Old 07-20-2010, 12:38 AM   #1
ytirrag
Member#: 250647
1995 Impreza Outback
Black GF4
Default Cold Air intake
i was curious to know if there were any cold air intakes that would fit my 1995 impreza 2.2 litre, because ive been asking around and looking everywhere and havnt found anything. So if i could get some help that would be great thanks.
ytirrag is offline   Reply With Quote
Old 07-20-2010, 11:00 AM   #2
Lord Grippington
Member#: 179989
2006 2.5i Sedan
Steel Gray Metallic
Did you try the search function in the NA forums? That'll get you results, look for pictures that may help you, and look on Ebay. You can probably get the pieces for it pretty cheap.
Lord Grippington is offline   Reply With Quote
Old 07-20-2010, 07:42 PM   #3
Strickly_Imprezter
Member#: 252447
1995 L AWD 2.2L
Red
Well I don't know how much you wanna spend but they have some at www.andysautosport.com and you could probably also try www.nopionline.com maybe www.summitracing.com too
Strickly_Imprezter is offline   Reply With Quote
Old 07-21-2010, 12:44 AM   #4
ytirrag
Member#: 250647
Black GF4
i cant find anything on na forumss, but i found some bootleg kits on ebay but i dont know how those will be lol
Old 07-21-2010, 01:26 AM   #5
flightwatch
Member#: 231058
2015 F-150
http://lmgtfy.com/?q=1995+impreza+cold+air+intakes
Also by just typing in "cold air intake" in the "search this forum" spot on the top right of this page, I got 20 pages of threads pertaining to cold air intakes.
Just helping you out
flightwatch is offline   Reply With Quote
Old 07-21-2010, 12:02 PM   #6
SubyRS03
Member#: 245297
2004 WRX vf48 93 oct
Your better off going with a sri or hybrid!!
SubyRS03 is offline   Reply With Quote
Old 07-21-2010, 08:03 PM   #7
ytirrag
Member#: 250647
Black GF4
i know how to search dude, but i am saying there is nothing that fits my car. and trust me i have googled it too, ive spent hours and hours myself. I look first then ask.
Old 07-21-2010, 08:07 PM   #8
ytirrag
Member#: 250647
Black GF4
why???
Old 07-21-2010, 08:17 PM   #9
subiman2005
Member#: 151686
2004 GTP Comp G
99 Legacy Sold
subiman2005 is offline   Reply With Quote
Old 07-21-2010, 08:25 PM   #10
ytirrag
Member#: 250647
Black GF4
Originally Posted by subiman2005 View Post
YESS! finally thank you soo much, thats exactly what i am looking for, how does it perform on your car, does it have the 7 hp gain like the site says?
Old 07-21-2010, 08:41 PM   #11
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Whoa, before you go spending $140 on a colorful pipe, try fitting on a cone filter first. I have done this to 3 of my 1993 Legacys, and it works just fine. Take the stock airbox off, cut off the screen part of the MAF in the front, and just fit a cone on to the MAF. It has worked fine on my subies and only costs $20.
Nice, easy, cheap.
Jessekrs123 is offline   Reply With Quote
Old 07-21-2010, 08:54 PM   #12
subiman2005
Member#: 151686
2004 GTP Comp G
99 Legacy Sold
I don't know exact gains but my butt dyno deff says it has more power mainly top end...and yes you can do the $20 intake its all personal pref I had the money so I went with the shiny blue intake lol
Old 07-21-2010, 10:39 PM   #13
cmiovino
Member#: 134005
2004 WRX Premium
Ehhhhh, hybrid or stock IMO... if you're stating with the stock ECU tune. Cone filters in general mess up airflow with the MAF... even the AEM velocity stack ones.
Old 07-21-2010, 11:19 PM   #14
ytirrag
Member#: 250647
Black GF4
Nice, easy, cheap.
i already have a k&n filter, and i want more hp lol, ik it sounds like what everyone wants these days, and ik most people would just say get a new car but i dont want a new car, and how did u get that red, not the cone, the pipes.
Old 07-22-2010, 12:05 AM   #15
Jessekrs123
Member#: 236927
1984 BRAT
^^^ Yea but aftermarket piping won't really add any more horsepower than if you just put a cone on the end. If you have a flat K&N filter in your airbox, eliminate the airbox and get a cone. With my FWD legacy sedan, I saw a good increase in throttle response and a lot more power in the top end. My intake manifold is red because I painted it while I was rebuilding the engine. Not wrinkle red like I wanted, but I did not want to wait 5 days for shipping for the paint because the motor was ready to be dropped in, and I wanted to drive it. It's pretty simple job, take off the coil pack, plugs, fuel, vacuum, PCV and coolant hoses, coolant temp sensor, injectors, IACV, throttle body & cables and whatever else is attached to it. There are 8 bolts I believe (4 on each side), take those off, pull the IM out. Take off the fuel lines (pain in the a$$, I should have made braided fuel lines while I had this out) Cover up the intake ports on the engine so nothing gets in them. Find some red paint, lay on 2 or 3 even layers (Tape off all the openings and bolt threads, there are A LOT of them) GET NEW GASKETS, anytime you take something apart with gaskets, get new ones. Also, while you have the IM out, clean the inside & the runners, mine were very dirty. Brake parts cleaner works really well, just spray the crap out of it. Once everything is painted, throw it all back together and voila. ---NOTE--- If you do end up cleaning the inside of your IM and painting it, when you put everything back together and go to start your car, DO NOT BE AFRAID if there is tons of white smoke pouring out of your exhaust, it is just the remaining cleaning product being burnt off. Just let it idle until it burns it all off.
