Old 07-13-2010, 09:49 PM   #1
hoffmanEstates
Member#: 122043
04 wagonier
psm
Angry ac issues compressor running
i am encountering a wierd issue my ac compressor is constantly running. i sucked the system down and put a 30min vacum draw down to -30in. recharged and still no change. it used to cycle. what am i missing on testing
hoffmanEstates is offline   Reply With Quote
Old 07-13-2010, 11:24 PM   #2
Wrencher86
Member#: 250463
2010 Impreza 2.5i
How hot is it outside? Is it blowing cold out the vents? If it's still cooling properly I'm not sure I'd worry about it.
Wrencher86 is offline   Reply With Quote
Old 07-14-2010, 02:59 AM   #3
caterpill
Member#: 27136
Is your suction line frosting up?
Your low-pressure cycling switch might not be working - your a/c won't blow warm, but if your evaporator ices up, the air blowing through the vents will start to diminish.
caterpill is offline   Reply With Quote
Old 07-14-2010, 03:23 PM   #4
hoffmanEstates
Member#: 122043
04 wagonier
psm
sounds familiar. so you mean low psi switch is going bad? how do i test such a switch? or any other switches
Old 07-16-2010, 03:11 AM   #5
caterpill
Member#: 27136
Oops, I retract my previous statement. Subarus use a a TXV setup, not like most CCOT setups on domestics.. LOL DUH.
I'm sorry, there is no such "low pressure switch" on subarus. I wasn't thinking.
A/C compressor clutch cycling is controlled by the "thermo control amplifier", which is the thermal expansion valve.
It'll cut power to the a/c compressor clutch before the evap. core frosts up.
Like someone said previously, if your a/c is cold, it's probably not a cause for concern. You do need to do further troubleshooting, though, if you go WOT and your a/c compressor still stays on.
Try running your a/c on the recirc setting, at the lowest blower speed at night time. Let it idle and run the car.. see if you see any frosting of the low side a/c lines and the compressor still does not cycle out, you may have a problem.
Old 07-17-2010, 11:18 AM   #6
datwrx
Member#: 17821
2002 Subaru wrx
candy apple red
I having the same damn problem. The AC is not leaking and the compressor is working fine. The only thing I can think of is the expansion valve. I hope to change it soon and see if works. Subaru AC system sucks.
datwrx is offline   Reply With Quote
Old 07-18-2010, 10:20 PM   #7
ep3smoker
Member#: 248857
2004 Wrx wagon
[quote=caterpill;31324361]
the thermo control amp and expansion valve are two different parts.
is the ac cooling?
ep3smoker is offline   Reply With Quote
Old 07-18-2010, 10:52 PM   #8
hoffmanEstates
Member#: 122043
04 wagonier
psm
yes a/c sucks i just "refreshed" the system and STILL its blows cheap cold air i hope into a 94 lumina and it was like a freezer
Old 07-18-2010, 11:19 PM   #9
ep3smoker
Member#: 248857
2004 Wrx wagon
how much refrigerant did you put in it?
AC clutch/compressor Audiosavvy Engine/Power/Exhaust 3 04-24-2009 03:49 PM
CT: 04 WRX AC pump / compressor, 17k miles, $50 jamesfacts Engine/Power/Exhaust 0 03-04-2009 07:01 PM
FS: AC lines/compressor from 98 2.2 compleckz 1993 - 2001 Impreza Specific Parts 4 06-01-2008 07:23 AM
'02 WRX AC Condensor/Compressor strong_auto_concepts Engine/Power/Exhaust 2 03-04-2008 03:55 PM
Refrigerator question--compressor running constantly Stephanie Off-Topic 12 10-19-2006 10:46 PM
