Old 07-27-2010, 08:22 AM   #1
eppoh
Member#: 199401
2000 Legacy OB
95 Honda wagon 66 Belanca
Default Leaking Cam seal
With about 200 miles on the rebuilt heads, the front cam seal on the passenger side is leaking.
Any ideas what I could have done when installing the new seal that caused a leak. Will be replacing it soon and don't want to repeat the same mistake.
While I am on the subject, any advice on a procedure for pulling the seal without scratching the head or shaft?
eppoh is offline   Reply With Quote
Old 07-27-2010, 08:38 PM   #2
Crashsector
Member#: 98702
2016 Jeep Patriot
Gray
The seal gets driven in flush with the cam cap/head, not past.
I use sharp drywall screws to remove the old seals. Drive them in at opposite sides and pull. Works every time.
--Andy
Crashsector is offline   Reply With Quote
Old 07-28-2010, 07:52 AM   #3
eppoh
Member#: 199401
2000 Legacy OB
--Andy
Is there anything to keep it from creeping in or out? Do you like to use three bond on it?
Old 08-14-2010, 01:13 AM   #4
mazda02subaru
Member#: 254103
I would like to know as well.. Should anything be applied when replacing the seal?
I expect my cam seal is leaking- I can see oil under driver's side of timing belt cover.
I may do this next week while replacing timing belt, idlers, water pump with gates kit.
Thanks!
mazda02subaru is offline   Reply With Quote
Old 08-14-2010, 02:27 AM   #5
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
When replacing cam or crank seals, be sure to apply some sort of a lubricant to the inside surface of the seal that comes in contact with the cam or crank respectively. I've used old motor oil, new motor oil, and bearing grease on multiple occasions and have never had a new seal leak on me.
I believe in the felpro seals, there is even an instruction telling you to do this.
PhilSine is offline   Reply With Quote
Old 08-14-2010, 06:42 PM   #6
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
99.9% of the time, they seal perfectly for me if I just wet the inside surface (that touches the cam) with oil. The really pain the in the ass ones won't seal unless you both wet the inside with oil and smear a tiiiiiiiiiny bit of Permatex Ultra Grey around the outside. I have a feeling that the reason a tiny portion of them leak is that the surface the outside of the seal touches (one side is the head, one side is the cam cap) isn't perfectly round or has some tiny imperfections.
Cam seal - Oil leak - tips? compton Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-15-2006 05:37 PM
Cam seal - Oil leak - tips? compton South East Region Forum 6 07-13-2006 09:39 AM
leaking cam or crank seal! how much $?!!?! ooberdoob Legacy Forum 2 12-31-2005 09:39 AM
Cam seal leaking oil. Again! b0dh1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-02-2005 03:51 PM
Auto Rx Product for Leaking Cam Seals/Engine Cleaning??? pdigiacinto Legacy Forum 9 01-27-2004 03:43 PM
