Old 07-20-2010, 12:09 AM   #1
blckout7
Member#: 189845
Default quick question about pulleys..
I was looking to potentially change my Lightweight Crankshaft Pulley, but have a concern.
My friend was telling me because im running a moderate-strong sound system something about the pulleys not allowing the alternator to generate enough power?
Im running about, 700 watts rms and 1100 max watts.
p.s this is the pulley i was looking at http://www.rallitek.com/Lightweight-...-Pulley/p-4532 if anyone could give me a review or comment about that, as well as what kind of gain would i be looking at? Thank you so much.
blckout7 is offline   Reply With Quote
Old 07-20-2010, 12:24 AM   #2
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
The pulley that you linked to should cause no problems with your electrical components, as it is not an underdriven pulley (smaller diameter than stock).
If you have a lightweight flywheel, a lightweight crank pulley can cause difficulty shifting in stop and go situations (can vary for different drivers).
rhino6303 is offline   Reply With Quote
Old 07-20-2010, 08:19 AM   #3
Boxer4Dad
Member#: 137226
2005 Saabaru 2.5i
OBP, or Black
Yep, you want to stay away from under-driven ones if you're concerned about electrical draw. There are plenty of choices, so it shouldn't be hard to find one.
Boxer4Dad is offline   Reply With Quote
Old 07-20-2010, 11:46 AM   #4
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
I know a few who run the linked pulley...no problems with electrical systems. A side note: Get a spare key for the cranknose from the dealer. It's 4 bucks i think, but it's one of thoes things thats nice to have on hand incase the stock key falls off and you cant find it. Other than that, the install takes 20 min tops.
treksofar is offline   Reply With Quote
Old 07-26-2010, 10:00 AM   #5
greanie
Member#: 194581
2002 Imp. Outback Sp
Default shouldn't be a problem
Yup, shouldn't be a problem. The power level you are looking for is not that high and should work with standard parts as you linked.
greanie is offline   Reply With Quote
Quick question about timing belt guide pulley spoolinej25 Newbies & FAQs 0 04-10-2010 09:33 PM
quick question.. crank pulley r0n Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-07-2007 10:18 PM
quick question about oil pressure...worried about my car Blindeye_03 South East Region Forum 6 09-03-2004 11:58 AM
Someone QUICK!!!..questions about installing racing pulley AustinSTi General Community 19 01-31-2002 09:07 PM
Help, need quick answer to quick question about ezpass munkis General Forum Archive 2 09-29-2000 03:45 PM
