Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 05-28-2011, 03:57 PM   #51
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
mad jealous.
maxpowr is offline   Reply With Quote
Old 06-03-2011, 03:00 PM   #52
banny sti
Member#: 118815
Rad fans fitted
Cossie manifold setup finished
For the geeks (like me)
banny sti is offline   Reply With Quote
Old 06-16-2011, 04:17 PM   #53
banny sti
Member#: 118815
Finished adaptor bracket
Throttle cable mount
Final finish on inlet manifold
Old 06-18-2011, 06:48 AM   #54
banny sti
Member#: 118815
Dry fit to check for issues, alternator bracket needs adjusting to clear the throttle cable
Old 06-18-2011, 01:59 PM   #55
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
thats wasup. i want one exactly the same way. looks awesome bro, good job.
Old 06-18-2011, 07:03 PM   #56
stilegacybd5
Member#: 285642
very nice banny good to see yous in the UK doing well, very good figures on a rolling road dyno i now know what i need to get my goal of 400-450whp now thankyou just need my meth injection turned back on with local 98octane and 26-28psi.
im running similar setup here in NZ, 2.0 sti jdm v3 closed deck forged pistons jdm sti rods in a legacy 1994 gt sedan with g4link gt3082r 1000cc bosch top feeds etc currently only on run in tune with the new turbo at 19psi i got 255kw atw ill be getting retuned in next week or two. heres the graph of the 19psi safe tune no meth (will get a more agressive tune on high boost setting)
heres a few recent pictures of my legacy
heres a video from a year ago on the old td05-20g that achieved on a agressive tune and meth 328whp
stilegacybd5 is offline   Reply With Quote
Old 06-19-2011, 11:37 AM   #57
banny sti
Member#: 118815
Proper sleeper you have there and post up your final results
Old 08-07-2011, 04:44 PM   #58
banny sti
Member#: 118815
Due to various reasons car has been on the back burner but work is starting again, collected a few bits whilst waiting
Flocked dash
DC2 Intergra type r seats, steering wheel will be trimmed in black suede with red stitching
Some whiteline goodies and carbon slam panel
Old 08-07-2011, 04:49 PM   #59
Clark Turner
Member#: 178047
02 WRX STI Spec C
I love it man. A white four door. Good work.
C
Clark Turner is offline   Reply With Quote
Old 08-09-2011, 04:01 AM   #60
banny sti
Member#: 118815
1.5 litre swirl pot with 2 X JIC - 6 INLET, JIC - 6 BREATHER/RETURN and JIC - 8 OUTLET will be boot mounted with pump and fuel lab filter
Old 08-11-2011, 11:57 AM   #61
banny sti
Member#: 118815
Some more bits arrived today, hoping to have the car closed to finished by the end of the month....
Old 08-25-2011, 03:17 AM   #62
banny sti
Member#: 118815
Received some more bits yesterday
Collected this pod on the weekend
Old 08-25-2011, 08:21 AM   #63
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i am doing a rotated throttle body 30r and am curious how you guys fabbed up the bracket to move the alternator. i assume i'll need to get a pulley in there as well for tension and coverage on the alternator pulley...
seems a lil easier to just lower the alternator as low as possible and use a short belt.
Old 09-08-2011, 03:39 PM   #64
banny sti
Member#: 118815
Got a couple of bits on the weekend, an air filter with trumpet and a billet timing belt guide
The fuel system has had a re think so it will be as follows, out of the tank to the swirl pot -10 to fuel pump, -10 out of fuel pump to fuel filter, -10 from fuel filter to -10 line through the car, billet y piece to split -10 line to 2 -6 lines to the fuel rails and -10 return to the swirl pot.
This should allow sufficient flow for well over 700bhp and keep things simple but meant I needed another fuel filter with -10 inlet and outlet. All lines and fittings will be supplied by Alex from Torques via ebay
http://www.ebay.co.uk/itm/6-Race-Ral...item23127c9d1c
http://www.ebay.co.uk/itm/6-AN6-STRA...item25641e5d0d
http://www.ebay.co.uk/itm/6-AN6-90-D...item230e8cbb18
Old 10-18-2011, 03:07 PM   #65
banny sti
Member#: 118815
Quick update finally on the home straight, firstly bought a cold air feed to fit on the inner wing
Alternator bracket
Injectors rails (prototype, still need finishing off) for 14mm ID2000s
Old 10-18-2011, 06:48 PM   #66
stu
Member#: 25768
35R bugeye
Slowbaru
have you always capped off the breather on the heads. i did that before and blew out the rings. i would let them breathe
stu is offline   Reply With Quote
Old 10-18-2011, 09:40 PM   #67
AREA1320
Member#: 112508
Its the oil return on the valve cover. The breathers are still open.
AREA1320 is offline   Reply With Quote
Old 10-19-2011, 02:09 PM   #68
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Looks awesome man im running a little bigger Turbo but twinscroll and im making about the same peak torque at pretty much the same Rpm, gotta love thefeeling of the 207s
seanathanq83 is offline   Reply With Quote
Old 11-01-2011, 03:44 PM   #69
banny sti
Member#: 118815
Final finish on the fuel rails
One off fuel rail for driver's side to allow clearance for the inlet pipe
In place
Test fit of inlet pipe to check clearance, actual hose will be black
Old 11-01-2011, 04:42 PM   #70
creative wrx
Member#: 141754
04 stock wrx ;)
z31 project, passat dd
cant wait to see how this car finishes up really nice project you pieced together
creative wrx is offline   Reply With Quote
Old 11-10-2011, 04:04 PM   #71
banny sti
Member#: 118815
Engine bay getting there, only intercooler pipework, tensior arrangement and brackets for the fpr left
A little something for the under bonnet temps as it will have a vent not a scoop
Old 11-12-2011, 04:56 AM   #72
tstevensWrX
Member#: 269681
Awesome build! Love the closed deck 2.2. Can't wait to see the finished product
tstevensWrX is offline   Reply With Quote
Old 11-12-2011, 08:20 AM   #73
CatfaceType-R
Member#: 81102
Who makes those rails, are both sides linked in parallels?
CatfaceType-R is offline   Reply With Quote
Old 11-12-2011, 10:27 AM   #74
banny sti
Member#: 118815
Pennine Subaru made them specially for my build and yes they are parallel
Old 11-12-2011, 01:20 PM   #75
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
looking good banny. what is and where did you get the material for the turbo inlet?
Anyone using Perrin EBCS w/ UTEC on WRX stock 2 litre? overdose Engine Management & Tuning 3 04-22-2005 12:33 PM
Turbonetics T58 on 2 litre [MRT.SUX] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 12-06-2003 11:57 AM
Tommy Kaira 2.2-litre STI illustration shirokuma Interior & Exterior Modification 27 05-21-2002 04:44 AM
2.2 litre turbo kits car_freak85 Normally Aspirated with bolt-on Forced Induction Powertrain 18 05-05-2002 06:11 PM
Tommy Kaira 2.2-litre B4 TT test drive shirokuma Legacy Forum 8 03-13-2002 08:53 PM
