Old 07-27-2012, 09:18 PM   #126
jura11
Member#: 255146
2001 2002 WRX Wagon
WR BLUE
Nice one Banny,should be fun on the TOTB,more to come with NOS
Jura
jura11 is offline   Reply With Quote
Old 07-28-2012, 11:45 AM   #127
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
this is a 2.35 now? you have a mod list?
karlknaupp is offline   Reply With Quote
Old 07-28-2012, 05:18 PM   #128
banny sti
Member#: 118815
Yep its a 2.35 now
Engine & Transmission
EJ22T block
EJ257 79mm nitrided crank
Wiseco stroker pistons
Crower stroker rods
ACL main and big end bearings
Cosworth 12mm high flow oil pump
14mm head stud conversion
Zero sports 71c thermostat
2006 avcs heads ported and knife edge polished
1mm oversize Cosworth Inlet and Exhaust valves
supertech titanium retainers
supertech double valve springs
supertech valve seats
272 inlet and exhaust cams
Adjustable exhaust cam pulleys
Kevlar timing belt
cosworth billet timing belt guide
Cosworth high flow inlet manifold
bespoke top feed fuel rails
Injector dynamics 2000cc Injectors
Aeromotive A1000 fuel pump
fuelab -10 fuel filter
SM swirl pot
walbro 255lph lift pump
braided clutch line
Exedy hyper twin plate clutch
RCM 100mm trumpet
RCM 260mm Induction cone
Inner wing induction box with 76mm feed to foglight
Beatrush gearbox stabiliser
STi engine mounts
GT spec headers
rotated up and down pipes
44mm tial external wastegate
Roger clark return to sump catch can
Braided fuel hoses
Scoobyclinic Garrett Billet GT35R
Custom header tank
STi 1.3bar header tank cap
2007 UK long ratio DCCD 6 speed gearbox
R180 3.54 plated diff
Bespoke braided engine loom
Roger clark lightened pulleys
DEI Titanium turbo blanket
Omni power 4bar map sensor
Odyssey PC680 battery
Fuel lab 3 port fuel pressure regulator
Power steering reservior relocation kit
twin scroll baffled sump
Syvecs S6 PNP ecu with 8 maps, Anti lag, Launch control. flat foot shifting and nos control
STi quickshift
ASH silicone hoses
Summit racing radiator flow panel
3.5" veilside titanium exhaust
wideband lambda fuelling control
NGK Racing 8 spark plugs
New age coil pack conversion
New age radiator
Reverse mounted radiator fans
Turbosmart 3 port boost solenoid
White ceramic coating on all exhaust pipework
NGK racing 8 spark plugs
Fuelab 3 port Fuel pressure regulator
Fuel pressure sensor
Aeroquip power steering hoses
Wizards of nos nitrous kit
Hyperflow monster intercooler
Tial bov
Suspension
AST sportline 1 coilovers
Whiteline 22m adjustable rear anti roll bar
Whiteline 22m front anti roll bar
whiteline alloy rear drop links
Whiteline adjustable front drop links
whiteline front roll centre adjustment kit
whiteline heavy duty steering rack mounts
whiteline anti lift kit
whiteline subframe lock kit
noltec adjustable top mounts front and rear
front strut brace
Beatrush rear diff brace
2 1/2 ratio steering rack
Whiteline KTA108 adjustable arms
Cusco rear carbon v brace
Whiteline H brace
Whiteline Front Heavy duty gearbox mnts-RACE (W0584M)
Kartboy Shifter Bushings
Kartboy Rear Shifter Bushing
Beatrush Propeller Shaft Mount Collar
Hardrace Gearbox mount
banny sti is offline   Reply With Quote
Old 07-31-2012, 04:47 AM   #129
banny sti
Member#: 118815
Gave the car a shakedown at the weekend ran 1.9bar peak holding 1.7bar on RE070s and managed a 10.80 1/4, the car has so much more to give but defo needs proper tyres
Old 08-08-2012, 05:38 AM   #130
banny sti
Member#: 118815
Slips from the above runs, against a strong headwind
Old 08-09-2012, 12:18 PM   #131
bannie 786
Member#: 328604
hi banny
couple of questions, why only show half a graph?
why blank out the drivers name? seems very strange? unless you have something to hide?
bannie 786 is offline   Reply With Quote
Old 08-09-2012, 12:29 PM   #132
CatfaceType-R
Member#: 81102
Originally Posted by bannie 786 View Post
hi banny
Seems like you pissed someone off, Banny. Or just being trolled, big time.
CatfaceType-R is offline   Reply With Quote
Old 08-09-2012, 12:32 PM   #133
bannie 786
Member#: 328604
genuine question
Old 08-09-2012, 12:35 PM   #134
CatfaceType-R
Member#: 81102
genuine question
Your screename and join date seem to show otherwise...
