Old 07-21-2010, 09:48 AM   #1
Jerry_NJ
Member#: 233288
2004 Forester
Default Torque Wheel Lug Nuts - Impact Wrench
I have a 2004 Subaru Forester, stock all the way.
I have a new electric Impact Wrench, large metric sockets and torque extensions.
It is time to rotate the tires on my Forest and need to know:
1) Wheel lug nut torque
2) Can I use an impact (electric) wrench and torque limiting extension to install the lug nuts?
3) given the extensions are for a range, whatever extension I pick, it will at best give a +/- range around the objective torque. Any concerns here?
I'm don't know how much steel verses aluminum we have in the Forster wheels and lug receiver/mount.
The many many times I have mounted wheels over the last 50 years I just used a manual lug wrench and put the nuts on "good-and-tight". So the torque limiting impact wrench approach should be more accurate and safer.
Thanks
Jerry_NJ is offline   Reply With Quote
Old 07-21-2010, 09:49 AM   #2
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
66Lb/ft
'Gudntite' will probably be too much.
Old 07-21-2010, 10:23 AM   #3
leecea
Member#: 37359
2003 WRX
Torque is not a very accurate measure at the best of times, so a bit of +/- from the desired setting seems OK to me. I'm not sure about the torque stick and electric impact. I've read a lot of contradictory stuff about how much power you need from your wrench to make a torque stick work. If it was me, I'd want to check the settings with a torque wrench until I became confident that I could reproduce a decently accurate torque each time I used the stick.
leecea is offline   Reply With Quote
Old 07-21-2010, 11:12 AM   #4
Badler
Member#: 133597
Sure, use the impact to snug them up, but then go over them with a torque wrench. Like said above, "good and tight" is probably way to much.
Badler is offline   Reply With Quote
Old 07-21-2010, 11:25 AM   #5
Onemanparty
Member#: 220119
07 suabaru sty
65-70 ft-lbs, torque wrench is your best friend, screw the torque sticks their garbage..
Onemanparty is offline   Reply With Quote
Old 07-21-2010, 11:58 AM   #6
Jerry_NJ
Member#: 233288
2004 Forester
Thanks, I have a 1/2" (the good old USA size tool) that will take 65-70 ft-lbs, that's the number if I read correctly.
I will use the impact to remove, that doesn't require measuring any torque. Then I'll install the nuts with the torque wrench set at something less than 50 ft-lbs and then apply the manual torque wrench...this may also give me some idea/check on what the impact wrench delivered.
Old 07-21-2010, 01:57 PM   #7
remotehuman
Member#: 201995
2000 Forester
I always do 90 ft/lbs just to be sure.
remotehuman is offline   Reply With Quote
Old 07-21-2010, 02:13 PM   #8
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
80 is good for subies. not a big fan of torque sticks. always use the torque wrench no matter what. also technically supposed to go over again with the torque wrench after driving it.
bugeye829 is offline   Reply With Quote
Old 07-21-2010, 02:27 PM   #9
06AWD
Member#: 112843
2011 SWP STI Sedan
Speedline/RCE/Cobb
I think 72 ft. lbs. is the average. I only use a torque wrench.
06AWD is offline   Reply With Quote
Old 07-21-2010, 02:59 PM   #10
bzbuzz
Member#: 116052
2011 STI ( Sold )
i do 75 lbs check it regularly.
bzbuzz is offline   Reply With Quote
Old 07-21-2010, 03:17 PM   #11
904scooby
Member#: 151518
2005 18g'd WRX
CGM
do not use an impact wrench or gun, use a speed wrench and a torque wrench
65-72 is enough
I set mine at 76 and check them soon after
904scooby is offline   Reply With Quote
Old 07-21-2010, 03:34 PM   #12
Onemanparty
Member#: 220119
07 suabaru sty
Why no impact gun? Power tools are too fun not to use.
BTW speed wrenches are for engine competitions
Old 07-21-2010, 03:58 PM   #13
Jerry_NJ
Member#: 233288
2004 Forester
Thanks, I agree and view the electric impact wrench a "poor man's speed wrench".
I purchased it because I needed to pull a flywheel on a B&S Vanguard twin cylinder garden tractor engine. There were many suggestions on how to lock the piston travel so that one could apply enough torque to remove the single 30mm nut. I purchased an impact wrench, and "zip" off came the nut. I was very impressed both with the easy with which it broke the nut loose and the speed that it removed the nut. I like so much I purchased a set of torque limiting extension to reinstall the nut...so far so good, the tractor engine is still working. I was going to purchase an air driven impact wrench, but thought why? Plugging into 115vac (60 cycle in the USA) was a lot easier than cranking up my air compressor and running an air hose around. All tools are Harbor Freight Chinese "imitations" but good enough (except possibly for calibration things like the torque limiting extension...I'm not even sure how they work, but suppose they flex at a designed torque point, absorbing the energy from the torque wrench and limiting the torque that can be applied to the nut. This does leave unanswered: how many hits is enough, how many is too many. I assume each time the impact hits the nut tightens just a little more, even if the extension is in full flex).
