#1 |
Member#: 251519
Vehicle:2010 Impreza 2.5i Dark Grey |
Freaking pissed... 2 week new car now has 4 long scratch marks on the bumper that took away the clear coat...
Any suggestions on how to fix it?? Thanks!! ![]() ![]()
#2 |
Member#: 248305
Vehicle:97 OBS my custom mixed silver |
If the scratches are down to the paint then a reclear is needed.
#3 |
Member#: 112992
SCIC
Vehicle:2006 WRX TR Crystal Gray |
try some meguiars scratch remover. If not you'll have to buy some touch up paint from the stealership or online.
Put a few thin layers till it's about level with the original paint job and sand it down with some super high grit sandpaper. I forget the number, but sand it till it's about flat and even. Then buff it with some scratch removing compound and finish it off with a polishing compound. Add a clear coat on top if you'd like. I had some deep scratches that went to the metal of my hood on my G35. Did all those things and I must say it came out really nicely. Not perfect, but you'd really have to look to find it. PM me if you want to know the exact products I used. I'm too lazy to walk to the garage right now. Also not sure if I'm allowed to promote other forums, but autopia.org is a good website Last edited by Wannascooby; 07-16-2010 at 12:15 AM. |
#4 |
Member#: 201661
RMIC
Vehicle:2009 WRX "Stage 2" 2002 Forester |
do they disappear if you wipe a wet rag over them? If so, they should buff out with some scratch remover/polish/wax action though it looks like a DA will be necessary.
#5 |
Member#: 251519
Thanks for the input...
The rear bumper feels plasticky... the clear coat is gone, I can still see the dark grey paint.. so I should wash and dry the area then add the touch up paint (1 small tough up pen with brush free from dealer) and sand it down... I'm scared that I'll create more scratches from the sanding... I was thinking of getting the following: Autoglym Super Resin Polish Autoglym Rapid Detailer and maybe Autoglym High Definition Wax Kit Would it work if I just use the first two products? Also, which clear coating product I should get to protect the paint that is available at Canadian Tire? |
#6 | |
Member#: 42303
NESIC
Vehicle:2004 WRX Rally Blue |
The higher the number, the finer the grit/grade. Generally, 1200 -1500 grit is good for taking down touch up paint. I use 3000 before I polish. Could just be the pictures, but those look too big to really use touch up effectively. Curious, how did you get those? Are you positive that the clear is gone? Last edited by jefmcc; 07-16-2010 at 02:41 PM. |
#7 | |
Member#: 251519
I don't know how I got those marks.. I don't recall hiting scraping any objects.. the marks are long and wide.. roughly 1 CM to to 1.5 CM wide and 15CM long The top clear layer is gone.. I was rinsing my car last night and I saw the marks.. I can feeling of the marks is different from other non-scratched areas.. it feels a bit rough... |
#8 |
Member#: 25187
Vehicle:'08 Foz Prem TGM '10 Challenger R/T Blk |
....before you do any touch up or sanding, I would try using a product like Scratch-X from Meguiars or use their Ultimate Compound followed by Swirl-X to remove any fine marks left by the UC. ….I would suggest the latter combo.
I have removed abrasions like this on several occasions. I’ll wager that most of those blemishes will disappear or will improve to a point that you will be satisfied with just polishing. There are a couple of spots though (on the body line and edge of the wheel arch) that look pretty deep. In either case, I would highly recommend polishing first before even considering touch up/repair. You will have a better idea of the actual damage at that point so you can re-assess and proceed from there if needed. IMO/IME some damage can look much worse than it actually is. |
#9 | |
Member#: 251519
Thanks |
#10 |
Member#: 25187
No problem. I would pick one small spot on concentrate on making that area better. This will give you a good idea of the effort involved in polishing out the rest of the blemish and just how effective polishing will be. It may take a little effort/time to get results. ....just keep checking your progress as you go.
#11 |
Member#: 252177
VIC
Vehicle:2002 Impreza 2.5 TS |
Man, I feel your pain, that really sucks. I'd try some rough cut polish with a good hand held polisher.
#12 |
Member#: 251519
I'm planning to use ScratchX first and followed by autoglym polish and autoglym detailer.. Is this a good step as a starter?
Going to Canadian Tire today after work then start working on the Car tonight after my studies... Damn this... Final exam on the 27.... work FT, repair scratches, and prep for final exam... Will post results another time Thanks everyone for their input |
#13 |
Member#: 239150
Vehicle:2003 WRX Sedan |
1. you should really wipe down the area clean before taking pictures
2. doesnt look that bad. i would recommend Ultimate compound over scratch X since it has a bit more cut in it. you wanna do at least two polishes. one for the cut, and a follow up. make sure you wax after youre done. |
#14 | |
Member#: 251519
So I use the Ultimate compound then I polish with autoglym then let dry and polish again? After the two polishes I wax? ![]() |
#15 |
Member#: 82989
NESIC
Vehicle:2002 WRX Hybrid VF22 |
Those scratches are nothing... I could easily take those out with my PC 7424 with a light polish pad.
#16 |
Member#: 241289
Yeah those scratches don't look bad at all. Don't even think about putting touch up paint on them.
#17 |
Member#: 252275
Porter cable buffer with swirl remover and a red pad.
#18 |
Member#: 251519
After polish using autoglym resin polish.. Need to use touch up paint for the areas circled in red... all the paint on those spots are gone.. it down to the plastic bottom...
#19 |
Member#: 25187
....yeah. That's what I thought. The good news is that the rest of the marks (mostly) appear to have come out like we thought. Now you can re-assess, consider your opotions and decide what you want to do about those smaller problem areas.
#20 |
Member#: 251519
I'm thinking of using touch up paint.. gradually adding thin layers... then give it a polish
#21 |
Member#: 25187
....that's one thing I will admit I suck at. However, I have seen touch up jobs that were wetsanded and then buffed with results that were difficult to tell there was ever any damage. ....on the other hand, I've seen touch ups that looked worse than the initial damage. I would do as much reading as possible on detailing forums like Autopia.org, etc. before diving in. It should really help guide you through the process.
#22 | |
Member#: 251519
#23 |
Member#: 241382
Those one are too deep...Needs repaint.
#24 |
Member#: 239150
yea if you are brave do some wetsanding. otherwise a little touch up paint and polish will only make it look better. the less you try to do, the less chance there is to mess it up
#25 | |
Member#: 251519
I already put a thin layer of touch up paint, but haven't polished it yet. Will polish it next week after final exam. Yeah it's not perfect, but better than the plastic showing. It's a good temp fix though. |
| Thread Tools | |
| Display Modes | |
| how to fix paint chips/deep scratches? | mcdrumrboy | Interior & Exterior Modification | 3 | 02-13-2006 05:13 PM |
| deep scratches on bumper sides. how to fix? touchup paint? | garie | Service & Maintenance | 2 | 11-05-2003 12:02 AM |
| Scratched 17" Rota Subzero! Any ideas in how to fix? | Kucheto | Interior & Exterior Modification | 10 | 09-09-2003 01:02 PM |
| How to fix scratched wheels? | YoungWilliams | Tire & Wheel | 3 | 04-25-2003 12:25 AM |
| How to fix or conceal small scratches? | Robmat | General Forum Archive | 2 | 02-04-2001 05:03 PM |
