Old 07-27-2010, 09:57 PM   #1
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
Angry Treeee Saaaappp!!
got tree sap on my WRB hood and scoop. I purchased the car this way.
I used Turtle wax bug and tar remover...it did nothing.
Suggestions
krauser2 is offline   Reply With Quote
Old 07-27-2010, 10:35 PM   #2
nymtber
Member#: 253247
2007 Impreza Wagon
Never had much luck with bug/tar remover stuff.
Clay bar is said to work, though its a bit of work, My brother spent a good part of a day clay bar'n his Grand Prix but said its worth it. I will do the Impreza someday...then RejeX it. RejeX will make stuff stick a lot less, it was all I used on my Neon, and only tar would stick. Tar is just nasty stuff...
Good luck!
nymtber is offline   Reply With Quote
Old 07-28-2010, 01:37 AM   #3
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....bug and tar remover can be effective but what I find is that many folks don't allow enough time for it to dwell on the contaminant. I typically saturate a spot on a towel and hold it on the affected area for a couple of minutes (checking periodically to check the progress). Some folks use IPA or even denatured alcohol. In either case, sometimes when sap is left for too long it can be a real bear to soften and remove.
Kean is offline   Reply With Quote
Old 07-28-2010, 01:54 AM   #4
xXsaabaruXx
Member#: 232125
2005 92x Aero
black
try goo gone. that stuff usually works good on stuff like that and it shouldn't be harsh to the paint job
xXsaabaruXx is offline   Reply With Quote
Old 07-28-2010, 12:58 PM   #5
Amnizu
Member#: 178854
2008 WRX, '11 BMW 1M
Red, AW
+1. Goo gone FTW, great on anything sticky stuck your car. Perfect for bumper stickers, sap, WRX badges and such.
Amnizu is offline   Reply With Quote
Old 07-28-2010, 01:07 PM   #6
starlightluvsu
Member#: 238682
07 BBLGUN STI
EJ207 V9 swapped
peanut butter. not chunky.
starlightluvsu is offline   Reply With Quote
Old 07-28-2010, 01:40 PM   #7
Oblivion
Member#: 208588
2005 WRX STi
The bug and tar remover has worked for me in the past; however, I find I have better luck if it's a hot day and the tree sap is warm and sticky, vs when it's cold and the sap is hard. Gotta let the remover sit for awhile, too...2 mins, usually.
Oblivion is offline   Reply With Quote
Old 07-28-2010, 02:31 PM   #8
jakedademon
Member#: 157764
2002 '02 SZ55 hyb
2002 v9 EJ207 VF22 wagon
Battery acid on a paper towel and rub moderately, should take it off with minimal effort.
jakedademon is offline   Reply With Quote
Old 07-28-2010, 02:34 PM   #9
blackacres
Member#: 134821
2006 STI
Depending on how long the sap has 'baked' onto the surface, I'd try my old standby first.
Yep! Good ole' WD-40!
Wet the area with WD, allow it to wet/soak into the sap, then begin to work the WD lightly into the sap with your finger tip. If the sap begins to soften, keep wetting/rubbing with WD. Every so often wipe the area and apply fresh WD and keep at it.
I've found this works well on fairly fresh/recent sap. It takes time, but it has worked for me.
The WD does not harm your paint. If it works and you get the sap off, wash the car and re-wax the area(s), or the whole car.
Good luck!
blackacres is offline   Reply With Quote
Old 07-28-2010, 02:46 PM   #10
ctrent86
Member#: 129199
Stoners Tarinator can work well or clay bar are my go to's.
ctrent86 is offline   Reply With Quote
Old 07-28-2010, 02:57 PM   #11
Hines
Member#: 116398
08 STI OBP
Tuned By Agile
clay bar, an some patience.
Hines is offline   Reply With Quote
Old 07-28-2010, 03:02 PM   #12
Luke G.
Member#: 253012
93 civic 1.8t dohc
black
bug and tar remover has worked for me in the past. Seems the longer it sits on the car the harder it is to get off.
Luke G. is offline   Reply With Quote
Old 07-28-2010, 03:13 PM   #13
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
thanks guys, what if it hard and baked in? what plan of attack do we go for..rubbing alcohol?
Old 07-28-2010, 03:16 PM   #14
desmo750
Member#: 111256
1992 Legacy Turbo
don't call me white...
Just go play in the mud and you won't even notice the tree sap I would try a clay bar and soapy water, has always worked for me with sap. Good luck!
desmo750 is offline   Reply With Quote
Old 07-28-2010, 03:48 PM   #15
golfinz
Member#: 246750
wash then clay bar the car, then if you have a porter cable start by using a light compound, if that doesnt work, pick up a more harsh compound. If your affraid to use a PC, call up a local detailer.
golfinz is offline   Reply With Quote
Old 07-28-2010, 08:32 PM   #16
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
just tried automotive goo gone. Let it sit and it tried to wipe it. Didn't do a damn thing.
Old 07-28-2010, 08:34 PM   #17
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
callin up a detailer....I just want this stuff gone
Old 07-28-2010, 10:15 PM   #18
Jasoncor
Member#: 195934
WTB 2007 black sti
clay bar
Jasoncor is offline   Reply With Quote
Old 07-28-2010, 10:26 PM   #19
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
...I've got rubbing alchy...tryin it tomorrow
clay bar will be my last resort
Old 07-28-2010, 11:23 PM   #20
ascott13
Member#: 234966
2004 Baja Turbo
black/gunmetal
rubbing and denatured alcohol work great. my parents have a habit of parking near pine trees back home (South Carolina) and get tasked with cleaning the cars up whenever i am home from college... dampen a terry or microfiber towel with the alcohol and the lightly rub the sap in question. it will start to get clear looking. at this point just keep rubbing lightly, making sure that your towel remains damp. it may take a minute or two to get through the sap, but once it is gone, wash and wax and you're done.
ascott13 is offline   Reply With Quote
Old 07-29-2010, 08:27 AM   #21
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
Thanks ascott13, def going to give it a try.
this morning I walked outside and noticed the tree sap I had been testing goo and turtle where a white chalky color. I guess the products were finally doing something. Hopefully the Aclhy will finish the job nicely
Old 07-29-2010, 06:16 PM   #22
pnutbutta
Member#: 192572
2007 Impreza
CGM
paint thinner/mineral spirits works every time. i've used thinner many times to take off splattered road paint, tree sap etc. without any illeffects. just do it in the shade on a cool car, and don't let it sit.
wash area first, apply thinner to a rag, wipe sap off, re-wash car. and apply wax where thinner was.. enjoy
pnutbutta is offline   Reply With Quote
Old 07-29-2010, 06:36 PM   #23
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
I used some isopropyl rubbing alchy....let it sit for a bit and it did nothing.
I'm wondering if the damage is done
I got frustrated and scratched it just a bit to see if it would come off ( I even knew it was a bad idea) I think I'm seeing a little bit of gray primer.
Not a big deal, I plan on geting some scratches I have on the left side touched up, its only the size of a pea.
Damn this is frustrating.
Old 07-29-2010, 09:39 PM   #24
pnutbutta
Member#: 192572
2007 Impreza
CGM
Old 07-30-2010, 07:11 AM   #25
kbobomber89
Member#: 231418
2006 WRX
acetone.
kbobomber89 is offline   Reply With Quote
