Old 06-17-2002, 02:30 PM   #1
luvmyrs
Member#: 1048
2000 Nothing, thanks
to POS thieves.
Default need help w/ TGV on a 02 WRX Motor
Has anyone unhooked the Tumble Generator Valve on their WRX? If so, did it cause the motor to miss and run rich at higher RPM's? The reason that the TGV's were unplugged was that im doing a motor swap into an RS and the stock ECU is not being used. Also, when you unplug the TGV. Are they supposed to be open or closed?
thanks in advance,
Yu-Pong Lam
luvmyrs is offline   Reply With Quote
Old 06-17-2002, 02:53 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
if you can, take the manfold off and remove the TGV plates...
always closed = bad
Old 06-17-2002, 02:58 PM   #3
luvmyrs
Member#: 1048
to POS thieves.
one more question. Are the valves open or closed when theyre unplugged?
Old 06-17-2002, 03:43 PM   #4
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Unhappy TGV unplugged
I've been told unplugged=closed....wouldn't do, would it? If the design is anything like a 32v 4.6l Cobra, you stand to lose a fair amount of bottom end by removing the plates in the TGV.....tumble is a good thing in certain cylinder heads.
n2xlr8n is offline   Reply With Quote
Old 06-17-2002, 03:55 PM   #5
luvmyrs
Member#: 1048
to POS thieves.
cool, thank you guys for the info.
Old 06-17-2002, 10:38 PM   #6
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Default Re: TGV unplugged
Does anyone know for sure which way those valves will go if you just unplug them? do they stay open or shut?? Thanks
alfriedesq is offline   Reply With Quote
Old 06-17-2002, 11:18 PM   #7
boogerwrx
Member#: 13448
2002 wrx wagon
they stay shut. when i turned the turbo for a fmic, it touched the sensor and bound the tgv. the cel came on and the code was for the tgv sensor-stuck closed. if you unplug them, the car should go into limp mode. ours did anyway. if you take them off, you will have to fool the computer with a resistor, but this may not work since there is a full open and full closed value. your only option may be to port your existing tgv housings.
boogerwrx is offline   Reply With Quote
Old 06-18-2002, 01:06 AM   #8
scooby
Member#: 13085
i've taken one off before and i regretted it, it is pre-sprung so you will have to wind it up then put it on. my car ran filthy rich and would bogg as soon as i hit the gas even slightly hard.
scooby is offline   Reply With Quote
Old 06-18-2002, 02:14 AM   #9
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Sounds like we hit the problem eh ???? Damm things !
Need help. Enkei J10 on my 06 wrx thesunnyboi Tire & Wheel 1 02-18-2008 08:03 PM
Need TGV delete for 02 wrx gotti Private 'Wanted' Classifieds 0 09-20-2006 04:53 PM
alaram keeps on goin off, need help on my 02 wrx twofast4u Car Audio, Video & Security 1 05-19-2006 01:18 PM
need help!! What wheels on DMB GC8 wrx?? z3gga Member's Car Gallery 15 11-18-2004 05:15 AM
Need help with swap plans... those with WRX motor in GC body please comment Subasaurus Rex Subaru Conversions 51 01-20-2004 05:53 PM
