Old 07-18-2010, 09:39 PM   #1
Effers
Member#: 221803
2010 WRX Limited 5DR
World Rally Blue
Default Removing wax/polish from plastic trim?
What do you guys use? I've heard isopropyl alcohol with rag may work - thoughts?
Thanks.
Effers is offline   Reply With Quote
Old 07-19-2010, 07:31 AM   #2
BadTrainDriver
Member#: 201416
1998 Impreza L
WD-40 on a rag...or lightly sprayed on a old toothbrush.
Takes wax off in a split second...and won't harm paint, trim,...or pretty much anything.
BTD.
BadTrainDriver is offline   Reply With Quote
Old 07-19-2010, 09:22 AM   #3
HarryN
Member#: 250258
2011 Legacy WRX STI
Dark Grey Metallic
Isopropyl or even denatured alcohol will work wonders and very quickly, but will dry out the oils to keep the trim flexible. Best to go over it with a spray wax afterwards.
HarryN is offline   Reply With Quote
Old 07-19-2010, 06:25 PM   #4
pacer07
Member#: 207068
06 Doesn't matter
its not a Subie!
We use this at my shop daily. It takes any type of wax off with one application and leaves a nice non greasy shine.
http://www.rubber-seal.com/prodview.asp?prodID=1558
pacer07 is offline   Reply With Quote
Old 07-20-2010, 08:24 PM   #5
lgangi
Member#: 132632
2006 WRX Wagon
Bright Silver
peanut butter...yep you heard right. visit autopia and learn more.
lgangi is offline   Reply With Quote
Old 07-21-2010, 12:48 PM   #6
Brian610
Member#: 161477
Griots Garage dried on wax remover works great.
Brian610 is offline   Reply With Quote
Old 07-21-2010, 01:01 PM   #7
starlightluvsu
Member#: 238682
07 BBLGUN STI
EJ207 V9 swapped
ive done this!
starlightluvsu is online now   Reply With Quote
Old 08-17-2010, 12:53 PM   #8
91gl
Member#: 186019
Optimum power clean works wonders
91gl is offline   Reply With Quote
Old 08-18-2010, 02:27 AM   #9
Kfly04
Member#: 252005
2004 STI
Java Black
really fine steel wool cleans it well and windows too!
Kfly04 is offline   Reply With Quote
Removing wax residue from clear bra edge. TRooper Car Care & Detailing 8 03-18-2010 03:35 PM
How to remove wax from black trim?? rice h8r Off-Topic 26 05-20-2006 07:37 PM
wax remover as polish? oilpond Car Care & Detailing 2 07-19-2002 05:22 PM
Removing wax from black trim G-REX Car Care & Detailing 4 07-14-2002 06:34 PM
Plastic trim removal help needed aowRS General Forum Archive 7 04-02-2001 06:04 AM
Message Board Statistics All times are GMT -4. The time now is 06:44 PM.
