Old 07-23-2010, 07:17 PM   #1
gianspi
Member#: 113006
'01 Suzuki Bandito
1200cc
Default Failed Emissions: "Catalytic converter code and oxygen sensor not ready".
Hello folks,
My '95 Legacy LS (140k mi) failed RI inspection because it failed the sniffer test (both at idle and at 2500rpm). I brought it back and had them test it via the OBDII port. The tech said it wouldn't pass that way either because of a:
"Catalytic converter code and oxygen sensor not ready code"
Do you think the spark plug defouler trick will work? Should I replace the o2 sensor downstream or need a whole new cat?
Thank you in advance for any help!
~GS
gianspi is offline   Reply With Quote
Old 07-23-2010, 09:58 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
You need to complete the readiness cycle by driving it more....then taking it back to get tested.
Jay
CEL and Oxygen Sensor Woes.... Reble_45 Normally Aspirated Powertrain 4 01-13-2009 05:53 PM
question for air fuel gauge and oxygen sensor scoobaru_wagon Electrical & Lighting 2 03-08-2005 03:28 PM
P0136 and oxygen sensor.. part number? SjYankee006 Normally Aspirated Powertrain 5 09-28-2004 03:19 PM
limp mode and oxygen sensor baldcherub Normally Aspirated Powertrain 2 12-07-2002 10:58 PM
Testing MAS and Oxygen Sensor? Dbigworm General Forum Archive 1 03-27-2001 06:19 PM
