Old 07-28-2010, 02:34 PM   #1
blckout7
Member#: 189845
Default Gains
Hey guys just wondering if you can give me an estimated answer,
What would be the horsepower gain (at wheels + general) from these mods?
Intake -
Lightweight crank pulley -
Axleback -
Finally all above tuned on 93 octane -
Thank you so much and doesn't have be perfect just an estimate
blckout7 is offline   Reply With Quote
Old 07-28-2010, 03:51 PM   #2
vrusso
Member#: 207074
2001 Impreza Outback
Silver -200k and counting
Intake -
Axleback -
You biggest hp gain will be straight from the tune for the 93 octane the other 3 will maybe net you 3-5 hp to the wheels. I would say you are looking at maybe 15-20 hp to the wheels all said and done. Again just an estimation.
vrusso is online now   Reply With Quote
Old 07-28-2010, 04:21 PM   #3
Steckers
Member#: 239264
2010 Mitsu Ralliart
Octane Blue
the axelback wont do anything
and for the intake get cai, colder air = denser air = more power
lcp will free up some parasitic lose, meaning u dont gain more power per say, but more will transfer to the wheel feeling like more power, which is awesome
Steckers is offline   Reply With Quote
Old 07-28-2010, 05:02 PM   #4
chazly413
Member#: 151079
2005 2.5RS RBP
s-techs mad tyte yo
Do the hybrid intake, and headers will net you a good gain for the exhaust. Axleback is purely for sound, in this case.
chazly413 is offline   Reply With Quote
Old 07-28-2010, 05:08 PM   #5
blckout7
Member#: 189845
Alrighty thanks for the feedback I have the hybrid intake and all the others installed, just curious I've actually gained lol
Old 07-28-2010, 05:23 PM   #6
flightwatch
Member#: 231058
2012 Hyundai Sonata
terbo
There are too many variables to allow anybody to give you any sort of accurate estimate. Steckers is right about the axleback...it does nothing but make noise. For any gains to be made through the exhaust, you will have to do headers back...even then, you will need to do it correctly to see any significant gains (allowing for proper velocity and scavenging.) The intake also throws in plenty of variables. A SRI, CAI, and Hybrid will all have an effect on the powerband, but each one will also dictate how much and where said power will be made. A SRI will lose you power down low, but will give you gains up top. A CAI will give you more power throughout the powerband, but you wouldn't see the type of gains up top that you would from a SRI. The hybrid will keep the stock power levels down low, but give you SRI gains up top. A LCP will give you about 3-5 dyno-proven hp by freeing up parasitic drag. Finally, what kind of tune did you get? What elevation do you live at? What was the OAT when you got tuned?
Not being cranky, but that is why it is very hard to give any sort of estimate.
flightwatch is offline   Reply With Quote
Old 07-28-2010, 06:08 PM   #7
blckout7
Member#: 189845
Gotcha as far as the type of tune, umm I drove up to conneticut where stimikey is and he tuned it on 93 all I know =/
OAT right now = 85 degrees Fahrenheit in NY
Elevation = 59.67 ft above sea level
If that helps sorry
Old 07-28-2010, 07:17 PM   #8
flightwatch
Member#: 231058
2012 Hyundai Sonata
terbo
So it was a road tune I'm guessing. I would guess you gained around 20whp. With an 85 degree oat, you should be running great. The ecu will pull timing based on iat. I was datalogging today, and my timing was at 0. I popped the gas, and it pulled 1.5 degrees out just from the pedal tap. Now it was 112 outside today, and that's why it pulled that much timing. Just an example to show how the ecu will react to the oat and iat.
Old 07-28-2010, 07:33 PM   #9
blckout7
Member#: 189845
Thank yea I must say it's like driving a new car drives so smooth pulls hard, new there was a gain just not sure of the numbers lol
Is it safe to say
200 hp at flywheel
150 whp
Estimating of course
Old 07-28-2010, 09:12 PM   #10
flightwatch
Member#: 231058
2012 Hyundai Sonata
terbo
More like 190/140ish
anyone know if you can swap heads from ej22 to ej18 hp gains torque gains high cmprsn turbocolin Normally Aspirated Powertrain 5 12-06-2004 08:42 PM
adjusting gain control in conjunction with LOC and remote gain IgotWRXed Car Audio, Video & Security 4 08-23-2004 08:34 PM
Gains from bigger TMIC? There is a claim of 35hp gain from TMIC! WRXVII Factory 2.0L Turbo Powertrain 34 11-19-2002 05:29 PM
Jaguar's gain MaClaren's loss? M8 Motorsports 2 05-31-2001 12:00 AM
What HP gains could i get from these mods? Shrubba Normally Aspirated Powertrain 6 04-07-2001 11:00 AM
Message Board Statistics All times are GMT -4. The time now is 08:18 PM.
