Old 07-16-2010, 10:37 PM   #1
ScoobyDude2002
Member#: 169868
2002 Impreza WRX
Default I want more power out of my 2002 2.5rs...
I have had my Impreza rs for some time now and so far i have the normal stuff.
Weapon r secret weapon intake
SRS ebay catback exhaust
fake Borla headers
Rallitek plug wires
NGK Platinum plugs
I want more power and i have been looking for a tuning device like the perrin or cobb but cant find any. I was wondering what I can do to get some extra powa!!
ScoobyDude2002 is offline   Reply With Quote
Old 07-16-2010, 10:43 PM   #2
jeonster
Member#: 198854
2013 WRX
Cat delete, weight reduction, cams, lightweight pulley, EL headers, Stop by an N/A tuner
jeonster is offline   Reply With Quote
Old 07-16-2010, 10:48 PM   #3
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
Also could tighten up suspension, which helps with cornering faster.
+1 on a NA tuner.
djinn is offline   Reply With Quote
Old 07-16-2010, 10:49 PM   #4
ScoobyDude2002
Member#: 169868
2002 Impreza WRX
Awesome! where would i find the cams at because every time i look they always say 2.5 WRX
Old 07-16-2010, 10:50 PM   #5
ScoobyDude2002
Member#: 169868
2002 Impreza WRX
Yeah i have been looking at megan racing coil overs or the KW coil overs... right now i got the KYB adjustable gas shocks with eibach lowering springs. I also have white line max caster camber upper mounts and white line endlinks for front sway bar
Old 07-17-2010, 11:54 AM   #6
wmdoucette
Member#: 192709
2007 2.5iSE Wagon CG
2001 2.5RS Coupe RBP
Call Delta (down time, options on grind), or buy from Rallitek (cores available, only one choice for grind).
wmdoucette is offline   Reply With Quote
Old 07-17-2010, 11:06 PM   #7
ScoobyDude2002
Member#: 169868
2002 Impreza WRX
thank you guys so much so far!! lots and lots of help
Old 07-17-2010, 11:17 PM   #8
SubyRS03
Member#: 245297
2004 WRX vf48 93 oct
Another area you could check out are phelonic intake manny spacers. and you could take your car to a nice suby tuner and have them tune it cause subys are tuned so restricted.
SubyRS03 is offline   Reply With Quote
Old 07-18-2010, 06:47 PM   #9
ScoobyDude2002
Member#: 169868
2002 Impreza WRX
so i looked at the phenolic spacers and i would love to get them but they are only for the WRX or STi i cant find any for the 2.5rs. now if they work i will get them because thats an awesome idea!!
Old 07-18-2010, 08:00 PM   #10
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I wouldn't bother with deleting the cat unless an exhaust you buy already comes without one, i.e., I wouldn't go out of my way to do it. Personally, I can't stand the smell of catless and I think it makes exhausts sound raspy. There's a thread on here showing that going catless did pretty much nothing. I don't feel like searching for it.
chazly413 is offline   Reply With Quote
Old 07-19-2010, 12:20 PM   #11
SubyRS03
Member#: 245297
they make phelonic spacers for are car ill try and find the website that sells em there an 8mm but all you would need is about a 6mm
Old 07-19-2010, 12:24 PM   #12
SubyRS03
Member#: 245297
http://www.upscaleautomotive.com/p-4...-2225l-na.aspx
those are the phelonic spacers made by grimspeed
Old 07-20-2010, 09:59 AM   #13
ScoobyDude2002
Member#: 169868
2002 Impreza WRX
Sweet! thanks again
Old 07-20-2010, 10:30 AM   #14
GEE-OTTO
Member#: 201277
2009 Legacy GT
Find a used AVo turbo kit
GEE-OTTO is offline   Reply With Quote
Old 07-20-2010, 10:37 AM   #15
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
+1 for delta cams, i have them and it's made the biggest difference. I did them with a Exedy LW flywheel and clutch so it really livened things up. You will want some tuning done if you are going to do cams, I don't' remember if you can do open source tuning with the 02, it's been a while since I've looked into anything like that but I know it's not avail on my 04. I already had the Perfect Power 6 Piggy back so i just had to run the stage 3 map they Rallitek sent me. But not to be a downer but no matter what you do there will never be quite enough power and eventually you will run out of stuff to do and it get really expensive at that point, that's about where I'm at now.
aclver1 is offline   Reply With Quote
Old 07-20-2010, 12:19 PM   #16
iluvdrt
Member#: 46248
82 Brat
Tan
If your car is equipped with EGR the spacers will cause the tube to be too short. You will have to extend it.
