Vancouver Impreza Club
Old 07-21-2010, 08:28 PM   #1
J-Chow
Member#: 104722
2006 2.5i - SOLD
Gray
Question OT: Having few issues with starting vehicle
So this is totally OT, but it happens to me once in awhile (about once a month).
Basically and very randomly, when I attempt to start my suby (5 speed manual), you need to depress the clutch and then turn the key to start the car (duh)
But. . . . sometimes when I do that, the car doesn't start, there is no crank, and nothing happens. I know that there is a positive electrical connection because everytime I attempt to turn the key to start position, the radio lights and gauge instrumental lights would turn on and off.
I've tried taking out the key, and re-inserting the key and repeating the steps to start the car, but nothing happens.
Like for today example, I was stuck at the airport parking lot for 2-5 minutes trying to start the car, and after inserting the key a few times, depressing the clutch a few times, I finally had a spark and it cranked.
So i'm trying to figure out what issues or problems I should look for. The plugs, ignition coil pack, and plug wires were replaced at about 10-15,xxxkm ago.
The battery has yet to be replaced ever since I bought car, and so has the alternator. Timing belt and other maintanence items are due, as I've reached 100,000km.
Anyone experience this crazy wacked out situation ?
What say you?
J-Chow is offline   Reply With Quote
Old 07-21-2010, 10:37 PM   #2
rs420
the cone killer
Member#: 157784
02 swapped bugeye
anthricite
Maybe the clutch cancel switch is loose. next time it happens, get down there and wiggle it & the wiring to the switch. if it starts, that might be your problem...
rs420 is offline   Reply With Quote
Old 07-21-2010, 11:24 PM   #3
sixthgear
Member#: 127691
11 VW CC
97 del sol dohc vtec
I just hit 100,000km a couple months ago. No need to replace battery, alternator or timing belt. DD told me it's good till 130,000(iirc)
sixthgear is offline   Reply With Quote
Old 07-21-2010, 11:47 PM   #4
bender
Member#: 1839
could be a electrical problem, but it's most likely that your starter is going bye bye.
bender is offline   Reply With Quote
Old 07-21-2010, 11:48 PM   #5
rs420
the cone killer
Member#: 157784
02 swapped bugeye
anthricite
are there contacts you can replace in a subaru starter?
Old 07-23-2010, 01:52 AM   #6
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Check your grounds?
minifreak is offline   Reply With Quote
Old 07-23-2010, 02:12 AM   #7
alexinvancouver
Member#: 251482
2007 WRX
1990 all-trac, 08 EVO
as rs420 said most likely the switch
to check starter make sure she's in neutral and short starter relay contacts.
it should crank every time
but even if it doesn't no need to replace starter,
usually removing starter and cleaning relay contacts takes care of the problem
alexinvancouver is offline   Reply With Quote
Old 07-23-2010, 03:33 AM   #8
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
sounds like a bad connection somewhere.....have u modified any wiring? removed anything lately?
and this thread isn't OT at all.....
Jeff54 is offline   Reply With Quote
Old 07-23-2010, 03:33 AM   #9
Subaru_Salesman
Member#: 241382
Could be starter...needs rebuild. Ignition switch might have a chance too...
Subaru_Salesman is offline   Reply With Quote
Old 07-23-2010, 09:09 AM   #10
mixdnuts
Member#: 147357
1997 JDM Fozzie S/Tb
Sounds like bad starter relay contacts. You battery sounds fine.
"I finally had a spark and it cranked"
Remember it needs to crank before it sparks. Subaru calls it the Magnet switch Assy and it does not look servicable, but you might be able to replace it.
mixdnuts is offline   Reply With Quote
Old 07-27-2010, 06:52 PM   #11
ralli-tart
Member#: 106125
06 OZ aw wagon
air filter for engine? my gas mileage shot up at least 100km because i havent replaced my air filter in like....forever.
ralli-tart is offline   Reply With Quote
Old 07-27-2010, 09:47 PM   #12
iht
Member#: 196742
2000 Impreza 2.5rs
have you tried to re-bleed your clutch cable with new fluid?
with the stock tranny and clutch and parked on a slope, i used to have that problem. used to have to pump the clutch pedal a little then it would start up.
iht is offline   Reply With Quote
Old 07-28-2010, 12:23 AM   #13
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Originally Posted by minifreak View Post
Check your grounds?
+1 on that most electrical issue's are bad grounds, also clean your battery post's, use electrical lube, on them and the yellow protectant spray. You can also check the connections on the starter, but if the lights are dimming turning off on sounds like a connection lose or toasted battery..
dasnowman is offline   Reply With Quote
Old 07-28-2010, 12:46 AM   #14
ALees
Member#: 201393
1995 impreza
check your grounds first, then battery, neutral safety switch and starter if it`s not a bad ground or battery
ALees is offline   Reply With Quote
Old 07-28-2010, 01:04 AM   #15
J-Chow
Member#: 104722
2006 2.5i - SOLD
Gray
top notch advice peeps. I'm bringing my car to my mechanic for an oil change and i'll check the above issues asap! thanks!
Issues with starting car schweezly Newbies & FAQs 4 12-02-2008 01:39 AM
Having an issue with the GF, how to deal with it. MattSEG Off-Topic 100 02-15-2007 04:36 PM
having a few issues with the TVs NLspiked02 Car Audio, Video & Security 11 12-27-2006 07:14 PM
Serious issues with starting the car NimrodBoz Normally Aspirated Powertrain 4 12-11-2006 09:44 PM
OT: Known billing issue with Verizon VCAST WRXtranceformed Mid Atlantic Impreza Club -- MAIC 10 02-21-2006 07:29 PM
