Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 07-22-2010, 03:55 PM   #1
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Default Mom's Legacy is overheating
My mom's 2000 legacy outback is overheating when she drives up hills. I'm kind of at a loss as to what it could be. No CEL's. She says it's not burning coolant. She also says that there isn't any air in the radiator cap. She also said that she recently had her A/C system serviced (but didn't know the extent of the service. Could there be air trapped in the system? Should she try and burp the system somehow? What are some other issues that could be causing this problem?
Not-EWRX is offline   Reply With Quote
Old 07-22-2010, 03:58 PM   #2
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
I would put the front wheels on jack stands, start it up, turn on the heater and rev it up to 2 grand once the engine is up to operating temp, and see if any air bubbles come out, then top it off and wham. done hopefully
06HAWKMAN is offline   Reply With Quote
Old 07-22-2010, 04:16 PM   #3
Not-EWRX
Member#: 158043
2013 Wrx Hatch
So lifting the front helps get the air out? Is it feasible that a little amount of air can make it overheat like that?
Old 07-22-2010, 05:06 PM   #4
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Blown head gasket, bad radiator cap, bad thermostat also check and see if the fans are even turning on..
Just some things to look into.
bhhamblin is offline   Reply With Quote
Old 07-22-2010, 05:12 PM   #5
SkiWrex
Member#: 142559
05 Fozz XT VF39'd
05 PSM Fozz 2.5xs
+1
My brother's 2001 outback was having the same symptoms, It was his head gasket and water pump.
SkiWrex is offline   Reply With Quote
Old 07-22-2010, 05:27 PM   #6
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Probably headgasket.
Has it had the coolant conditioner?
DLC is offline   Reply With Quote
Old 07-23-2010, 07:15 PM   #7
phattydrummer
Member#: 183070
2003 WRX
True Blue
Sniff the coolant in the coolant overflow bottle. Its very common that exhaust gets in the coolant (blown head gaskets) which will cause overheating, especially on heavy loads.
Also, if its really bad, you can get the car up to temp and pop the lid on the reservoir bottle. Put the car in park/neutral and manually rev the motor while looking into the overflow bottle. If you see little bubbles come up out of the coolant, you have bad head gaskets.
It is very common for those 2.5L non turbo head gaskets to go out. Here at our shop, we see several Subarus a month with this very problem. I am doing head gaskets on one right now!
phattydrummer is offline   Reply With Quote
Old 07-23-2010, 08:28 PM   #8
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
If she did just have the AC serviced, perhaps something is making it so that both fans don't kick on when the AC is turned on. Check that first.
My STI is overheating when the AC is on and the AC fan doesnt work, why overheating? nicksamba_18 Service & Maintenance 1 03-09-2015 09:55 PM
My STI is overheating when the AC is on and the AC fan doesnt work, why overheating? nicksamba_18 Off-Topic 9 08-21-2009 07:37 PM
My mom's Car is fastAr than mine WagonMonster Off-Topic 58 05-18-2005 11:18 PM
took my mom's legacy out RSimport Mid Atlantic Impreza Club -- MAIC 23 02-17-2003 03:22 PM
('93-'01) So i took my Mom's Legacy out for a spin.......and almost.............. FuJi K Impreza Forum 42 06-01-2001 02:15 PM
