Old 07-25-2010, 07:43 PM   #1
subaru_kid
Member#: 207888
2003 Impreza 25RS
Platinum Silver
Default Exhaust valve failure.Help/advice needed
Took my car in and was told by the mechanic that my cylinder 4 mis-fire is due to a bad exhaust valve.How bad,I don't know.When I asked how much to fix it he said he wouldn't due to the miles and that it would probably cost me less to find a used motor.Well im considering replacing the valve myself or maybe buy new complete heads cause I dont know what im going to find when I take off the covers.He said that the intake side of things are working fine and im getting good spark.The exhaust valve makes sense due to a dirtier plug and dirty exhaust pipe.I was thinking also a wrx swap but not sure on the cost.If I could find a used EJ22 that would be nice,then iI can swap parts without messing with ecu and wiring stuff.Any advice would be most helpful as im not sure what to do(or what funds and the wife will let me do).Until then I will just keep driving since its had this issue for awhile.If I were to do a WRX swap would I just need the engine,wiring harness,and ecu? and what about putting 2.5 heads on the 2.2,how much work would this be? Thanks for the info.
subaru_kid is offline   Reply With Quote
Old 07-25-2010, 09:09 PM   #2
Jaren1
Member#: 195061
1997 \_(ツ)
Green
Well it will probably be cheaper just to buy an used motor. But you probably wont know till you get the heads off of your current one. On a wrx swap yes technically all you would need is the harness and the ecu and the motor. But it will put alot of stress on the rest of your car that isnt made to take that amount of power.
I dont know how much money you had but I just got a DOHC EJ25 for $1200 with 70k on it had my buddies shop install it. Resealed everything, all seals replaced, new clutch and radiator for $2400 total.
Jaren1 is offline   Reply With Quote
Old 07-25-2010, 11:16 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
If you're handy with a wrench and can read english....get ahold of a FSM for your car. Subscribe to techdocs at subaru.com (might have to look around a bit) and download everything for your year and model.
You can replace headgaskets and reseal the important stuff while the heads are at a local machine shop getting a new valve and seals. (unless you feel confident to do this yourself)
A full engine gasket kit goes for around $250 and includes everything you'll need except that valve. A typical valvejob of inspection, seat cutting / lapping, and valvestem seals should run about $200. If you can eat this cost and do the rest of the labor yourself....it'll be cheaper than sourcing a newer motor and making any changes that need to happen should it be a different motor than what was in the car originally.
What part of MI you from? If in the SE....get the head(s) to me and I can replace the valve, seals and anything else short of cutting new seats.
Jay
Old 07-27-2010, 06:31 AM   #4
subaru_kid
Member#: 207888
2003 Impreza 25RS
Platinum Silver
I live in holt.thanks for the information.I do have all the service manuals for my car from Subaru.I think for now I'm going to pull the cover and see exactly what is going on .maybe I will get lucky and find a bad spring.
Old 07-27-2010, 08:11 AM   #5
eppoh
Member#: 199401
2000 Legacy OB
95 Honda wagon 66 Belanca
Without knowing how many miles on your engine and it's service history, it is hard to recommend either repair or replacement. If the head gaskets haven't been done, a complete job would cost you less than 1000 dollars if you do it yourself- and it will be fun! ( that includes new valves) Doesn't matter what you see under that rocker box cover-- the repair procedure will be the same- pull heads, replace gaskets, get heads to machine shop, replace bad valves, do timing belt and water pump, idlers and tensioner. All these, except head gaskets would need to be done on a used engine anyway.
eppoh is offline   Reply With Quote
Old 07-27-2010, 01:05 PM   #6
subaru_kid
Member#: 207888
2003 Impreza 25RS
Platinum Silver
I just did the timing belt and pumps and idlers.the car has 187000 miles.I have a friend looking at getting me new complete heads from Subaru.so I may go that route.still like the idea of getting a used motor and doing a complete rebuild.I think I can drive this car quite a bit longer as is.
leagal help/advice needed on trespassing M E R C U R Y Off-Topic 37 12-16-2007 02:34 AM
Sister needs help, advice needed. ninethreeeleven Tri-State Area Forum 10 10-25-2006 07:21 PM
FMIC Help/Advice needed! APSWRX1 Texas Impreza Club Forum -- TXIC 24 06-21-2005 03:31 AM
help/advice needed jhonas North West Impreza Club Forum -- NWIC 19 04-03-2002 08:23 AM
Help/Advice needed for wing install oldpreza Interior & Exterior Modification 2 06-24-2001 05:39 PM
