Welcome to the North American Subaru Impreza Owners Club Thursday July 10, 2014
Vancouver Impreza Club
Old 07-14-2010, 01:39 PM   #1
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Default Good place to have the car tow to?
Something happened to my car and now it can't even idle properly (stutters and then stalls)...
The log says the engine is running lean but I checked as many parts as I could and can't find anything. I am hoping it is not the ringland or the headgasket...
Where is a good and reasonably priced place for me to tow my car to? 5Zigen? Kons? The dealership?
I am located in Richmond.
Here's the stuff I checked/tested:
Changed the engine oil. A bit dark but still looks like oil (it was about time for an oil change anyway).
Pulled the spark plugs and all looks dry and not too dark/white.
Pulled the TMIC, there was some oil in the piping but not that much I think.
The coolant looks green still, but with the expansion tank cap open it would bubble up when I first start the engine.
Disconnected the MAF sensor and still the same thing.
Disconnected the front O2 and still the same thing.
minifreak is offline   Reply With Quote
Old 07-14-2010, 01:57 PM   #2
Linkseal
Member#: 102329
05 AW Piggy Gone
11 SP TOM'S IS-F
To 5 Zigen... PM him about the shop address and cell.
Linkseal is offline   Reply With Quote
Old 07-14-2010, 02:05 PM   #3
iht
Member#: 196742
2000 Impreza 2.5rs
reset ecu?
take of turbo intake and check to see if the turbo bearings aren't blown?
iht is offline   Reply With Quote
Old 07-14-2010, 02:55 PM   #4
Linkseal
Member#: 102329
05 AW Piggy Gone
11 SP TOM'S IS-F
might be a defective idler... if other parts are tight and no leak...how does your fuel pressure look like?
Old 07-14-2010, 03:27 PM   #5
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
fuel pump?
alcoolaid is offline   Reply With Quote
Old 07-14-2010, 03:49 PM   #6
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Dealership will always be $$$.
For flatbed towing, you're probably looking between $75-100 to get it towed. Best to call around and get a quote for a flatbed.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 07-14-2010, 07:10 PM   #7
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
ZERO/SPORTS/99 GM6/05 BP6
is there fuel pressure? how much fuel you got in your tank? does the engine start, run, then stall? no DTC? only says it's running too lean?
what have been done to it recently? has it been running well or it has started to run poorly last couple days? if you have tried to start the car few times, no luck (all ended up stalling) and you said you pull out the plugs and they look just like normal, that's already not really normal?! especially when you said it looks DRY!
5 Zigen is offline   Reply With Quote
Old 07-14-2010, 07:43 PM   #8
brumue
Member#: 82175
2000 impreza
white
Not sure about the WRX, but on our Imprezza one coil pack died suddenly giving the same symptoms. I'll keep my fingers crossed for you.
brumue is offline   Reply With Quote
Old 07-14-2010, 08:35 PM   #9
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
WRX is individual coil
Old 07-14-2010, 09:17 PM   #10
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Not sure how much fuel pressure is as I don't have a fuel pressure gauge. The ECU is showing the fuel pump working at 33% duty cycle.
The only CEL I got was the P0171 System too Lean, no misfire.
Yeah, I wondered why the plugs looks dry, so perhaps the fuel pump or an injector is gone.
I am curious as to if a dying alternator/battery could cause issues like this. Hopefully I'll find out soon.
Old 07-14-2010, 10:00 PM   #11
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
not likely. if it has enough power to crank over and kinda start, it has enough power to run the engine. could also be a valve issue if you belt somehow lost tension and skipped a tooth.
sounds like low compression to me.
do a compression test. if the rings are shot or the ringlands cracked, or somehow the valves became slightly "bent" this will show it
the turbo would have nothing to do with it unless its broken in half and causing a huge vacuum leak. even if that were the case, unplugging the maf would atleast let it kind of idle.
Loomin is offline   Reply With Quote
Old 07-14-2010, 11:36 PM   #12
mcwc
Member#: 196262
1999 RSTi, Silver
1990 240DL, Gold
I had a similar problem. I've replaced the spark plugs, coil packs, one bank of injectors, cleaned the MAF, cleaned the IACV, and searched for potential vacuum leaks to fix the issue. Later, the front O2 got changed and that smoothed out the idle even though no code was thrown for it.
I have no idea what fixed it but each fix accumulated to a working car. The easiest and cheapest would be cleaning the MAF. IIRC, DBW cars don't have an IACV. Also, try to spray some contact cleaner into the fuel injector connector that plugs into the main harness.
mcwc is offline   Reply With Quote
Old 07-15-2010, 12:18 AM   #13
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
and if you are going to do compression test, leakdown test is very important too...
front O2 sensor is an air fuel ratio sensor, and yes it does make the car run a lot better especially if it has codes.
Old 07-16-2010, 02:55 AM   #14
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
good point! compression/leakdown test is much cheaper than randomly replacing parts it might or might not be as well.
Old 07-16-2010, 03:34 AM   #15
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
if the car has good compression and leakdown result, then check for fuel pressure etc, i am sure someone will have a stock fuel pump u can try? the car wouldn't just die itself, and when u said unplug MAF doesn't do any diff, that's already not "normal" (usually it should make some diff, better or worse)...u dun really need O2 to "run" the car, the car should idle and won't stall...
Old 07-23-2010, 08:47 PM   #16
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Update:
After some trouble shooting we eventually found out that the O-ring on the in-tank fuel filter is gone. I now have it by-passed and had an external fuel filter installed in the engine bay like the older style Impreza's.
A 2 dollar part caused my car to be down for a week...
Old 07-24-2010, 05:27 AM   #17
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Update:
I would get the injectors clean and flow tested where did the O ring end up.... what dirt etc might have ended up into the system.?
dasnowman is offline   Reply With Quote
Old 07-25-2010, 02:55 PM   #18
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
The o-ring was still in one piece, and the way it failed means any fuel that made it to the front of the car still has to pass through the filter.
The car still drives strong and holds good vacuum, but I'll get a compression test done on it just for a piece of mind. I have been pretty lucky with this instance, got a deal on a flatbed towing, Kon barely charge me anything for all the diagnostics he did and the car runs fine once the filter issue is fixed
+1 to Kon Auto on Venables, I plan on taking my car there in a few weeks to have the timing belt done
Old 07-25-2010, 04:32 PM   #19
steve
Member#: 4718
~ too
many to list
good to hear johnson.
That's such a painful issue to have diagnosed. Glad to see it's done.
steve is offline   Reply With Quote
My neighbor tried to have my car towed from MY driveway. vision.dynamix Off-Topic 185 06-30-2011 09:20 PM
after having the car protuned to 91 oct.... Nettalp Newbies & FAQs 2 07-10-2007 06:43 PM
It's nice to be right (nicer to have the car, but...) sonicblue Off-Topic 13 11-28-2006 04:42 PM
Detroit Area: Need to have my car towed to dealer. Which one? steelhead Mid West Subaru Owners Club Forum -- MWSOC 16 09-11-2005 07:59 PM
