Old 07-22-2010, 02:50 AM   #1
wrx0001
Member#: 99887
2002 tbxs stg 3 wrx
black
Default No power at low RPMs Help Please.
I have a 97 legacy outback with a 2.5l and automatic transmission. It has 172,000 on it. it has always ran fine until a few weeks ago. When I try to accelerate from a stop or low speed the vehicle seems very sluggish. It feels almost like its bogging down, However once I get passed 3000 RPM it pulls like it always has. I have no CEL showing. Any Ideas? Could it be a bad knock sensor with out throwing a code? Thanks for any help in advance
wrx0001 is offline   Reply With Quote
Old 07-22-2010, 10:04 AM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
what normal maintenance has been done recently? How's the fuel economy? I kinda doubt it would be a bad knock sensor w/o a code, but it could be a bad oxygen sensor going out w/o a code. Try an ECU reset and see if that does anything. report back.
yarrgh is online now   Reply With Quote
Old 07-22-2010, 01:01 PM   #3
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
air filter and cleaning maf if you havent yet
kewlboxer2 is offline   Reply With Quote
Old 07-22-2010, 10:45 PM   #4
wrx0001
Member#: 99887
2002 tbxs stg 3 wrx
black
Thanks for the input guys. It was the knock sensor. I pulled it and could instantly see the crack. Not sure why it didn't trip the CEL though. I replaced it and its back to normal. I haven't owned the car for very long. I am planning on doing plugs, wires and air filter. Anything else I should replace while I'm at it? Timing belt has about 50,000 on it so it should still be good.
Power assist cuts out at low RPMs ('05 STi) case Brakes, Steering & Suspension 2 02-22-2008 10:49 AM
Car bogging at low RPM's help please Troll Boy Service & Maintenance 9 08-22-2007 08:40 PM
Misfire at low rpm, help farulz1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-02-2006 04:41 PM
Help! Sti Stalling at low RPM (sorry, long) BlackWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 36 11-23-2004 07:40 PM
any ideas why the power steering would give up at low rpm? Bart Service & Maintenance 9 01-14-2003 05:15 PM
