Old 06-17-2002, 07:21 PM   #1
tsbarro
Member#: 18358
02 WRX Wagon
Midnight black pearl
Default How bad is it to drop a bolt in the engine?!
Well, I was attaching the last wire of my grounding mod - the one that goes to the passenger side engine manifod... and sure enough I dropped the dam bolt in the engine!! Its LOST! nowhere to be found, and I looked for a long time.. It made 2 clinks against metal and then stopped somwhere. I'm not about to start unbolting all sorts of stuff to find it.. I used another bolt to secure the wire, but how bad is it now to have this bolt floating around??? From where I dropped it, I don't think its really in harms way of the belts/fans, but I'm not sure!
And please, no replies that just say 'your screwed'
Ts
(I started the car and drove it w/ no problems.. I also made some hard stops from forward and reverse trying to make it drop, but no luck)
tsbarro is offline   Reply With Quote
Old 06-17-2002, 07:30 PM   #2
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Thumbs up
You just dropped it in the engine compartment, and not inside the engine, right? If it's just in the engine compartment, it shouldn't be a problem; heck, it probably fell out on your drive home. I've done the same thing on several of my cars, and it's never been a problem, unless I didn't have a replacement for the bolt I dropped. Now, if you somehow dropped it inside of the block or heads, that's bad, but sounds like you didn't have the engine taken apart or anything, so don't sweat it.
HondaH8er is offline   Reply With Quote
Old 06-17-2002, 08:24 PM   #3
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
i would say it fell out, but next time have a magnet with you or somthing that can get bolts when they fall(get a magnetic tool tray thing to, those kick ass)
YaZahX is offline   Reply With Quote
Old 06-18-2002, 08:41 AM   #4
Code-7
Member#: 5077
'97 e39 540i6
Take off your intercooler and look. Will take ten minutes and you just may find it.
Code-7 is offline   Reply With Quote
Old 06-18-2002, 09:30 AM   #5
Sam2
Member#: 15265
2002 WRX Wagon
WR Blue
I swear the wrx has more bolt/screw/nut/socket-catching nooks and crannies than anything else I've ever worked on! I don't think I have evr just dropped something and have it clink and clank its way all the way to the ground. Sorta eerie the way it sucks up small parts.
Sam2 is offline   Reply With Quote
Old 06-18-2002, 09:44 AM   #6
mynew02
Member#: 13726
2002 WRX - 264 AWHP
ION-Turbo&LINK [email protected]
so true...
mynew02 is offline   Reply With Quote
Old 06-18-2002, 11:10 AM   #7
BOP
Member#: 8681
Post
this is pointless
BOP is offline   Reply With Quote
Old 06-18-2002, 12:30 PM   #8
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
Originally posted by BOP
On the 3G Eclipse board, there once was a guy who somehow managed to drop a nut into a cylinder while changing sparkplugs. He was intelligent enough to say "ah, screw it", put everything back together and start the engine. You can guess what happened next.
the car ran fine and he lived happily ever after
i droped a bolt into a sunfire intake at school, i get my trusty magnet and i get that and i pulled out a part of the PCV system
Old 06-18-2002, 01:02 PM   #9
codean
Member#: 10186
I lost the small nut that holds the clamp to join the two parts of the turbo together. Two weeks later I pulled off the IC to install a knock link and found the nut sitting on a ledge under the cruise control unit. Poor little guy didn't want to let go of my car.
codean is offline   Reply With Quote
Old 06-18-2002, 01:06 PM   #10
EdsWRX
Member#: 13881
08 spec b
07 335xi
Default Whats the worse that could happen?
Check out the last two pictures on AdamsRS's Site
Ouch
http://homepage.mac.com/adamsrs/PhotoAlbum15.html
EdsWRX is offline   Reply With Quote
Old 06-18-2002, 01:18 PM   #11
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Talking
I had a spark plug fall and get wedged under a shock absorber near the crossmember. It made my entire car virbrate at idle. It took me an hour to knock the little bastard out of there. That's probably the worst that could happen unless of course you like a free massage.
seven881 is offline   Reply With Quote
Old 06-18-2002, 02:02 PM   #12
touch
Member#: 12678
i thought if you drop a screw in the cylinder it would just shoot out the tailpipe!
touch is offline   Reply With Quote
Old 06-18-2002, 02:26 PM   #13
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
When I first saw the title of this thread I was a little worried. I thought you actually dropped a bolt into the ENGINE itself. That would be very bad. Engine compartment is no big deal, I've lost all kinds of crap under the hood of my rex. Some pliers, a socket, a bolt... No big deal, you'll find it eventually.
kenshiro is offline   Reply With Quote
Old 06-18-2002, 03:03 PM   #14
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
Yeah, this is what it looks like when that (in this case, a bunch of BBs) happens:
For the full story, click Here
Coati is offline   Reply With Quote
Old 06-18-2002, 08:04 PM   #15
HellWagon
Member#: 16172
I count how many times I have heard freinds talking about working on their old muscle cars. Putting the air filter nut on the carb for some reason. Then deciding to test fire the car without the air filter on. The secondaries would open and then "kthunk". So weird I have heard this story from multiple people.
HellWagon is offline   Reply With Quote
Old 06-19-2002, 12:23 PM   #16
spanner
Member#: 18791
2002 WRX wagon
Silver!
My wagon came from the factory that way...
I had to remove the grille when I installed my Supertones and found an extra clip just sitting there. The little bugger was in there for over 700 miles...
spanner is offline   Reply With Quote
Old 06-23-2002, 10:42 PM   #17
portablevcb
Member#: 7979
I had a Jeep Cherokee I "lost" a screw in. (no, not inside the intake). Everythong was fine so I forgot about it. Ona trip I heard a very loud screeching noise. The little bugger had worked its way down between the crank pully and the block.
Freaky, but still did no damage (except to the bolt). My nerves were sure shot after that.
portablevcb is offline   Reply With Quote
Fender Liners totally trashed... =( how bad is it to run like this in MD? Psybin Mid Atlantic Impreza Club -- MAIC 30 11-19-2009 11:19 PM
How bad is it to use 80w-90 in cold climates?? WRXSleeper Transmission (AT/MT) & Driveline 10 01-27-2006 12:10 PM
how bad is it to have ear buds in all day at work? maaw Off-Topic 4 11-08-2005 08:08 PM
How bad is it to move with the parking brake?? mike270 Normally Aspirated Powertrain 2 09-15-2002 12:19 AM
How bad is it to leave out the exhaust manifold heat shields? Blue02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-10-2002 11:30 PM