Old 07-21-2010, 04:28 PM   #14
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Impact guns are for removing lug nuts, not installing them.
Overtorqued lugs are a huge cause of warped rotors.
Splinter is offline   Reply With Quote
Old 07-21-2010, 04:31 PM   #15
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
i torque mine at 80 ft/lbs. i've spoken to many mechanics and thats usually their preference, so i trust them.
I've overtorqued lugs on a really old car before and actually stripped the stud and that was not a fun experience.
DutchOven is offline   Reply With Quote
Old 07-21-2010, 04:55 PM   #16
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Torque settings are based on the studs themselves. If one coat of wax is good and you put on 10 more coats of wax, the car won't break because of it. If 75 foot pounds is good, then 90 is bad and using a breaker bar with your elbow is worse. Studs stretch if you go beyond recommended torque. Then they cross thread, then they break.
I use my impact to remove nuts and on a very, very low setting to put them on (like 30 foot pounds) and then use a torque wrench to torque them.
Old 07-21-2010, 04:58 PM   #17
remotehuman
Member#: 201995
2000 Forester
I gotta over tourque my 18 lugs.. just to stay safe
Old 07-21-2010, 05:48 PM   #18
Punk In Drublic
Member#: 232673
2015 wrx limited
dgm
Tight enough so this doesn't happen!
Punk In Drublic is offline   Reply With Quote
Old 07-21-2010, 06:29 PM   #19
cobra22nd
Member#: 168249
I do 70-80 and run them down with a MAC impact on low. Then I tap it one more time after it contacts the wheel, and hit it with the torque wrench. Don't hammer on it. Torque sticks will still turn if you wail on them, and most people do because they thing they won't turn. My impact only gets moved off of low if someone else uses it.
cobra22nd is offline   Reply With Quote
Old 07-21-2010, 06:56 PM   #20
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....I do the same.
Kean is offline   Reply With Quote
Old 07-22-2010, 10:18 PM   #21
DWUsSubaru
Member#: 220644
2004 WRX Wagon
I was under the impression Subaru wanted 87 on wrxs.. And that's what dus out and leswab do to me too..
No?
DWUsSubaru is offline   Reply With Quote
Old 07-23-2010, 10:16 AM   #22
Kean
Member#: 25187
'08 Foz Prem TGM
No?
....say wha....???
Old 07-23-2010, 08:53 PM   #23
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
YouTube- RX7 wheels fall off
IIRC, it wasn't improper torque, it was improper lug nut size/thread that caused this hilariously dangerous situation
dantastic is offline   Reply With Quote
Old 07-23-2010, 09:35 PM   #24
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I never put my lugs on with an impact before. Always a ratchet until seated, 35 ft/lbs while the wheel is in the air, then 70 ft/lbs once the wheel is on the ground. I put ARP Studs in the front, and it would take a day and a half to put the lugs on with a ratchet, so I use my battery impact until it seats, then the 35/75 ft/lbs sequence.
vision.dynamix is online now   Reply With Quote
Old 07-25-2010, 06:19 PM   #25
droppedOB
Member#: 251101
BSM
Ive made the mistake of letting my brother put my wheels back on, and he used the impact gun only. There was a mysterious clicking noise when i drove the car which i later found was because he only used the impact gun and didnt check the torque! My wheels almost fell off! it is extremely dangerous to do it that way. impact wrench them lightly and then hit them with a torque wrench to about 80 ft lbs
droppedOB is offline   Reply With Quote
Torque for lug nuts renorex Brakes, Steering & Suspension 4 06-04-2009 01:20 PM
Cross-treaded wheel lug nuts Marcin Mid West Subaru Owners Club Forum -- MWSOC 11 06-17-2002 12:00 PM
what should I torque my lug nuts to? Mauricio Texas Impreza Club Forum -- TXIC 15 05-21-2002 07:38 PM
Where to get P1 wheels lug nuts? bensonwrx Brakes, Steering & Suspension 11 08-20-2001 03:42 AM
Wheel lug nut torque specs?? Kyle Paton Technical Forum Archive 16 07-21-2000 11:44 AM
