thanks,
-Chav
Old 06-16-2002, 07:23 PM   #6
christoph1371
Member#: 1090
mmmmmmm hamburger...mmmmm
Old 06-16-2002, 07:38 PM   #7
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
-Chav
if it was really rich, it would be really obvious. while driving, the car would bog and buck and you wouldn't be able to rev freely. also there would be a loud popping under the car and outside of it would smell like gas. i had a problem like this yesterday but all i had to do was reload the map and it worked fine again. what injectors are you using and what is your master fuel set at?
KillerTHC is offline   Reply With Quote
Old 06-16-2002, 07:42 PM   #8
Chav
Member#: 3269
RSTi
Stock fuel system. Master fuel is at 130. Do you think it was pinging then? I didnt think it would be so easy to get predet at part throttle at like 2500rpms and medium load.
-Chav
Old 06-16-2002, 07:55 PM   #9
christoph1371
Member#: 1090
don't listen to that kid he knows nuthing! I think he just woke up too, the lazy bum
Old 06-16-2002, 08:10 PM   #10
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
i woke up at 3 thank you very much!!! anyhow, i think your master fuel is way too high. mine is at 105. lower it to like 110 and see if the problem is as bad.
Old 06-16-2002, 08:13 PM   #11
Chav
Member#: 3269
RSTi
ok, i'll try that. I'm very very paranoid about this whole pinging thing. I gotta tone it down to the healthy paranoid level.
btw I have the rear O2 in the stock location (behind the cats) and it was still reading 94 at idle and 88 under cruze. I'm guessing this is really rich.
-Chav
Old 06-16-2002, 08:19 PM   #12
christoph1371
Member#: 1090
move that o2 up behind the turbo (on the down pipe). you 'll get better readings. then get back to us.
Old 06-16-2002, 11:28 PM   #13
Chav
Member#: 3269
RSTi
Ok I put it down to 110 and the car's idle fell to 800rpm and the O2 read 0. Way to lean even at idle. So I went up to 170 on the master fuel and went for a ride and the "pinging" or whatever it is was less pronounced. The car doesnt have the turbo on yet. This is a stock engine with an intake and exhaust and I cant get this "pinging" or whatever it is to go away. With the master fuel at 170 the car runs a lot better. I did some data logging and the knock sensor only went above 15 once. To test the knock sensor I started data logging with the engine off, key on and went and tapped the sensor and engine block around it. The knock only went up to 11 is this normal? thanx
-Chav
Knock link installed, question- Tex-WReX2 Factory 2.0L Turbo Powertrain 31 03-23-2012 11:25 AM
Cobb Stage 2 Questions IllustriousBrown Newbies & FAQs 9 06-02-2010 11:35 AM
Knock link screw question wRx14pSi Factory 2.0L Turbo Powertrain 6 09-14-2004 02:15 PM
Link people - question for you! JenisonWRX Factory 2.0L Turbo Powertrain 4 06-05-2002 05:36 PM
Defi-Link install questions...WRX andygold Factory 2.0L Turbo Powertrain 29 12-09-2001 10:01 AM
Message Board Statistics All times are GMT -4. The time now is 08:12 PM.
