Vancouver Impreza Club
Old 07-27-2010, 09:41 PM   #1
keifun
Member#: 176100
03 Bugeye WRX
Default My Bugeye is giving me headaches..AHH!!!
A lil bit of history.
I bought the car back in January, it was fine. Then around April/May I got a CEL about my TGV valves and sensors not working. Got that all sorted out and fixed at Richmond Subaru which costed me a **** load of $$$
Now today while driving home, my CEL just came on again.
ahhhh...anybody here have a OBD reader that I can borrow. I wanna see what this CEL code is and if its related to the first CEL I had about my TGV.
If it is so, then perhaps I can use this as a reason for them to fix it for free as they guarantee their parts and service.
Any other owners having many pblms with CELs..
I drive a 03 WRX btw...
/end rant
keifun is offline   Reply With Quote
Old 07-27-2010, 09:46 PM   #2
jchretien
Member#: 217235
1999 FoLEsTa EsTe-Ai
Canyon Red
I have OBDII reader. I'll PM you my #
jchretien is offline   Reply With Quote
Old 07-29-2010, 08:59 AM   #3
Horkus
Member#: 112667
2002 WRX wagon
Usually Miss fire codes which is pretty common.
Horkus is offline   Reply With Quote
Old 07-29-2010, 11:51 AM   #4
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
is it modded? my bugeye used to give me all kinds of CEL's. a lot of misfire codes even on a stock tune.
Loomin is offline   Reply With Quote
Old 07-29-2010, 05:54 PM   #5
keifun
Member#: 176100
03 Bugeye WRX
well i resetted my ECU by pulling out the negative terminal on my battery..
the light went off.. then took it for a drive last night, it didn't come on again....yet
Old 07-29-2010, 06:56 PM   #6
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
i r in langley/abbotsford....with code reader...pm me if im close to you
Jeff54 is offline   Reply With Quote
Old 07-30-2010, 03:24 AM   #7
Beard
Member#: 241120
2003 WRX
hey, I also drive an 03 WRX and also had a problem with the CEL. it came on today, took it to the shop, and first it read that my #1 and #3 pistons were missfiring, then it said, all my pistons were missfiring, but that doesn't make a whole lot of since considering the car was still running.
good luck with yours
Beard is offline   Reply With Quote
Old 07-30-2010, 04:00 AM   #8
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
the car will still run even if its misfiring....makes complete sense
Old 07-30-2010, 04:29 AM   #9
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
it is true. my bugeye got all 4 misfire codes.
Old 07-30-2010, 03:57 PM   #10
Beard
Member#: 241120
2003 WRX
ineresting.
i had no idea it would still run, so guess it does make sence.
Old 07-30-2010, 03:58 PM   #11
Beard
Member#: 241120
2003 WRX
ineresting.
Old 07-30-2010, 07:30 PM   #12
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
mine used to misfire #4.. maybe 4 times iirc.. so ran perfectly fine.. just had to pull the code and clear it.. =)
KIMUTAKU is offline   Reply With Quote
rough idle is giving me a headache kyle_g Normally Aspirated Powertrain 24 03-05-2009 01:09 AM
My new job is giving me carpal tunnel Cjchaps Off-Topic 18 12-04-2006 11:46 AM
utec with stage two map is giving me knock. codean Engine Management & Tuning 14 10-31-2002 04:00 AM
tranny is giving me probs! Blindeye_03 Transmission (AT/MT) & Driveline 2 12-17-2001 11:49 AM
('93-'01) Vice Prez of Flow Master is giving me a freebee! hayscoob Impreza Forum 4 06-08-2001 01:10 AM