I could have sworn banny had a projects thread on bbs scoobynet, I can't seem to find the thread now.
Old 08-09-2012, 12:40 PM   #135
bannie 786
Member#: 328604
seems a strange reply? think before posting spring to mind? we dont want his thread tarnished!
Old 08-09-2012, 12:53 PM   #136
CatfaceType-R
Member#: 81102
Pot calling the kettle black...I was actually looking out for his thread, but u win. :wave:
Old 08-13-2012, 06:16 AM   #137
stealthiejrat55
Member#: 328969
Lovely build and great 1/4mile results!!!
stealthiejrat55 is offline   Reply With Quote
Old 08-13-2012, 12:18 PM   #138
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
More videos!!!
maxpowr is offline   Reply With Quote
Old 08-13-2012, 01:09 PM   #139
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
hi banny
genuine question
You joined just to post this. You haven't posted anything else. You're being watched. Don't start ****.
Scooby921 is offline   Reply With Quote
Old 08-13-2012, 01:20 PM   #140
bannie 786
Member#: 328604
sorry, but some of us work and cant get on here all the time, apologies to banny didnt want to put doubts into a lot of peoples mind, by all means watch me im not on here just to post on this thread
Old 08-14-2012, 02:54 PM   #141
duncjsttt
Member#: 328889
right, as i was a guest on here for many months i thought id finally join but i need to post on this thread because theres lots of bad press i was at totb when this car did a 10.8, was on a saturday, not the sunday when the top boys were there! yes it did a 10.8 but it was not banny driving it it was gazza who built bannys car, i dont want to get involved in a slanging match, some are on here doing that already! so can we please say bannys car is really nice but gazza built and drove it at totb this is nothing against banny or the other people that have posted good or bad!!!! but personally i think some points need clearing up
duncjsttt is offline   Reply With Quote
Old 08-14-2012, 03:08 PM   #142
banny sti
Member#: 118815
I never said he did not drive it, you should have popped over and said hello on the day
Old 08-14-2012, 03:26 PM   #143
duncjsttt
Member#: 328889
didnt have time mate else i would hope i helped you out on this thread no need for that nonsense from other users, glad its all out in the open..... finaly
Old 08-15-2012, 08:50 AM   #144
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
No one says you have to post all day, every day to be a part of the site. It's just that your first 3 posts were all in this thread and it looked like you were stirring the pot. If all is well then carry on.
But...
Originally Posted by duncjsttt View Post
^^ This account was created 3 days later from the same computer and is now posting in this thread. I thought coincidence and now I'm wondering if it's something else.
And so I continue to watch...
Quite simply, and this goes for everyone, if you want to talk about the car and the results that's what PPB is for. If you want to call someone out and pick a fight you do that somewhere else.
Old 08-15-2012, 08:56 AM   #145
CatfaceType-R
Member#: 81102
Aww, he lied to you, slap him with that ban stick.
You are too nice!
*cowls, then run's into hiding*
Old 08-15-2012, 09:35 AM   #146
banny sti
Member#: 118815
But...
Do the above two accounts share the same IP as username rcm scoob by any chance?
Old 08-15-2012, 10:24 AM   #147
eggy790
Member#: 236241
2002 WRX STi - Bug
Black Blue Mica
lol banny we all know its gonna be stealthy55 or jag .. my bets on the teabagger tho lol just go out with proper tyres and kill the 10.6 time and really get them hating.. as if they aint hating enuff as it is.. maybe by then stealthys top secret, no one can know about or hear about.. proper built car with proper parts and all that rubbish will be running and they'll have double the chance.. coz jag sure as hell aint getting any better with his driving.
eggy790 is offline   Reply With Quote
Old 08-16-2012, 01:22 PM   #148
banny sti
Member#: 118815
Set of drag/track wheels courtesy of Mikee Singh :thumb:
Old 08-18-2012, 10:14 AM   #149
einstein ra
Member#: 329503
Yep it'll be the 'snivelling little shyte' no doubt!
einstein ra is offline   Reply With Quote
Old 08-18-2012, 11:35 AM   #150
BLACKKETYL
Member#: 207919
is a transition
medium
WTB, the English language.
BLACKKETYL is offline   Reply With Quote
Anyone using Perrin EBCS w/ UTEC on WRX stock 2 litre? overdose Engine Management & Tuning 3 04-22-2005 12:33 PM
Turbonetics T58 on 2 litre [MRT.SUX] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 12-06-2003 11:57 AM
Tommy Kaira 2.2-litre STI illustration shirokuma Interior & Exterior Modification 27 05-21-2002 04:44 AM
2.2 litre turbo kits car_freak85 Normally Aspirated with bolt-on Forced Induction Powertrain 18 05-05-2002 06:11 PM
Tommy Kaira 2.2-litre B4 TT test drive shirokuma Legacy Forum 8 03-13-2002 08:53 PM
