Old 04-03-2013, 01:29 PM   #176
banny sti
Member#: 118815
banny sti is offline   Reply With Quote
Old 04-05-2013, 10:51 AM   #177
Mr.Veryfast
Member#: 278728
Thanks a bunch
Mr.Veryfast is offline   Reply With Quote
Old 04-09-2013, 02:41 PM   #178
banny sti
Member#: 118815
Old 04-29-2013, 08:21 AM   #179
banny sti
Member#: 118815
Nearly ready for collection
Old 05-14-2013, 02:46 PM   #180
wagon_war
Member#: 320092
02 WRX WAGON
Bump love this car ...... I still Follow !
wagon_war is offline   Reply With Quote
Old 05-20-2013, 04:35 AM   #181
banny sti
Member#: 118815
Cheers, having to revert back to the standard wheels for now to get the best possible geo setup open to ideas on what wheels to go for but need to be 7.5x17 between ET45 and ET48
Old 06-02-2013, 09:54 PM   #182
wagon_war
Member#: 320092
02 WRX WAGON
So what whees did you choose ?
Old 06-05-2013, 07:54 AM   #183
banny sti
Member#: 118815
Got a choice between bronze rays ce28n's
or white rota fighter's
Old 06-05-2013, 11:05 AM   #184
wagon_war
Member#: 320092
02 WRX WAGON
I like the bronze. And easier to keep clean!
Old 06-12-2013, 01:56 AM   #185
WelDun1
Member#: 249130
1999 Ver5 STi RA
This build is off the eFFn chain!!! Im building a Ver5 Type-R at the moment but its all going into a 95L sedan so I guess u could say I'm building a RA. Anyways, I'm trying to figure out what turbo I'm going with, and was hoping you could help me out. I'm using the Ver5 Type-R ej207dw1pr, Apexi PFC (**EDIT**LINK G4 PLUG N PLAY), bottom end will be built, possible built heads + PnP, stock TMIC at the moment, trying to find a Bigger ver7-9 STi TMIC & I also have a Brand new FMIC w/o piping, 3" V-band TBE, (***EDIT*** no MAF, Tuned for Speed Density), walbro 255lph, 1000cc Dynamic Inj, .... This is all in the making BTW, nothing set in stone yet. I had in mind either the Blouch Dom 2.5XTR, GTX3071R, or the GT3076R.(***EDIT***GTX3071R). if u have any input or advice u can share with me, I would appreciate it a lot bro! My set goal is 400-450whp. No higher than that .
WelDun1 is offline   Reply With Quote
Old 06-21-2013, 04:53 AM   #186
banny sti
Member#: 118815
Originally Posted by WelDun1 View Post
This build is off the eFFn chain!!! Im building a Ver5 Type-R at the moment but its all going into a 95L sedan so I guess u could say I'm building a RA. Anyways, I'm trying to figure out what turbo I'm going with, and was hoping you could help me out. I'm using the Ver5 Type-R ej207dw1pr, Apexi PFC, bottom end will be built, possible built heads + PnP, stock TMIC at the moment, trying to find a Bigger ver7-9 STi TMIC , 3" V-band TBE, KS Tech 73mm Mega MAF intake, walbro 255lph, 800-1000cc Dynamic Inj, .... This is all in the making BTW, nothing set in stone yet. I had in mind either the Blouch Dom 2.5XTR, GTX3071R, or the GT3076R. if u have any input or advice u can share with me, I would appreciate it a lot bro! My set goal is 400-450whp. No higher than that .
If cost is no issue then it would have to be the GTX3071R as power delivery is so much more aggressive from a rotated turbo and would probably make your target at lower boost
Big thank you to Chevron for finally making my car the way it should have been from the outset, correcting lots of issues that I did not know were even there!
Now the actual reason the car was there was to have a full geo setup and I can happily say handling, grip and all around balance of the car is amazing, knew there would be a difference but did not expect it to feel like a different car the biggest change is the turn in, it is super sharp as it responds to the slightest input and changes direction instantly. May even do TOTB saturday now lol
Old 06-21-2013, 05:14 AM   #187
WelDun1
Member#: 249130
1999 Ver5 STi RA
I wouldn't say money isn't an issue, but I'm looking at about $12k for the initial build, and then gradually build from there. I actually have an opportunity to snag a fairly new (2000mi)gtx3076r right now for $1500, but its set up for IWG /stock location. Will the 3076 be torquey enough with the 2.0? I've also changed my mind to run a Link G4 Plug n Play instead of the Apexi. It just has a lot more/better features +anti lag :-)
Old 06-21-2013, 05:38 AM   #188
banny sti
Member#: 118815
If its a stock location turbo then I would not bother as they seem to be laggy for the numbers they make, I would defo go for the blouch over it
Old 06-25-2013, 03:23 AM   #189
WelDun1
Member#: 249130
1999 Ver5 STi RA
I'm actually thinking about running with a rotated gtx3071r .63ar now. I'm only aiming for 400awhp 450 Max. So it looks like the gtx3071r is going to be my new best friend!
