Vancouver Impreza Club
Old 07-28-2010, 04:06 PM   #1
RonnyDT
Member#: 237350
2006 WRX - Gone :(
2004 FXT - Gone :(
Default Check engine light
I just went out for a short drive to pick up some food and when i started up my Check Engine light came on and my Cruise light is blinking and won't let me cancel it or activate it.
Any ideas??
Where is a good cheap place to take it to get the codes checked and cleared?
RonnyDT is offline   Reply With Quote
Old 07-28-2010, 04:23 PM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
A bunch of the local VIC members have either a Tactrix and/or ODB2 cable and can help you out.
I do have a Tactrix cable, but I'm busy tonite and tomorrow.
Check out the FAQ up top for more info on people who can help you pull a code or two.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 07-28-2010, 04:26 PM   #3
Ricewagon
Member#: 59703
2004 STi
always wrb
I got a OBDII reader. I'll pm you my number.
Ricewagon is offline   Reply With Quote
Old 07-28-2010, 07:16 PM   #4
iht
Member#: 196742
2000 Impreza 2.5rs
whatever you do,
Don't reset your ECU. This will clear the code / CEL but you won't beable to tell what it was. the code reader will beable to remove the code.
iht is offline   Reply With Quote
Old 07-28-2010, 08:41 PM   #5
RE3Rotor
Member#: 162465
04 Forester XT
12 Outback 2.5i
I had the same lights (CEL + Cruise). The code turned out to be some faults in my fuel line. It can be as simple as a loose connection in the fueling sensors under your car. Not sure if yours is the same.
RE3Rotor is offline   Reply With Quote
Old 07-29-2010, 12:11 AM   #6
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
I've got a tatrix if needed.
2010 WRX Limited is offline   Reply With Quote
Old 07-29-2010, 01:39 AM   #7
timbits
Member#: 166183
2007 2.5i SE
Newport Blue
Me too. PM me if you wanna give it a go. I don't know why, but I store mine in the trunk of my car...
timbits is offline   Reply With Quote
Old 07-29-2010, 04:51 PM   #8
RonnyDT
Member#: 237350
2006 WRX - Gone :(
2004 FXT - Gone :(
Thanks guys! i'm super busy at work but i'll be replying to PM's and probably getting in touch with you guys in the next few days
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 09:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 02:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
