Old 07-22-2010, 02:45 AM   #1
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
Default Does the CEL mean I am in Limp mode?
I own a 2000 2.5RS. I'm running catless and had my ECU reflashed at Crawford with the SRS-20. My CEL was coming on before and still is now. I'm certain it's the usual "Bad cat" code. Anyway's my question is, if the CEL is on am I running at less power or anything?? Am I in "Limp mode"?
Jay
Rallly2000 is offline   Reply With Quote
Old 07-22-2010, 03:13 AM   #2
connie808
Member#: 251735
2004 IMPREZA
CGM
Jay
How long has the code been on?? Just pull the code and ease your mind.
connie808 is offline   Reply With Quote
Old 07-22-2010, 03:39 AM   #3
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Do you have a boost gauge?
If it stays below 10 PSI, or less than .8 bar, than you are most likely in limp mode.
Jubert69 is offline   Reply With Quote
Old 07-22-2010, 04:19 AM   #4
flightwatch
Member#: 231058
2015 F-150
See...this is why the boosted guys need to stay out of the N/A forum. He has a 2000 2.5rs. I highly doubt he has boost gauge...much less a turbo.
Just because your cel is on doesn't mean you're in limp mode. It means just what it says...Check Engine. Trust me, if the ecu was in limp mode, you would know.
flightwatch is offline   Reply With Quote
Old 07-22-2010, 08:32 AM   #5
VIsubi
Member#: 187834
06 2.5i impreza
Red
Been an ******* much lately..geez the guy was just trying to help the man..who cares if he's boosted or not and that comment would likely serve and help someone that is boosted. Try having some coffee first thing instead of bashing ,flaming people. But nice comment none the less on CEL
VIsubi is offline   Reply With Quote
Old 07-22-2010, 08:45 AM   #6
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
Looking to see what forum we are in, Oh it is the Normally Aspirated Powertrain.
Now to the OP, check out what code you are getting most likely P0420
ask me how I know.
I have the same Crawford reflash but was getting this code way before that
dstan is offline   Reply With Quote
Old 07-22-2010, 08:48 AM   #7
starlightluvsu
Member#: 238682
07 BBLGUN STI
EJ207 V9 swapped
Jay
before this thread gets OT, did you have your car checked for the CEL code? with that code, u can usually look up what exactly is tripping the CEL.. I had mine turn on 2 days ago.. despite the fact that 4 of my subie friends told me it was prob just a sensor, and not to worry about it.. I got my code read, and it turns out that my turbo inlet was falling off. so good thing I got it checked out sooner than later.
If it ends up being a "bad cat" code, just go to a tuner/specialist and they can turn it off.
starlightluvsu is offline   Reply With Quote
Old 07-22-2010, 08:52 AM   #8
dstan
Member#: 120386
No they can't.
Old 07-22-2010, 11:15 AM   #9
flightwatch
Member#: 231058
2015 F-150
Being an ass has nothing to do with it, and I don't care if the turbo kids come into the N/A forum...But you don't see us n/a boys over in their forums answering their technical questions. There's a reason for that.
I think she is talking about a cat inefficiency code...not necessarily a true bad cat.
Old 07-22-2010, 12:33 PM   #10
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
lol thanks guy's
Old 07-22-2010, 01:39 PM   #11
vrusso
Member#: 207074
2015 STI
You know you're jealous
You may or may not be running in "limp mode" depends on the code. Get it read. Git it fixed. Good to go.
vrusso is offline   Reply With Quote
Old 07-22-2010, 04:00 PM   #12
starlightluvsu
Member#: 238682
07 BBLGUN STI
EJ207 V9 swapped
and thank u for acknowledging that I'm a girl
I said "bad cat" cuz that's what OP called it.
Old 07-22-2010, 06:51 PM   #13
dstan
Member#: 120386
LOL, I think
"2007 STi named Babee
WRB w/ pink flakes+wheels"
gave it away
Old 07-22-2010, 07:23 PM   #14
flightwatch
Member#: 231058
2015 F-150
You're welcome.
