Old 07-15-2010, 10:16 PM   #1
FLT.4.PWR
Member#: 252007
07 Impreza 2.5i
Silver like a bullet :)
Default Pulse plugs!
Who's use these plug and what have thought of them... Any one used BE1I plugs! Anythings about them !
FLT.4.PWR is offline   Reply With Quote
Old 07-15-2010, 11:32 PM   #2
toyjunkie
Member#: 177315
2004 sti
wrb
my opinion is that they are a gimmic. made my car run like crap. put the old plugs back in and it ran fine. i sent them back and got my money back.
toyjunkie is offline   Reply With Quote
Old 07-17-2010, 04:11 PM   #3
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
can i tell you a secret?
there is very little new technology, just alot of hoaxs
you can put those pulse plugs up next to your bosch platinum+4 plugs
feint05 is offline   Reply With Quote
Old 07-17-2010, 05:53 PM   #4
Back Road Runner
Member#: 60082
2004 Forester STI
This thread needs more !!!!!!!! to emphasize...something...
Google is your friend. The Pulse plugs have been around for a while and a number of people have used them.
Just realize that the plug ignites the fuel. A better plug will not help any more unless the plug it is replacing is having trouble igniting the fuel (large gap, fouling, etc.) You would experience misfires if this was happening. After the fuel is ignited, there really isn't anything more the spark plug does. The fuel will simply burn up at a given speed based off its octane.
So what does a $1 cheapy copper plug do worse than the super whatever plug you might be looking at?
Old 07-20-2010, 08:32 PM   #5
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
well, technically if the plug can create multiple sparks at the same time it should create multiple flame fronts which should have some effect on the combustion. how and if it would be good, I couldn't say. I've thought about this because aircraft engines (and some auto engines) have two ignition systems so two plugs fire at the same time (or nearly the same time) and it makes a very noticeable difference in engine roughness and power output! The plug locations on aircraft engines are opposite sides of the CC so the epicenter of the combustion events couldn't be replicated with a single plug.
Old 07-21-2010, 11:26 AM   #6
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
On aircraft at least, isn't some of this also just for redundancy? I'm pretty sure most/all piston aircraft have completely separate dual ignition systems, just in case one fails. . .That said, dual-plugging is rather popular mod among the BMW airhead motorcycles. . .with all sorts of partially and un-substantiated claims of wild power increases.
motohippy is offline   Reply With Quote
Old 07-21-2010, 12:01 PM   #7
SubyRS03
Member#: 245297
2004 WRX vf48 93 oct
Dude i have em in my car and i like em. i dont see a big differnce but there are many good reps about em import tuner did a article about em Dsport did one too check it !
SubyRS03 is offline   Reply With Quote
Old 07-21-2010, 12:15 PM   #8
eppoh
Member#: 199401
2000 Legacy OB
95 Honda wagon 66 Belanca
I had dual plugs in a BMW r100. Just take a wire off one and drive it- you can see the difference, It is significant. In my airplane, at 1700 RPM dropping one mag results in a loss of 100 rpm
eppoh is offline   Reply With Quote
Old 07-21-2010, 01:12 PM   #9
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Not without moving it won't. If the plug ignites the fuel near it, there won't be any fuel left to ignite a second time.
If you have two plugs, you can start two flame fronts from different locations. That would certainly change the engine's performance. But it wouldn't be the same as having a single plug fire multiple times.
sniper1rfa is offline   Reply With Quote
Old 07-21-2010, 08:58 PM   #10
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Oh yes, the primary reason for having two ignition systems is for reliability and safety, no doubt. I was just saying that it ALSO results in more performance.
Who said anything about the same plug firing multiple times? multiple sparks at the same time @ different locations is the key.
Now if one plug can fire multiple sparks across multiple electrode gaps, it would effectively be just like having multiple, very close together plugs. And I think that may result in little no measurable gain in combustion "performance" because of the proximity of the combustion epicenters to eachother.
Hope that make my previous statement more clear.
In any case, this is not how the Pulse plug works and there are no plugs/ignition systems capable of doing such a thing.
Old 07-21-2010, 09:01 PM   #11
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Uh oh, 75 rpm mag drop is the max allowed!
I don't think I have seen a 75 rpm mag drop on new plugs and bendix mags even with retarded timing.
Old 07-22-2010, 08:59 AM   #12
GEE-OTTO
Member#: 201277
2009 Legacy GT
i bet you believe that the slap chop is greatest kitchen item to be invented? YOUR EJ253 runs best with NGK or Champion platinum or copper plugs. Please do not waste money on "pulse plugs" but if you must try the latest in plug tech spring for a set of Split Fires!
GEE-OTTO is offline   Reply With Quote
Old 07-22-2010, 09:05 AM   #13
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
NGK Iridium
dstan is offline   Reply With Quote
Old 07-22-2010, 05:58 PM   #14
eppoh
Member#: 199401
2000 Legacy OB
It's 125 on a lycoming O-320
Old 07-23-2010, 12:01 AM   #15
kantthinkofasn77
Member#: 220808
2005 WRX Wagon
i dont think creating multiple flame fronts will do anything for your boxer except cause pre detonation and too many explosions on top of the piston while its on the exhaust stroke. the pulse plugs are significant because it creates more of an expanding force on the air fuel mixture instead of an explosion. obviously it ignites the mixture, however it aids into a stronger combustion force on to the piston which we all know equals some kinda hp gain. modified mag did a little write up on them. you can find the pdf of the article with this link --> http://www.pulstar.com/pdf/Modified_April2008.pdf
kantthinkofasn77 is offline   Reply With Quote
Old 07-23-2010, 12:02 AM   #16
kantthinkofasn77
Member#: 220808
2005 WRX Wagon
Pulse Star Plugs subaru_steve Service & Maintenance 2 09-18-2009 11:42 PM
Pulse Plugs...Comments? Concerns? XtianBajafresh Mid West Subaru Owners Club Forum -- MWSOC 6 04-09-2008 01:14 PM
pulse plug? Anyone try that? SuperTurbo Newbies & FAQs 1 04-01-2008 02:23 AM
Pulse Star Pulse Plugs bigmatt33 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-05-2008 03:35 PM
Pulstar Pulse Plugs = Gimmick? impreza4life Normally Aspirated Powertrain 2 01-28-2008 04:25 PM
