Old 06-17-2002, 08:47 PM   #1
adamsrs
Member#: 3768
Angry Pictures of my SCREWED up piston!
and with the screw!!!:
For all of you that dont know here is the screw that i dropped into the intake port without knowing...!!! SUX! ANyhow...Im dumb!
adamsrs
adamsrs is offline   Reply With Quote
Old 06-17-2002, 08:53 PM   #2
Dave99
Member#: 6743
Ouch!!!
That bites!
Well, I suppose you'll have to change all of your pistons and re-bore your engine and probably change the connector rods. Well, I suppose an AVCS valve-train wouldn't be so bad.
Hmmm.
Maybe you should just buy a used STI engine!
Dave99 is offline   Reply With Quote
Old 06-17-2002, 09:54 PM   #3
STiTuner
Member#: 5778
09 135i
Jet Black
I've seen worse
Brad
STiTuner is offline   Reply With Quote
Old 06-17-2002, 10:02 PM   #4
adamsrs
Member#: 3768
Ummmm, guys i have already bought a new motor EJ22t block w/ EJ25 SOHC heads.....
adamsrs
Old 06-18-2002, 05:32 PM   #5
SubaSonic
Member#: 11365
02 N/A, A/T Wagon
Sedona Red Pearl
Default rEd
Nice looking intake manifold (engine bay)
SubaSonic is offline   Reply With Quote
Old 06-18-2002, 06:34 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
What is that screw from?
Old 06-18-2002, 11:33 PM   #7
adamsrs
Member#: 3768
The screw is from a Fuel Hose clamp that shook loose whil my manifold was off.
adamsrs
Old 06-19-2002, 12:04 AM   #8
Aphex
Member#: 146
'16 WRX Limited
a good testament as to why all open engine orifices should be blocked off when working on the engine, shop rags should do the trick just fine.
waiting for a job and second car so I can start some engine work
good lookin buildup though adam
Aphex is offline   Reply With Quote
Old 06-19-2002, 12:09 AM   #9
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Wich type of paint did you use the the intake manifold! I am trying to copy the sti style but so far I have not been able to do that!! but yours looks very, very close!!
DJIMPREZA is offline   Reply With Quote
Old 06-19-2002, 12:24 AM   #10
Gerry
Member#: 1829
DJ..you can have it powder coated with the wrinkle finish.It's tough as nails and holds up to alot of abuse...Gerry
Gerry is offline   Reply With Quote
Old 06-19-2002, 12:41 AM   #11
adamsrs
Member#: 3768
What Gerry said!
adamsrs
Old 06-19-2002, 03:18 AM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
yeah unless you pull a bone head move like one of the guys at my work did and leave the damn rags in the cylinders when ya put the head back on ....OOOOOPSSSSSSSSSSIIIIIIIIEEEEEEEEEEEEEEE bent all 4 rods...that was a costy mistake.
jeremy
Old 06-19-2002, 03:29 AM   #13
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
jeremy
Reminds me of a pic I saw in Chevy High Performance some years back of a shop rag halfway sticking out of the exhaust port because someone forgot about it. I've been looking everywhere but can;t find it
Eric
Eric SS is offline   Reply With Quote
Old 06-19-2002, 11:31 AM   #14
kapnk
Member#: 4890
2001 Impreza RS
rookie move!!
in my 20+ years of amateur wrenching, nothing like this has ever happened to me(knock on wood). but i have unnecessarily pulled heads, etc. back off because i thought i dropped a bolt or forgot something. in fact more than a few times. my dad drilled into my head(literally. with a bosch hammer drill). cleanliness,cleanliness,cleanliness. torque, check,retorque. tape, tape, tape. screw it!(better oil retention)
kapnk is offline   Reply With Quote
Old 06-20-2002, 10:46 AM   #15
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
is this your secound motor? the EJ22T that you were having problems with? i remember saying something about leaving something in the manifold when you had your other problem..... or is this the EJ25?
hope its running well now...
HOK is offline   Reply With Quote
Old 06-20-2002, 04:53 PM   #16
JohnnyWRX
Member#: 18678
2002 WRX Wagon
WR Blue
Well this link should make you feel a little better.
BBs
JohnnyWRX is offline   Reply With Quote
Old 06-20-2002, 06:32 PM   #17
adamsrs
Member#: 3768
THis happened to my EJ25....not by new motor...
adamsrs
Old 07-03-2002, 10:58 PM   #18
adamsrs
Member#: 3768
BUMP!
adamsrs
pictures of my clutch and parts. hope it holds up. STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-22-2003 04:56 PM
Pictures of my pistons and rods. Just got them back from swain coatings STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 04-15-2003 12:41 AM
I finally got pictures of my car up! sbsnyder Newbies & FAQs 20 03-02-2001 09:05 AM
Pictures of my car are up. Andrew General Forum Archive 6 06-18-2000 11:19 PM
