Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 07-26-2010, 09:56 AM   #1
erikm
Member#: 107019
Stg2 08 STi MBP
Franz Diebold tuned!
Default Shifter rattle after TiC Holy Shift Kit install
Installed the TiC Holy Shift kit on my 08 STi yesterday with stock lever.
LOVE the sound of it and the crisp shifting!
My question however is that if I drive somewhat hard I get a pretty loud rattle from the shift lever especially in 1st and second gear. Is this normal? If it is, I can live with it.
If not, what can be done? I can't tell if it is the reverse lockout that is rattling or something else. Maybe I didn't torque the pivot bushing properly?
Any help is appreciated, thanks!
erikm is offline   Reply With Quote
Old 07-26-2010, 10:11 AM   #2
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
More-than-likely, there is harmonic feed-back coming through the shifter handle.
This is because the shifter handle is one piece whereas the OEM handle is two pieces, but the two are effectively mated together through the use of a rubber or rubberized dampening material. Without the dampening material, you will experience chatter through the handle.
You can recheck the torque specs for the pivot bushings, which is 8.7Lb/ft (5 or 6-speed).
Additionally, did you lube (relube) the ball and socket of/for the shifter handle?
Old 07-26-2010, 10:22 AM   #3
erikm
Member#: 107019
Stg2 08 STi MBP
Nope I didn't re-lube the ball and socket. I never removed the ball from the socket for the install. I guess I should do this eh? What grease is recommended?
Also just to confirm I am using the OEM shift lever, not an aftermarket lever.
Old 07-26-2010, 10:26 AM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Lockout cable. Make sure the lug inside the lever isn't pressed against one side. Some grease will help with this.
Old 07-26-2010, 10:31 AM   #5
erikm
Member#: 107019
Stg2 08 STi MBP
Ohhh so the cable that is stuck against the lever is rattling against it eh? That makes sense. I hate pulling the center console apart but I guess I have to!
Old 07-26-2010, 10:46 AM   #6
erikm
Member#: 107019
Stg2 08 STi MBP
TiC, can you explain how I can move the cable away from the lever? Sorry... newb :P
Old 07-26-2010, 11:31 AM   #7
Turn in Concepts
Member#: 93646
Many Track Records
remove knob, use a flashlight, and a long screwdriver to push the lug over to the middle of the pin.
Old 07-26-2010, 11:44 AM   #8
erikm
Member#: 107019
Stg2 08 STi MBP
Thanks!
Old 07-26-2010, 01:27 PM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Originally Posted by erikm View Post
Thanks!
check the emblem on the shift knob if it's the stocker. Those come lose as cause noise as well (weird, but it does happen a good bit).
-clint
Old 08-02-2010, 06:04 PM   #10
jamesohoh7
Member#: 39070
GTF off my lawn!
-clint
Ha!, yep... the one in my STi buzzed a bit shortly after I bought the car. I 'fixed' it by just stuffing a piece of burlap or something in there to take up the space.
jamesohoh7 is offline   Reply With Quote
Old 09-30-2010, 04:23 PM   #11
erikm
Member#: 107019
Stg2 08 STi MBP
Fixed my rattle by adding some grease between the reverse lock out knob and the shift lever. There was some play between the two and now the grease has kept everything silent
FS: (PA) TiC Holy Shift Set [stock shifter] Espo Drivetrain 0 11-23-2009 02:30 PM
AccessPORT V2, Tic Holy Shift Kit, Blue Sti Mats,17x8 Sport Edition ST3 New2Subaru! Tri-State Area Private Classifieds 51 09-03-2009 05:20 PM
FS: (CO) TIC Holy Shift Set, Cobb Double ADJ. Shifter & Cobb Knob cleatis Drivetrain 5 07-27-2009 10:29 PM
Strange sounds after TiC/Kartboy Klunk Killer and Shift Kit Installed Eluder Transmission (AT/MT) & Driveline 26 05-02-2007 10:08 AM
TiC Holy Shift SonicWRX Car Part Reviews 1 03-01-2007 12:36 AM
