Old 07-20-2010, 05:15 PM   #1
phunkeeHomosapien
Member#: 56061
Unhappy 96 legacy rough idle/ slow start
A few days ago I changed the plugs/wires. Also i attemted to take of the exhaust so i could get to the drive line in order to replace the front U-joint. In trying to take the exhaust off i used and impact wrench to get no result. My question is that do you think putting the impact wrench on the exhaust could have rattled my cats to break in on themselves? or is this slow start and rough idle due to the changing of the plugs/ wires? any help would be greatly appreciated as i need to fix it soon..............
phunkeeHomosapien is offline   Reply With Quote
Old 07-20-2010, 05:17 PM   #2
phunkeeHomosapien
Member#: 56061
Also wondering how can one tell if a catalyctic converter is still good or not?
Old 07-20-2010, 05:43 PM   #3
flightwatch
Member#: 231058
2015 F-150
Slow start and rough idle wouldn't be caused by a cat. If the cat was completely clogged, your car wouldn't run at all. Are you getting a cel? If so, get it read at Autozone and tell us what it is.
It's more than likely a bad plug/wire. You need to go back through each plug and wire to make sure that they are gapped correctly, and that you didn't get the wires crossed. If all else fails take the new ones off and put the old ones on (You saved the old ones for a bit...right?) and then start swapping them out one by one until you find the bad plug/wire.
You can tell a bad cat by the very potent rotten egg smell that t gives off...that and the cel.
flightwatch is offline   Reply With Quote
2002 Legacy Rough Idle xTourniquet Normally Aspirated Powertrain 8 07-28-2010 12:04 PM
Rough idle - cold start up txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-03-2010 11:09 PM
1996 legacy rough idle, tried everything I can find brian3676 Normally Aspirated Powertrain 6 09-30-2008 04:57 PM
96 Legacy 2.2 hot start issues b1pig Normally Aspirated Powertrain 0 06-28-2006 08:41 PM
Shaking/Roughness on slow starts? proletariandan Newbies & FAQs 4 07-31-2005 12:50 PM
