Old 06-16-2002, 02:56 PM   #1
WagonMaster
Member#: 6445
2002 WRX Wagon
WR Blue
Default Headlight mod disaster - HELP!
I finally got round to doing the headlight mod and was really pleased with the result. Unfortunately some of the black sealant goop got on to the lens and was proving to be a bugger to clean off, so I got out the "goof off" and gave it a wipe.
I tested the goof off on another part of the lens without troubles, but it seems that the sealant has reacted with the goop and spoiled my finish.
I would be grateful for any advice on how to fix this mess!
WagonMaster is offline   Reply With Quote
Old 06-16-2002, 03:20 PM   #2
i eat meat
Member#: 13755
is it just the excess chemicals left over on the lense? if so, try buffing it out with some wax..
if not.. sorry to hear that this happened..
i eat meat is offline   Reply With Quote
Old 06-16-2002, 04:05 PM   #3
BillMiya
Member#: 19583
2002 WRX Sedan
Platinum Silver
From the pictures alone, I can't tell if they are scratches on the glass or left-over chemicals.
I hope that they are simply chemicals that can be buffed out.
Sorry to hear.
BillMiya is offline   Reply With Quote
Old 06-16-2002, 06:43 PM   #4
imprezakid
Member#: 12286
2002 Rally Sport
Platinum Bling Bling
ouch
imprezakid is offline   Reply With Quote
Old 06-16-2002, 06:52 PM   #5
mark5211
Member#: 9873
2002 WRX wagon
I would try a touch of wd-40 or similar product on a soft paper towel. Btw, that's what i would have used in the first place. It's great for removing "goo" from glass and painted surfaces (i.e. old inspection/registration stickers). Just remember to use sparingly!
mark5211 is offline   Reply With Quote
Old 06-16-2002, 07:08 PM   #6
JonnySubaru
Member#: 17901
Default That's on the outside, right?
I'd try buffing it with wax as well. If there is damage to the plastic lense, don't worry thought. There are ways use different plastic polishes to get it like new again (if nothing else works)
JonnySubaru is offline   Reply With Quote
Old 06-16-2002, 08:26 PM   #7
COwannago
Member#: 6972
Rubbing alcohol might also work.
Nick C.
COwannago is offline   Reply With Quote
Old 06-16-2002, 09:36 PM   #8
Chunky_Chicken
Member#: 9782
2002 E46 M3
Laguna Seca Blue
Is the area still soft?
If not I would hit the closes Pepboys and get an assortment of super fine sand paper. Go all the way up to 2500 if you can. Then go find some lense buffing compound (polycarbonate buffing compound) and get buffing.
I tried this on my badge after it took a huge shot from a rock leaving a crater in it. I sanded it down, went all the way to 2500 and then used a generic polish (like a metal polish) to buff it to a shine. It looked better than new when done.
I'd avoid adding more chemicals to the mix. If the surface of the lense is already galled then you're gonna have to sand. If its just stuff on the surface that won't come off... sanding my make it worse, so be warned.
-Pete
Chunky_Chicken is offline   Reply With Quote
Old 06-16-2002, 11:18 PM   #9
Yungimoto
Member#: 14940
Try plastic polisher.
Yungimoto is offline   Reply With Quote
Old 06-17-2002, 03:51 AM   #10
Impreza2fast
Member#: 14088
2002 WRX (RIP)
Default maybe
try using some paint thinner, that might work
Impreza2fast is offline   Reply With Quote
Old 06-17-2002, 10:34 AM   #11
Rebellion
Member#: 8069
2016 Fiesta ST
Kona Blue
i did the same thing to one of mine... the finish on the plastic is eaten away.. it's not stuff stuck to it. Plastic polisher might work, but I dunno, I never came up w/ anything to fix mine either.
Rebellion is offline   Reply With Quote
Old 06-17-2002, 11:05 AM   #12
Ging
Member#: 3258
2000 Impreza TS
If you don't want to go out to buy plastic polish, tooth paste will also work. I used it on a friends scratched watch lens.
Ging is offline   Reply With Quote
Old 06-17-2002, 12:58 PM   #13
bjteel
Member#: 14442
2002 WRB WRX
GOO-GONE, works great! (clear bottle, amber liquid)
bjteel is offline   Reply With Quote
Old 06-17-2002, 03:27 PM   #14
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
had the same proublem
wd-40 worked great
Old 06-17-2002, 03:48 PM   #15
WRXzard
Member#: 14855
Use liquid car wax with water. The same way you would spit shine you boots. Start a little at a
time it will come out.
WRXzard
WRXzard is offline   Reply With Quote
Old 06-17-2002, 06:05 PM   #16
BillMiya
Member#: 19583
2002 WRX Sedan
Platinum Silver
Does this happen a lot???? I was thinking of baking mine but now I'm feeling a little less enthused.
Old 06-17-2002, 06:46 PM   #17
AndrewWRX
Member#: 13191
Default MAGUIRES!
Get the plastic cleaner & polish (I think #10 & #17)
They are a small blue and white plastic bottle each.
The stuff is used for the plastic convertible windows and should polish it up. It's used to clean Cd's too!
I would do this before adding any more solvents to the mix!
AndrewWRX is offline   Reply With Quote
Old 06-17-2002, 11:19 PM   #18
WagonMaster
Member#: 6445
2002 WRX Wagon
WR Blue
Thanks for all the advice (and sympathies!). I probably won't get chance to mess with it until the weekend.
I will try waxing it first, followed by plastic polish. Where can I get plastic polish? I have never heard of it before !
BillMiya - don't worry. This shouldn't have happened at all. I was just a little careless with the sealant while it was warm and got it stuck on the lens. Oh, and don't use "goof off" to remove it...
If you learn from my mistake, you will be fine. Apart from my scratched lens, this mod looks awesome.
Managed to mess up with the headlight mod please help to fix! SilentShadow Interior & Exterior Modification 22 04-16-2006 03:22 AM
Please help with the headlight mod scubaracer Interior & Exterior Modification 2 06-01-2002 12:21 AM
wanna help me with the headlight mod? bluperlrex Bay Area Impreza Club Forum -- BAIC 3 04-15-2002 02:04 AM
help me with the headlight mod hpracingwrx Interior & Exterior Modification 3 03-27-2002 09:24 AM
The headlight mod... Help quikly please DubbleURX Interior & Exterior Modification 3 10-11-2001 08:48 PM
