Old 07-15-2010, 03:32 PM   #1
nickolas388
Member#: 135994
2006 wrx
Default hardcore WHEEL cleaning
long story short, i have rust/metal from the rear pads on my back rims of my 06 wrx. does anyone know how i could clean this? i got most of the heavy stuff off w/ rim cleaner and simple green (using the rough side of a sponge) but it isnt enough. is there a sand paper i can use without scratching the rims? would i be able to use a really fine steel wool? or is that too much?
all opinions are welcome.
thanks,
-nick
nickolas388 is offline   Reply With Quote
Old 07-15-2010, 03:34 PM   #2
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
Seen the title and thought this was something else
Cbgrandtheftauto is offline   Reply With Quote
Old 07-15-2010, 03:42 PM   #3
nickolas388
Member#: 135994
2006 wrx
lol, so no advice though?
Old 07-15-2010, 03:46 PM   #4
CC4nj
Member#: 136945
2005 WRX/CRX/LGT
Obs. Black
Try SONAX wheel cleaner...it targets the iron from the brake dust.
CC4nj is offline   Reply With Quote
Old 07-15-2010, 03:46 PM   #5
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
not really...you can try some steel wool but it may hurt the clear coat...spray some rust remover (like PB blast)on the spots but wash it off quickly and use some sealer afterwards
Old 07-15-2010, 04:06 PM   #6
lavid2002
Member#: 226864
I like purple power.... keep it off the paint though might be too strong for it
lavid2002 is offline   Reply With Quote
Old 07-15-2010, 04:16 PM   #7
TEK112
Member#: 218140
2009 WRX Prm Sed DGM
Know my friend Hiram?
I used to like black magic for my dirty rim jobs...
Sorry, I couldn't help it. However, black magic used to work wonders. You have to let it set in though.
TEK112 is offline   Reply With Quote
Old 07-15-2010, 05:01 PM   #8
litowrx
Member#: 132418
2004 EJ207
Chemical guys Diablo gel, or Sonax wheel cleaner.
litowrx is offline   Reply With Quote
Old 07-19-2010, 09:18 AM   #9
HarryN
Member#: 250258
2011 Legacy WRX STI
Dark Grey Metallic
What TEK112 said. Black Magic and even Eagle 1 are damn great products and what I use on my customer cars when I detail them.
Also, if you want to spend less time scrubbing your wheels clean, try spraying some armor all on a terry towel and put on a nice coat. Go over the rim two times until you have a nice film on it. Do not worry, it will not make the wheel look faded but in turn give it a wet look. But the best part is, next time you wash your car (whether in the winter or summer) all you have to do is spray the wheel clean with water. Even a garden hose using your thumb to spray off the dust will work as well.
But if the rim is as dirty as you say it is, OP, then you can't go wrong with Sonax. That is some great stuff.
HarryN is offline   Reply With Quote
Old 07-19-2010, 09:30 PM   #10
ctrent86
Member#: 129199
You might need a strong cleaner like Megs Wheel brightener. Sonax is a good choice as well and quite a bit strong then diablo wheel cleaner in my use (3:1 dilution).
After that you are really only left with an acid, just be very very careful, especially since your hardcore scrubbing might have effected the clearcoat.
ctrent86 is offline   Reply With Quote
Old 07-20-2010, 11:37 AM   #11
nickolas388
Member#: 135994
2006 wrx
thanks for everyones help, i think im going to try the sonax wheel cleaner. it seems expensive so i hope it works good. also, i really like the idea of the armor all on the wheels. im going to do that once i get them clean.
thanks,
-nick
Old 07-20-2010, 12:17 PM   #12
starlightluvsu
Member#: 238682
07 BBLGUN STI
EJ207 V9 swapped
WHEELS, not rims!! (unless ur only talking about the rim itself)
starlightluvsu is offline   Reply With Quote
Old 07-20-2010, 12:28 PM   #13
MooImpreza94
Member#: 252568
94 Impreza Wagon
[to be]Aspen White
not gonna lie, thats why I clicked here too
MooImpreza94 is offline   Reply With Quote
Old 07-20-2010, 12:31 PM   #14
starlightluvsu
Member#: 238682
07 BBLGUN STI
EJ207 V9 swapped
^ mind in gutter.
Old 07-20-2010, 12:32 PM   #15
CarbonDetails
Member#: 246012
2006 Acura TSX 6MT
Sandpaper, steel wool will scratch up the wheels. All sandpaper will induce scratches, something like 2,000-3,000 will make very small scratches but none the less there scratches and probably will do more harm. You could try eagle one metal polish. It comes in a silver tin and its like wadding but its not harsh and should help clean it up a bit.
SANDPAPER AND STEEL WOOL WILL SCUFF UP THE WHEELS
CarbonDetails is offline   Reply With Quote
Old 07-20-2010, 06:16 PM   #16
JT05
Member#: 252619
Use steel wool but you will have to put another clear coat on.... also try mothers they have some really good products
JT05 is offline   Reply With Quote
Old 07-20-2010, 06:54 PM   #17
Wintershredder
Member#: 160089
2008 M5/330xi/328xi
Black/Black/White
Sonax
/thread
Wintershredder is offline   Reply With Quote
Old 07-20-2010, 07:19 PM   #18
IIdiceII
Member#: 90438
sonax wont take off anything REALLY built up...megs wheel brightner is your best bet with LOTS of elbow grease followed by a really aggressive clay bar.
IIdiceII is offline   Reply With Quote
Old 07-20-2010, 08:16 PM   #19
lgangi
Member#: 132632
2006 WRX Wagon
Bright Silver
Megs Wheel Brightener did a good job of removing the rust from my inner wheel surfaces without much work just normal wheel brush agitation. I thought they were done...but now look almost new.
lgangi is offline   Reply With Quote
Old 07-20-2010, 10:27 PM   #20
jefmcc
Member#: 42303
2004 WRX
Rally Blue
Why a clay bar?
jefmcc is offline   Reply With Quote
Old 07-20-2010, 10:29 PM   #21
CarbonDetails
Member#: 246012
2006 Acura TSX 6MT
Clay bar will help remove any of the rust/contaminants.
Old 07-20-2010, 11:41 PM   #22
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Between this and "My knob is old and worn out" I'm not sure what to think.
CKxx is offline   Reply With Quote
Old 07-21-2010, 12:51 AM   #23
vms150
Member#: 172917
2004 WRX
I am sure this will be horribly frowned upon here, and I personally wouldn't do it. As an absolute last resort I have heard the the non-bake type oven cleaner can be used when nothing else will work.
On another note, I used non-diluted simple green automotive formula before painting my wheels to remove all the grime. It worked well, and in condensed state it is pretty harsh stuff.
vms150 is offline   Reply With Quote
Old 07-21-2010, 01:20 PM   #24
nickolas388
Member#: 135994
2006 wrx
couldnt find sonax at autozone or pepboys, anyone know where they carry it?
Old 07-21-2010, 01:34 PM   #25
starlightluvsu
Member#: 238682
07 BBLGUN STI
EJ207 V9 swapped
ill tell u if u change ur post to say wheel instead of rim.
keeping white rims clean? mofoporn Car Care & Detailing 21 06-02-2011 07:51 AM
Keeping painted rims clean? baileypicks24 Interior & Exterior Modification 10 01-31-2005 10:03 AM
Keeping painted rims clean and shiny? baileypicks24 Tire & Wheel 1 01-15-2005 08:09 PM
rim cleaning creaquack Interior & Exterior Modification 7 01-09-2004 11:41 AM
Rim cleaning ideas Qbushido Interior & Exterior Modification 8 09-08-2003 06:34 PM