I know the Ver5/6 ej207 are outdated engines, but I think they are still worthy of a respectable build, and it would be nice if the ppl who feel the same way would post their build results. I know I will try to post all my info to help the next GC8'er that comes along!
Old 07-03-2013, 05:54 PM   #190
WelDun1
Member#: 249130
1999 Ver5 STi RA
What up Banny. So I'm trying to pick out my Cams right now, and thought id see what your opinion is on Low Duration High Lift. I'm thinking about running the Kelford-J cams which are a Rally/Time Attack Cam @ 264/260 10.90/10.45 LSA110/112 8500rpms.
Old 11-03-2013, 11:36 PM   #191
WelDun1
Member#: 249130
1999 Ver5 STi RA
Haha.. It looks like I'm buggin the hell outta you when you read this last page. Sorry man, but ur the only guy I've seen on these forums that has built a GC8, and better yet..built a GC8 engine. Most ppl with built GC8's on here have swapped out the original engine for a Ver7-9.
Anyways, one last question, I think... I'm at the fuel delivery stage of my build right now, and wanted to know what Injectors you thought would be good for my build. Rotated gtx3071r. I'm thinking about going with the DW850cc side feeds. They will drop right in won't they? At first I wanted ID1000cc but I didn't know I had to do a huge top feed conversion, so I'm going with side feed. 850cc should Definitely be enough for a 400awhp build right? I here a lot of ppl say that the 740's will be plenty' but I want to make sure I leave room for Improvement, not to mention run at a lower duty cycle. So basically my main question is, "will the DeatschWerks 850cc side feeds drop right into a Ver5 STi?"
Thanks Banny! Sorry for the Novel sized comments. I'm just super stoked for this build.
Old 03-24-2014, 07:27 AM   #192
banny sti
Member#: 118815
So due to personal reasons the type r was sold and I took a break from the scene but picked this up yesterday after a 6 month break
Old 03-24-2014, 01:51 PM   #193
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
What are those seats?!
Zee Biker is online now   Reply With Quote
Old 03-24-2014, 02:46 PM   #194
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Extremely rare Confetti Recaro's from Japan
Gigs90 is offline   Reply With Quote
Old 03-24-2014, 03:19 PM   #195
Kuros
Member#: 328669
2017 STI
Red. Duh
All this BAR talk is making me feel Irish...
I guess ill go home and beat my wife
Also, that is a beautiful car. Love it
Kuros is offline   Reply With Quote
Old 03-26-2014, 09:03 AM   #196
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
Man that thing is nice just needs a fresh build
alexandern05 is offline   Reply With Quote
Old 03-26-2014, 12:48 PM   #197
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr jdm 6-spd JJtuned
Why is the face blurred out? Did you boost it?
Dave D. is offline   Reply With Quote
Old 03-26-2014, 01:08 PM   #198
snowmanwithahat
Member#: 328283
2004 STi
lol it looks like the cheap carpet out of a movie theater from the 90's
snowmanwithahat is offline   Reply With Quote
Old 03-26-2014, 02:28 PM   #199
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Yes but they are extremely well built seats
Old 03-26-2014, 04:21 PM   #200
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Subian is offline   Reply With Quote
Anyone using Perrin EBCS w/ UTEC on WRX stock 2 litre? overdose Engine Management & Tuning 3 04-22-2005 01:33 PM
Turbonetics T58 on 2 litre [MRT.SUX] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 12-06-2003 12:57 PM
Tommy Kaira 2.2-litre STI illustration shirokuma Interior & Exterior Modification 27 05-21-2002 05:44 AM
2.2 litre turbo kits car_freak85 Normally Aspirated with bolt-on Forced Induction Powertrain 18 05-05-2002 07:11 PM
Tommy Kaira 2.2-litre B4 TT test drive shirokuma Legacy Forum 8 03-13-2002 09:53 PM
