Old 07-21-2010, 04:41 PM   #1
mazmac24
Member#: 240419
2004 WRX
World Rally Blue
Default 2004 WRX, 05 LGT Block + 05 STI head... need help
Ok so long story short, blew the engine in my 04 WRX.
So far I have a EJ255 05 LGT block and was looking at buying a very clean pair of 05 EJ257 STI heads for cheap.
My question, what am I getting myself into? I have been doing research on AVCS and I am scared and confused. First of all, would the ECU hook right up? The guy I bought the block from worked at a dealership, he said that I would be able to reflash the ECU. I was looking into it and a flash from a 06-07 WRX would be most compatible engine wise...
I'm looking for input, is it as easy as i think? Starting to think not.
mazmac24 is offline   Reply With Quote
Old 07-21-2010, 10:51 PM   #2
kaane
Member#: 74006
2005 9-2x
You cannot just flash your ecu. You will need complete wiring harness and ecu from a car with avcs or a stand alone ecu that you can wire avcs on your own. Either way it's not simple.
kaane is offline   Reply With Quote
Old 07-22-2010, 07:01 AM   #3
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
If you searched so hard why didn't you get half way down the page to the EJ25x swap guide?
domestic_abuser is offline   Reply With Quote
Old 07-22-2010, 11:53 AM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Ahahahahaa you so funny.
You don't have to run AVCS. Just leave the solenoids unplugged. It's not like it's going to not run. sheesh... people. Just install your intake manifold on it and go get a tune for the different loads and such to match your setup.
FuJi K is online now   Reply With Quote
WRX block & STI heads John Vanos Subaru Conversions 2 12-13-2005 11:14 AM
05 lgt vs 05 wrx wrxpunk53 General Community 24 04-05-2005 02:54 PM
Valve Stem Height Specs needed on STI heads - any help ? Dyno Flash Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-09-2004 07:57 PM
Wanted STI// WRX BOV 04-05/Also rubber gasket under splitter-need help on item-see ad MITZA Private 'Wanted' Classifieds 2 06-19-2004 01:52 PM
2.5 block with STI heads & internals KYScuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-01-2003 11:34 PM
