Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 07-27-2010, 08:00 PM   #1
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
Default Gas Gauge reads inaccurately in 96' BG.
Basically it's like this.... it's a 96' Outback 2.5L.
If I fill it up with 16 gallons it fills up; but whenever 6-8 gallons go through it'd move to the EMPTY. It's 50% or so inaccurate, but still works; when I fill up the car it does go up.
So; do I need to replace a fuel sender? fuel pump, or what? Maybe I can repair mine.. I don't know. What advice do you guys have?
kirbykirb is offline   Reply With Quote
Old 07-27-2010, 08:04 PM   #2
kirbykirb
Member#: 183596
2005 WRX/9-2x
Also forgot to add; the fuel light does not come up when I have 1-2 gallons left in the car?
I measured this by how much gas I add to the car and it comes around to 14 or so gallons.
Old 07-27-2010, 11:18 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I would guess you'd need a new fuel sender. I'm away from home right now, so I can't look at it, but I'd bet that the Haynes Manual has resistance values for empty and full so you can measure whether the sender is bad or not.
Pat Olsen
Old 07-27-2010, 11:34 PM   #4
daleyswanson
Member#: 205604
87J Robinson
R22
Mine is inaccurate as well. There is a DIY that supposedly helps on sli or legacygt. I can't remember which. It involves removing the sender and sanding down the brass receiver if i recall.
daleyswanson is offline   Reply With Quote
Old 07-29-2010, 12:25 AM   #5
ReubenH
Member#: 172522
1998 Legacy GTB Ltd.
Gas Guage reads inaccuratley in 96' BG.
There's a saying in the aviation world, which i've repeated here many a time.
There's only 2 times a fuel gauge will ever read correctly. Absolute full, and absolute empty.
ReubenH is offline   Reply With Quote
Old 07-29-2010, 09:00 PM   #6
TjCombs89
Member#: 253398
my subaru does the same thing, let me know if you figure out how to fix it
TjCombs89 is offline   Reply With Quote
Old 07-30-2010, 12:35 AM   #7
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
I *think* with the "new" submersible fuel pumps many manufacturers design their fuel senders to intentionally read "low" or "empty" when there is still plenty of fuel in the tank.
The idea being to make sure you keep plenty of fuel in the tank. Running below 1/4 of a tank means that often times your submersible fuel pump isn't always submerged and in some cases could be running "dry". Their usable service life declines drastically when they are attempting to pump fuel that isn't there. Also they depend on being submerged in fuel to help keep the pump cool.
These things can cost serious money to replace.
My advice would be to live with it the way it is and make sure you still have plenty of fuel in the tank between fill up.
Jonathan is offline   Reply With Quote
Old 07-31-2010, 11:42 PM   #8
Navi271
Member#: 203099
1995 Legacy Wagon
Winter Green Metallic
There's a giant thread about this at sl-i.net, and the general consensus there is that most 95-99 legacy's have this problem. They must have been built with some crappy stuff that doesn't accurately read the fuel level after years of use. Mine does it too. My gauge will hit E when I have about 5 gallons left. I just keep track of the gas mileage and reset the trip counter every time I fill up, so I know about how much gas I actually have! My low gas light has never come on... EVER! I swear the light looked fine last time I had the gauges out...
I agree with jonathan, live with it! That's what I do, because like you said, "it still works" so why fix it?! ... still is annoying tho...
Navi271 is offline   Reply With Quote
Old 08-01-2010, 02:35 PM   #9
kirbykirb
Member#: 183596
2005 WRX/9-2x
That's what i've been doing, I can get to around 220 miles and have 3-4 gallons left (to my surprise).
I just need to be getting a scanguage though. :| I would so love the feature of having my MPG read, and fuel level left and etc... one reason I loved E36's. <3
Old 08-02-2010, 06:47 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
The Haynes Manual says the resistance of the sender should be ~50ohm when the tank is near empty, and ~1ohm when it is full. On the AWD cars there are two sending units - the driver side is just a sending unit, the passenger side is integrated with the fuel pump assembly.
Old 08-02-2010, 04:36 PM   #11
Navi271
Member#: 203099
1995 Legacy Wagon
Haha! It's funny that you're talking about a scangauge, because I've been using one for more than a year now! It's pretty accurate too. Last time I filled up it was only like .2 gallons off with how much gas I actually used.
gas gauge doesnt read correctly t00sl0w Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 11-14-2009 09:01 PM
My Omori boost gauge whines, inaccurate. Superorb Electrical & Lighting 4 05-21-2007 07:18 PM
which gauges read in psi? bluperlrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-07-2002 10:10 AM
What Should An Oil Presure Gauge Read In A Wrx 02 GM991 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-31-2002 11:55 AM
My gas gauge reads 50% off. anyone else? Eric SS General Community 15 12-20-2001 09:42 AM
