Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 07-13-2010, 07:19 PM   #1
Gerkins31
Member#: 52337
OMGHi2U OT computer peeps: Vista won't boot. halp?
I haven't seen this before..
I tried to start up my PC a minute ago, but after the initial screen comes up with the motherboard logo/info etc. (P5ND), the screen goes black, and nothing else happens. The monitor is still on and working (if take out the cable from the vid card it says "vga no signal.") Also, i don't hear the boot-up sound, and ctrl+alt+del hard resets, so it doesn't seem to be a display problem, it seems like Vista isn't booting at all. It doesn't even get to the screen that gives you the option to boot in safe-mode. I've tried going into the bios and resetting everything to default, but there was no change. Soooo what's dead?
Gerkins31 is offline   Reply With Quote
Old 07-13-2010, 07:21 PM   #2
LTApaulie
Member#: 167649
Hard drive or motherboard. See if you can get the hard drive to work in another computer or carrier. Extract your data if it does.
LTApaulie is offline   Reply With Quote
Old 07-13-2010, 07:28 PM   #3
raj100
Member#: 8645
Sounds like the mother board.
Try booting to a CD, see if that works.
raj100 is offline   Reply With Quote
Old 07-13-2010, 07:32 PM   #4
markman
Member#: 93623
See if it boots to yore Windows setup CD.
markman is offline   Reply With Quote
Old 07-13-2010, 08:01 PM   #5
Gerkins31
Member#: 52337
After much rummaging, I just found my Vista CD. I'm trying that now..
Old 07-13-2010, 08:21 PM   #6
Gerkins31
Member#: 52337
The CD boot was semi-successful. I was able to get into the menus and try a system restore from a previous point. It said it was successful, but when it auto-restarted, I got the same thing. i noticed that the last restore point it mentioned was listed as "windows update" (the others were "scheduled restore point") and that it was listed as being made today. Could that be the reason for the flub? maybe it tried to auto-update and it borked itself? Also, am I right to assume that getting this far and successfully booting/navigating a CD means the mobo is fine?
Old 07-13-2010, 08:26 PM   #7
Gerkins31
Member#: 52337
Giving up and trying a full wipe/reinstall. I have most of my stuff backed up amyway
Old 07-13-2010, 08:28 PM   #8
raj100
Member#: 8645
yeah, sounds like the MBR is gone
Well a reinstall should fix it.
Old 07-13-2010, 08:29 PM   #9
LTApaulie
Member#: 167649
Before you do go in with a Linux live CD of some sort and get the rest of your stuff!
Old 07-13-2010, 08:49 PM   #10
perret318
Member#: 23510
WHO DAT!
This. Try ubuntu or knoppix.
perret318 is offline   Reply With Quote
Old 07-13-2010, 09:27 PM   #11
Gerkins31
Member#: 52337
Never thought of that.. Oh well, I did the re-install and all is well. In fact Vista's little save-all-your-old-crap-in-a-folder trip worked like a charm, and I didn't lose anything. I just have a lot of re-installing to do. Thanks fer the inputs :wavingkitty:
Old 10-21-2010, 09:36 AM   #12
REX8
Member#: 24038
Hands up! This is a hijack!
Harro OT computer people!
Problem on my Gateway netbook...
On startup, I get kicked into the boot screen. No matter how I boot (safe, last good settings, as normal, etc.), it tries to boot, then returns to the boost screen.
Wash, rinse, repeat.
It's a netbook, originally running Vista, now running XP for the last year or so.
Any ideas?
Old 10-21-2010, 09:41 AM   #13
aod
Member#: 7121
It is doing you a favor.
aod is offline   Reply With Quote
Old 10-21-2010, 09:54 AM   #14
perret318
Member#: 23510
WHO DAT!
Please choose one or more of the following:
1. Boot from XP CD, attempt restore.
2. Clean wipe, fresh install
3. Boot to Ubuntu or Knoppix Live CD and attempt to recover data
4. Clean wipe, install Linux, feel cool.
5. Take out a second mortgage and buy a Mac, wear trendy glasses, feel self-important.
6. Screw it all, use an abacus.
Old 10-21-2010, 09:56 AM   #15
REX8
Member#: 24038
4. Install Linux, feel cool.
5. Take out a second mortgage and buy a Mac, wear trendy glasses, be hip.
No CD (netbook), I have the OS on an external HD, I guess I'll try to boot from there when I get home. Maybe I can load a recovery program on the HD as well and try that first.
Old 10-21-2010, 09:57 AM   #16
REX8
Member#: 24038
Side-note:
What's going to be reliable in the 11.5 screen size range?
Old 10-21-2010, 10:59 AM   #17
aubsxc
Member#: 91476
2005 9-2x Aero
Doesn't the Vista CD provide you an option to repair the Master Boot Record? It has been a long time and I don't remember. Your hardware is probably fine, and from your description it sounds like your MBR is corrupted (this has nothing to do with your Windows Restore Points). Do a search for restoring/fixing the MBR and look for free tools that will allow you to do this.
aubsxc is offline   Reply With Quote
Old 10-21-2010, 11:00 AM   #18
REX8
Member#: 24038
No CD, it's a netbook. Came with pre-loaded software. Thank you, will do!
OT Computer peeps: Why won't Vista recognize my camcorder? Gerkins31 Off-Topic 6 02-13-2010 11:27 PM
OT computer peeps: Why aren't my front audio jacks working? Gerkins31 Off-Topic 15 01-12-2010 06:53 PM
OT Computer Guru's..... Halp! stud100spray Off-Topic 13 11-24-2008 10:17 PM
OT computer experts, HALP! VpointVick Off-Topic 32 04-03-2008 05:28 PM
OT Computer Gurus: using an xp external hard drive with vista... hotshot172 Off-Topic 12 08-13-2007 10:43 AM