You can also take the coolant line off of your TB unless The IACV is built into the TB its self.
iluvdrt is offline   Reply With Quote
Old 07-20-2010, 05:42 PM   #17
SubyRS03
Member#: 245297
good lord i just looked at the avo turbo kit. its nice but dang i wanted a to spend 4500more i would have bought a wrx =) its just too much all im doing is full exhaust headers,hi flow cat,mid,axel back and sri, phelonic spacers, tires,wheels n a Roof rack thats it the N/A models are best kept to basics.(not unless you got the money then go for it)
Old 07-20-2010, 06:33 PM   #18
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
They make spacers? http://www.phelon.com/
Old 07-21-2010, 10:35 AM   #19
watchdoc
Member#: 104821
2015 Outback LTD
don't forget the raptor supercharger kit.
watchdoc is offline   Reply With Quote
Old 07-21-2010, 01:38 PM   #20
ederd2003
Member#: 219822
2003 Impreza RS
Default swap it
+1
Cat delete or high flow cat can give u some gains if u dont wanna run catless.
lightweight pulley's orrrr get a lightweight flywheel. it'll rev a lot faster then with a lightweight pulley.
but seriously if you want POWER then u should just get a wrx. RS's are more of a fun driver then anything. The most power u could get with general mods (including internal) is around 230 (and thats probably to the crank). The most anyones gotten out of our engine is about 300 hp. But thats a specific build and not even worth it unless u have an unlimited budget.
I recommend lightweight flywheel.
ederd2003 is offline   Reply With Quote
Old 07-21-2010, 02:26 PM   #21
watchdoc
Member#: 104821
2015 Outback LTD
A 2.5 RS will pretty much beat a WRX on a rallyx course any day of the week. The lighter weight, better throttle response, and instant torque make it a lot more fun to drive as well. They are actually really fun at autox too but currently not classed well.
You can knock close to 75lbs off the front end of a 2.5 RS pretty easily which makes it handle even better.
light weight battery -13+
light weight bumper beam -20
WRX hood -22
Lightweight flywheel -10??
headers -5??
Keep your RS brakes since they are lighter than WRX rotors and work absolutely fine unless you plan to use the car for track days. (in which case, you only need a pair of good WRX rotors and caliper brackets).
Old 07-21-2010, 03:16 PM   #22
SubyRS03
Member#: 245297
^^i deffinatley agree about the hood the wrx hood was super less. its aluminum i belive but the stock 2.5rs has a steel hood
Old 07-21-2010, 05:21 PM   #23
ScoobyDude2002
Member#: 169868
2002 Impreza WRX
SWEEEET!! i think im just gonna do some fun stuff with this make this my daily then get a WRX later and make that my project!!
Old 07-23-2010, 02:56 PM   #24
watchdoc
Member#: 104821
2015 Outback LTD
Don't forget how much money you're saving in gas since the 2.5 RS doesn't require premium.
Old 07-23-2010, 03:06 PM   #25
Bluefoton
Member#: 141373
2008 2.5i-hatch -
FS/FT : Potential part out of my 2001 2.5RS yeos NWIC Private Classifieds 34 08-12-2010 11:20 PM
Not getting the power out of my stage 2! b.s. subie_nation General Community 25 04-30-2008 11:42 PM
More power out of the 2.0 peewee111 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 09-05-2007 07:42 PM
how can i get more power out of my stock outback impreza jbone2 Newbies & FAQs 4 03-03-2007 11:26 PM
Looking for More power out of my 2.5RS chris Stephens Normally Aspirated Powertrain 18 01-28-2006 11:50 AM
