Old 07-27-2010, 11:00 PM   #1
06legacy555
Member#: 225791
2006 Legacy
Alantic Blue
Default Window Problem.
After i clean my car and dry the windows right away then i clean them with glass cleaner they still come out with water marks all over them. Can someone tell me how to remove these water marks. Thanks
06legacy555 is offline   Reply With Quote
Old 07-27-2010, 11:06 PM   #2
sti6yr
Member#: 248150
dont put the window down after you clean them
sti6yr is offline   Reply With Quote
Old 07-27-2010, 11:42 PM   #3
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
What kind of towel are you using? What glass cleaner are you using?
ThreeEleven is offline   Reply With Quote
Old 07-28-2010, 12:40 AM   #4
06legacy555
Member#: 225791
2006 Legacy
Alantic Blue
i dont and its all my windows. i use a Absorber to dry them. then i use Invisible Glass cleaner with a micro fiber cloth.
Old 07-28-2010, 12:43 AM   #5
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....are you talking about pre-existing spots/etching or spotting as a result of your cleaning methods?
Kean is offline   Reply With Quote
Old 07-28-2010, 12:55 AM   #6
06legacy555
Member#: 225791
2006 Legacy
Alantic Blue
What do you mean by etching? and they look like water marks all over the windows. and iv tried to get them off by cleaning the windows real good then cleaning them with the window cleaner and they look the same.
Old 07-28-2010, 01:04 AM   #7
Gorge
Member#: 97449
2007 WRX
Don't use an absorber first of all. They are awful for your paint.
Claybar your windows, use rain-x, and then glass cleaner. Which glass cleaner are you using? I hope it's not ammonia based. Use something like Stoner's Invisible Glass. Also are the water marks on the outside or inside? I'm curious to see if you have moistuer inside the doors and they are leaving a mark on the inside of the window as well.
Gorge is offline   Reply With Quote
Old 07-28-2010, 01:12 AM   #8
06legacy555
Member#: 225791
2006 Legacy
Alantic Blue
yea i claybared the windows today. it didnt make a diffrence really. and i use a ammonia free glass clean cause i have tinted windows. and the water spots are from the outside. i feel like there stained onto the window.
Old 07-28-2010, 01:24 AM   #9
Kean
Member#: 25187
'08 Foz Prem TGM
....while the following is an example of water etching/deposits on paint, it still gives you a good idea of what it can look like on glass:
If they are spots that don't go away with washing, cleaners, etc., then they are likely hard water deposits, etching, etc. from standing water that was left to dry on the car/windows previously.
Old 07-28-2010, 03:06 AM   #10
jxkim
Member#: 239150
2003 WRX Sedan
i think they are not new water spots but old ones.
try some vinegar. and/or claybar
jxkim is offline   Reply With Quote
Old 07-28-2010, 10:44 AM   #11
Kean
Member#: 25187
'08 Foz Prem TGM
....if distilled white vinegar doesn't work I have had excellent results with water spot removers like Chemical Guys WSR on both paint and glass. Some use 0000 steel wool (with a cleaner to lubricate the surface), Bon Ami, polish (incld. chrome polish), etc. I would take a visit over to the Autopia forums and do a little searching.
Old 07-28-2010, 12:40 PM   #12
06legacy555
Member#: 225791
2006 Legacy
Alantic Blue
thanks for all the help i will check out what you guys said and try these products.
Old 08-04-2010, 04:07 AM   #13
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
best thing you can try is either spray the window down with glass cleaner and take some steel wool to it. or you can buy some water spot remover. and the last resort is taking the buffer to it.
Garrek11 is offline   Reply With Quote
Old 08-04-2010, 10:24 AM   #14
Kean
Member#: 25187
'08 Foz Prem TGM
....cerium oxide would be the last resort IMO.
Old 08-04-2010, 03:19 PM   #15
vms150
Member#: 172917
2004 WRX
I would try a simple clay bar before anything else
vms150 is offline   Reply With Quote
Old 08-04-2010, 11:19 PM   #16
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
dam what is up with all of you guys and using the clay bar. the easiest way to tell if a clay bar will work on it or not is by how ruff the water spots are. clay bar might take some of it off however when put back out in the sun you will still be able to see the water spots through the window.
Old 08-05-2010, 12:25 AM   #17
Bdavis1
Member#: 241215
Honest to god, I have tried everything. I finally decided to buy Zaino glass polish and it worked miraculously... I'm not a product promoter at all but this stuff really does work. If you dont want to waste your time "trying" these other things, get this. It works.
Bdavis1 is offline   Reply With Quote
DEI window rollup module/window problem? NateDogg Electrical & Lighting 2 08-20-2004 09:27 AM
window problems slin02 Service & Maintenance 7 10-29-2001 03:01 PM
('93-'01) Window problem!!! SoBaLo Impreza Forum 12 05-24-2001 12:49 AM
('93-'01) Window problems DownSouth Impreza Forum 4 04-10-2001 07:27 AM
window problem Q BAMA RS General Forum Archive 0 03-16-2001 05:30 PM
