Old 07-14-2010, 02:31 AM   #1
Bdavis1
Member#: 241215
Unhappy So lets say someone decided to wet sand some scratches out of my hood...
And lets say that "someone" couldn't figure out how to fix the dull area the wet sanding left behind... What should that "someone" do to restore the shine?
"Someone" used 2000 grit dry/wet sandpaper with a little water...
Please help
Bdavis1 is offline   Reply With Quote
Old 07-14-2010, 02:32 AM   #2
02redwagone
Member#: 87067
02 Old but tasty
SRP
Someone needs to rubbing compound and polish.
02redwagone is offline   Reply With Quote
Old 07-14-2010, 02:55 AM   #3
Bdavis1
Member#: 241215
so I have rubbing compound and polish. What do I use with the rubbing compound? machine or elbow grease? and what kind of cloth?
Old 07-14-2010, 02:58 AM   #4
matt107
Member#: 152303
04 STI
JBP
If you can't do it by hand, just go to your local car wash/detailer and have them hit the spot with a machine buffer. Probably only cost you 20-40 bucks just to do a small spot.
matt107 is offline   Reply With Quote
Old 07-14-2010, 02:59 AM   #5
Bdavis1
Member#: 241215
ok thank you guys for the quick responses! I hate driving around with a lame ass spot on my hood
Old 07-14-2010, 03:41 AM   #6
snoboarder8232
Member#: 241289
You seem a bit in over your head.
snoboarder8232 is offline   Reply With Quote
Old 07-14-2010, 12:18 PM   #7
blue-sun
Member#: 15934
this.
Try the rubbing compound with a micro fiber applicator pad and a MF towel, see if that does the trick, though it will not be easy and will probably not look great when you're done. Your best bet will be to contact a local detailer as matt107 said.
blue-sun is online now   Reply With Quote
Old 07-14-2010, 02:59 PM   #8
kimgt
Member#: 142097
2002 celica GT
red
dang, you decided to sand in a major obvious part of the car BEFORE knowing how to correct it. nuts.
kimgt is offline   Reply With Quote
Old 07-14-2010, 04:53 PM   #9
gtfaded
Member#: 142322
2002 wrx
wrb
I wouldnt take it anywhere.
gtfaded is offline   Reply With Quote
Old 07-16-2010, 10:17 PM   #10
robertrinaustin
Member#: 51964
2008 STi, OB, EVO
Blk Sti and EVO, Navy OB
You won't be able to fix it by hand. You need a polisher and a fairly aggressive pad. When I've polished out 2000 grit marks, it was a 3 or 4 step process with a rotary and a PC.
robertrinaustin is offline   Reply With Quote
Old 07-16-2010, 10:33 PM   #11
snoboarder8232
Member#: 241289
Yeah I'd go wool/105, orange/105, white/205
Old 07-17-2010, 01:17 AM   #12
Nagz
Member#: 211432
2012 WRX STI
you'll need somebody experienced with a rotary buffer and some compound. I would go here and take a look:
http://www.autopia.org/find-professi...iler/index.php
Nagz is offline   Reply With Quote
Old 07-19-2010, 01:15 PM   #13
IIdiceII
Member#: 90438
you 99.9% need a rotary and wool pad. you will NEVER get those out by hand.
when i say 99.9%, I say that because people have had good results removing sanding scratches with an orbital and the surbuf pads.
IIdiceII is offline   Reply With Quote
Old 07-19-2010, 09:25 PM   #14
ctrent86
Member#: 129199
A PC in the right hands will do it (105/Surbuf), but will more than likely take some time, because I am assuming he sanded by hand to the surface will be all uneven.
OP take some steps backwards and ease into detailing a little bit more. Take it to a professional (Autopia has a good directory I believe), and get your read and learn on.
ctrent86 is offline   Reply With Quote
Old 07-20-2010, 03:09 PM   #15
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
post up where your from.....see if someone could help ya
holland_patrick is offline   Reply With Quote
Old 07-20-2010, 03:11 PM   #16
starlightluvsu
Member#: 238682
07 BBLGUN STI
EJ207 V9 swapped
if u do it by hand, u might end up making it worse and uneven.
starlightluvsu is offline   Reply With Quote
Old 07-20-2010, 03:21 PM   #17
CarbonDetails
Member#: 246012
2006 Acura TSX 6MT
x2, where are you located. You will not get it fixed by hand, rotary or atleast a orbital is needed.
CarbonDetails is offline   Reply With Quote
Old 07-21-2010, 01:41 AM   #18
Bdavis1
Member#: 241215
Sorry I haven't checked this in a few days. It turns out just a little polishing compound on a terry cloth pad with a little elbow grease fixed it perfectly. I can't even see the scratches!!! So i'm going to do the rest of my car seeing as how there are minor scratches everywhere....
So lets say I wanted to work internationally.... BhamRoadrunner Off-Topic 27 03-05-2008 10:12 AM
So lets say I want to produce porn BhamRoadrunner Off-Topic 56 02-05-2007 07:48 AM
OT DOCTORS: Sand is pouring out of my.... Turk Off-Topic 5 10-13-2006 02:19 PM
revved . . white smoke came out of my hood scoop x12oyx316x Transmission (AT/MT) & Driveline 14 07-03-2003 09:03 AM
Uhh... smoke coming out of my hood vent.. Clutch? Siper2 New England Impreza Club Forum -- NESIC 14 06-10-2002 10:39 AM
