Old 07-17-2010, 04:25 PM   #1
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
Default 2000 RS will not crank
I have a friend with a 2000 automatic RS that would not crank, it is not the battery and my guess it is gear position switch, where is this switch located?
and how hard is it to bypass.
Any other thoughts on what could be going on are appreciated.
Thanks, Dave
dstan is offline   Reply With Quote
Old 07-17-2010, 05:28 PM   #2
~Gregster~
Member#: 252281
2007 Impreza
Get a test light and see if there is power at the A terminal on the starter from the battery. If there is then get someone to go in the car and have them turn the car as if they were starting the car. Check for power at the B terminal on the solenoid, The ignition switch sends power then when cranking, If you are getting power at both terminals then you'll need a starter. I'd try tapping it a few times with a hammer and see if it will crank.
If you aren't getting power at the starter at the battery then it's a broken wire. If you aren't getting power from the ignition switch then it can be the switch, shift interlock or bad fuse. You can always jump the shift interlock switch.
~Gregster~ is offline   Reply With Quote
Old 07-18-2010, 08:08 PM   #3
dstan
Member#: 120386
stupid security switch
2000 RS Crank trigger wheels Odyknuck Normally Aspirated Powertrain 1 03-31-2009 04:39 PM
2000 RS 2.5 had 79mm crank? With 52mm rod ends? reddevil Normally Aspirated Powertrain 2 03-30-2008 09:26 PM
WRX swap in RS will not start Turb0loverRS Subaru Conversions 5 05-28-2007 10:04 AM
Help! Car will not crank. Sounds like a machine gun. em199si Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-02-2007 04:16 AM
On a stock 2000 RS, will adding 4 to 5 lbs per wheel feel much slower? Gravel-Fun Brakes, Steering & Suspension 5 09-17-2002 01:00 AM