To further add to what I was saying earlier; If the ecu is running in limp mode, you wouldn't be able to rev very high. Your car would also be insanely slow since the ecu would pull all timing. Limp mode=limp car=limp...well you know. It's the ecu's last defense that is designed to "limp" your vehicle onto the side of the road before your engine blows. It is usually caused by either several consecutive miss-fires, or excessive knock...although it can be caused by several other things too...I just can't remember them all right now.
Old 07-22-2010, 07:40 PM   #15
dstan
Member#: 120386
You're welcome.
I am not 100% sure but the 2000 RS does not have "Limp Mode"
Old 07-23-2010, 12:30 AM   #16
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
If you look at his car it says RS (JDMSTI REP)...
Possibly it can have an STi drivetrain?? No? Not possible?
Old 07-23-2010, 12:34 AM   #17
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
ask me how I know.
NA Powertrain... 2.0L.... they are so far from each other.
Old 07-23-2010, 01:32 AM   #18
VIsubi
Member#: 187834
06 2.5i impreza
Red
Doesn't matter where all Subaru influenced...now if you had an EVO guy in here the nby all means bash him,don't bash someone thats trying to help a fellow Subby brother. Thats your alls problem and I see it more with the N/A crowd than with the turbo crowd...period. Secondly if you have your cat removed and a O2 bung installed your gona throw a code no matter what...why cause you have two of them and if the reading on the first O2 is the same as the second O2 then your cat (which the ECU thinks is there) isn't doing its job..best bet is to keep clearing codes...or get a high flow cat that still does its job. You probably worded the delete of the O2 trouble code wrong cause you can't just delete it like that lol you can how ever bypass it by any means.
Old 07-23-2010, 02:09 AM   #19
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
No STI drivetrain just yet. some day though
I reset the ECU finally after driving it with the CEL light on for about 1.5 months. I was able to rev right to 6500rpm with it on but now without the CEL it does seems much more responsive?? Weird
Old 07-23-2010, 02:15 AM   #20
flightwatch
Member#: 231058
2015 F-150
A 2.5 n/a and a turbo 2.0 are pretty far from each other...sorry. Irregardless, I wasn't trying to flame you.
Old 07-23-2010, 02:44 AM   #21
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
I meant in the forum section, Not the actual internals.
Old 07-23-2010, 08:58 AM   #22
dstan
Member#: 120386
Yes I know I have had both, OP said he had a SRS-20 Crawford Reflash which is what you do to a NA 2.5... Crawford does offer a SRS-30 which yield 5 to 10 more HP over the 15 to 20 HP the SRS-20 reflash does.
http://store.crawfordperformance.com/store/products/85
Old 07-23-2010, 04:00 PM   #23
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
dstan, I mean, look at the nasioc techical section, the factory 2.0L powertrain is right below the N/A. That's what got me
Old 07-23-2010, 04:21 PM   #24
dstan
Member#: 120386
that is true
I didn't know what you meant
Old 07-23-2010, 09:03 PM   #25
Storm
Member#: 5218
96L Most Over-
Developed Beater
If the car is in Limp Mode, it won't rev past 3500-4000 rpm and it was probably precluded by a FLASHING CEL.
This could be as simple as the MAP sensor not being plugged in or the VSS not working, or it's not in limp mode and the OP should stop at any discount auto parts store and have the codes read for free....it's too easy to diagnose this crap nowadays....help yourself a little bit.
Jay
need help. im in limp mode! drifterx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-04-2003 04:17 PM
Car in limp mode wont go away + dont know why its on ac_gohan Normally Aspirated Powertrain 12 01-16-2002 03:01 PM
Help car stuck in limp mode!!! ac_gohan Bay Area Impreza Club Forum -- BAIC 3 01-15-2002 05:28 PM
Ques: MAF = toasted; how long can i drive in limp mode? Orbiter Technical Forum Archive 6 06-12-2000 02:38 PM