Old 07-22-2010, 12:28 AM   #16
ytirrag
Member#: 250647
Black GF4
^^^ Yea but aftermarket piping won't really add any more horsepower than if you just put a cone on the end. If you have a flat K&N filter in your airbox, eliminate the airbox and get a cone. With my FWD legacy sedan, I saw a good increase in throttle response and a lot more power in the top end. My intake manifold is red because I painted it while I was rebuilding the engine. Not wrinkle red like I wanted, but I did not want to wait 5 days for shipping for the paint because the motor was ready to be dropped in, and I wanted to drive it. It's pretty simple job, take off the coil pack, plugs, fuel, vacuum, PCV and coolant hoses, coolant temp sensor, injectors, IACV, throttle body & cables and whatever else is attached to it. There are 8 bolts I believe (4 on each side), take those off, pull the IM out. Take off the fuel lines (pain in the a$$, I should have made braided fuel lines while I had this out) Cover up the intake ports on the engine so nothing gets in them. Find some red paint, lay on 2 or 3 even layers (Tape off all the openings and bolt threads, there are A LOT of them) GET NEW GASKETS, anytime you take something apart with gaskets, get new ones. Also, while you have the IM out, clean the inside & the runners, mine were very dirty. Brake parts cleaner works really well, just spray the crap out of it. Once everything is painted, throw it all back together and voila. ---NOTE--- If you do end up cleaning the inside of your IM, when you put everything back together and go to start your car, DO NOT BE AFRAID if there is tons of white smoke pouring out of your exhaust, it is just the remaining cleaning product being burnt off.
cool, and i do have a cone, i have a k&n cone filter, hmm, so could i just buy any piping and put it in place of thhe rubber intake? an i think im gonna paint my im blue itll look sweet i hope
Old 07-22-2010, 01:06 AM   #17
medic14
Member#: 197419
2000 2.5RS
BRP
You really aren't going to be able to pull that much more hp off an intake. You might want to look into headers and exhaust...
medic14 is offline   Reply With Quote
Old 07-22-2010, 11:22 AM   #18
Jessekrs123
Member#: 236927
1984 BRAT
^^^^ like I said before, getting an aftermarket intake pipe will not give you any more horsepower, so spending $130 on a colorful pipe is pointless and is a waste of money. Like medic said, if you want more power, look into an exhaust system, and possibly some N/A tuning. Other than that, the only way to get a really good increase of power out of you N/A car can only be done with some type of forced induction, or getting better cams.
Old 07-22-2010, 11:35 AM   #19
ytirrag
Member#: 250647
Black GF4
i only have a muffler as of now, should i get all the piping for an exhaust is it worth it?, also what headers would you suggest? I don't know too much bout headers
Old 07-22-2010, 11:37 AM   #20
ytirrag
Member#: 250647
Black GF4
haha i know you were talking about the colorful pipe, but wut if i buy like a pipe from homedepot or sumtin (hypothetically) could i make that an intake pipe and have it perform the same as the rubber one that i have now? If the pipes do nothing than id be willing to spend like 10 bucks on a pipe that looks better but does nothing...if that makes sense haha
Old 07-22-2010, 11:41 AM   #21
Jessekrs123
Member#: 236927
1984 BRAT
Yes, I had an intake pipe on my old wagon that I got from home depot. Get a straight pipe and an angled pipe. Find some intake couplers, put it all together and there you go.
Old 07-22-2010, 11:53 AM   #22
ytirrag
Member#: 250647
Black GF4
and it works good? just the same...no losses?
Old 07-22-2010, 07:13 PM   #23
subiman2005
Member#: 151686
2004 GTP Comp G
99 Legacy Sold
Yeah making a intake is way cheaper takes a little know how and some time but easily done...to bad you didn't have a newer car like my 99 no maf to deal with at all...but yeah you can get a maf adaptor some tubing couple adaptors and should turn out real nice or buy one whatever makes you more happy...and yes deff do headers
Old 07-22-2010, 08:40 PM   #24
ytirrag
Member#: 250647
Black GF4
any type of piping in particular?, and what headers do you suggest?
Old 07-23-2010, 01:42 AM   #25
VIsubi
Member#: 187834
06 2.5i impreza
Red
Injen CAi,with accessport tune and axle back exhaust and yes there are gains..mostly in the mid to top end than bottom. Also better gas mileage since your engine now doesn't use more fuel to sub for less air..great add on to get better gas mileage if anything and top end power. With tune at least a 10hp gain.
I'm also going Supercharged in a month so gona use the CAI with the centrifugal SC which should help with cooler intake temps aswell as dense air into intake manifold.
VIsubi is offline   Reply With Quote
Hot Air Intake VS Cold Air intake.Poll & Discussion arfrce Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 73 09-01-2008 10:35 PM
WTB: 02/03 WRX stock air intake or trade for Injen cold air intake limpstick VIC Private Classifieds 17 02-16-2007 01:46 AM
Opinions on cold-air intake or no cold-air? gldenchld Tri-State Area Forum 7 11-06-2002 07:55 PM
ram air intake vs cold air intake Shaji Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 62 07-21-2002 09:05 PM
AEM cold air intake or Injen cold air intake? energy57 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 05-20-2002 12:27 AM
