Old 06-16-2002, 03:07 PM   #1
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default TEC-II Kit: Pardon my ignorance, but what the heck...
that came with the tec-ii I bought? Did not come with a description and I certainly don't see it described in the installation instructions:
Thanks,
Kevin
latinskllz is offline   Reply With Quote
Old 06-16-2002, 03:12 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
That looks like a knock sensor.
Old 06-16-2002, 04:20 PM   #3
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
Yeah, that's a knock sensor, threaded into the adapter. The adapter threads into the driver's side engine mount - you take out one of the bolts and replace it with the adapter.
Jeff
Portly is offline   Reply With Quote
Old 06-16-2002, 11:17 PM   #4
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default That's what I thought...
just didn't watn to sound like a dumbass by labeling it and then being wrong.
Where by the engine mount, I looked today and could not clarify the bolt you were talking about jeff
Old 06-16-2002, 11:39 PM   #5
Austin
Member#: 7089
2016 STi
That brass adapter replaces one of the engine mount bolts. You can go with either side engine mount.
Austin is offline   Reply With Quote
Old 06-17-2002, 02:19 PM   #6
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default on another note...
why did two crank trigger sensors come with the tec-ii? Maybe I'm not looking at the install photos or not reading carefully, but I only see one being used.
The sensor (crank) i'm refferring to is the ones behind the knock sensor in the picture.
Kevin
Old 06-17-2002, 02:39 PM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Default Re: on another note...
Kevin
good qestion...there should old be one *shrug*
Old 06-17-2002, 04:49 PM   #8
Lurker
Member#: 806
2000 RS-T
BRP
The crank trigger sensor is the only single point of failure in the system, so Shiv recommends having a spare around in case the installed one fails. I asked for a spare one when I ordered my kit. Maybe now he's including an extra by default.
Lurker is offline   Reply With Quote
Old 06-17-2002, 09:08 PM   #9
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Yes, he is now including an extra.
david2z4 is offline   Reply With Quote
Old 06-17-2002, 09:10 PM   #10
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Running the TecII kit is a real DIY.. About half the job is already done thanks to the custom machined pieces.. But the rest is gonna be all you.. Do the whole thing in stages
Mount ECU/Coil to firewall (stage 1)
Install coolant temp gauge (2)
Install Crank Wheel and Sensor (3 prep lots of time and watch those washers!)
Install Knock Sensor and MAT sensor (4)
Install MAP Sensor move around a bunch of vac hoses (5)
Splice the needed stock sensor wires, install comm wire (6)
Plug power into the TEC, see if you can make a scratch map for your stock injectors if still NA And install the O2 sensor.. (7)
Install fuel system (8 This could take a few days and lots of trips to the store)
If you were closer to Illinois, I could help you...
NA should look something like this..
More reference PICS.
Revision is offline   Reply With Quote
Old 06-17-2002, 10:16 PM   #11
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default Woah that engine bay looks nice...
Thank you Revision for the picture and input...I currently own the Vishnu Fuel Rails and thanks to you I know what fittings to get for those.
The TEC-II kit I got came with all the sensors and connectors that I can see from the installation. How do I know if I have a 1/2/3 bar boost controller?
I looked at the Vishnu forums and it does help me to an extent.
Kevin
pardon my ignorance.... KevnKel South West Impreza Club Forum -- SWIC 4 12-31-2007 10:24 AM
Pardon my ignorance, but what the hell is THIS? extraducksauce Off-Topic 8 10-13-2007 02:25 PM
pardon my stupidity but what is.. culmination Newbies & FAQs 20 09-07-2004 01:27 PM
Pardon my ignorance. VSM EXtasy Off-Topic 12 02-26-2004 10:22 AM
Swapping in the rear end part II- What the heck are these? beachbum Technical Forum Archive 5 05-27-2000 08:36 PM
