Old 07-27-2010, 03:20 PM   #1
MikeyAE86
Member#: 185525
1993 Impreza wagon
Default -Help- Squealing noise. Im lost. Cash prize inside
So this has boggled my mind for a very long time. when i got the car it made this noise for about a week. i just drove it normal and it went away. now over a year later it has come back, and wont go away.
now its just a squealing noise, listen to the video, you'll hear it. It only happens when im turning left or when the suspension is compressed ( going over a bump)
its related to wheel speed, when it happens i can take it out of gear and shut the car off, and as i roll to a stop its steal squealing.
so ive looked at and eliminated the following:
fenderliners ( removed them)
CV boots ( greased them and there in amazing shape)
hanging lines, wires etc
i just dont understand what could be causing it..
If you can figure this out, ill give you $15. cash. thats how much this is driving me mad.
Ill post pics of anything you would like to see, im just stumped.
Thanks in advance
MikeyAE86 is offline   Reply With Quote
Old 07-27-2010, 04:48 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
That's very strange! I don't know if the symptoms are right but have you check the power steering pump? When was the last time you inspected/replaced the brakes?
Mike
GrimmSpeed is offline   Reply With Quote
Old 07-27-2010, 05:11 PM   #3
MikeyAE86
Member#: 185525
1993 Impreza wagon
Mike
Ps pump is fine, fluid is full. checked the brakes last night and ten mins ago..
a member on another forum was saying it might be wheel bearings so i checked and no sign of play.
and it happens engine running or not, and in or out of gear so im 90% sure its not anything engine or trans related.
Old 08-14-2010, 12:28 PM   #4
snoopyone8
Member#: 42970
1998 2.5RS BlkDmdPrl
2000 2.5RS SilverthornMet
That almost sounds like it could be something rubbing against the ABS Sensor Wheel, have you looked at that?
snoopyone8 is offline   Reply With Quote
Old 08-14-2010, 01:44 PM   #5
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
Is this on both sides?
If its happening from just turning wheels, it might be your bearings although it doesn't sound like bad bearings I'm used to hearing. Bearings that start to go bad won't show much play but can still be audible. Throw your car up on jackstands and rotate the offending wheels. Listen for any "growl" when you turn the wheels. Use your sense of touch too, as you turn the wheels by hand it should be smooth and no roughness.
Hope its not your diff. Check the fluids though...or maybe just change it for good measure. Its not hard or expensive.
Henry H is offline   Reply With Quote
help needed...prize inside!! :D:D Lamb155716 Off-Topic 19 01-22-2009 07:27 PM
help me please. Im lost memphisawaits Newbies & FAQs 28 10-03-2006 12:51 PM
squealing noise help checque Brakes, Steering & Suspension 5 07-18-2006 08:02 PM
need help with swap, im lost dont know where to start....... stusha Subaru Conversions 3 09-01-2005 10:33 PM
New England - I need YOUR Help!!! $500 CASH PRIZE chrislehr New England Impreza Club Forum -- NESIC 19 12-15-2004 03:47 PM
