Old 07-28-2010, 07:26 PM   #1
altezza2impreza
Member#: 95516
2011 WRX
Default broken a/c thing? pic inside, help please
hey guys, can you tell me what this piece is. its the broken rotary looking thing on the end of the a/c pully i believe. the left side is broken and right is too. thanks
altezza2impreza is offline   Reply With Quote
Old 07-28-2010, 08:00 PM   #2
altezza2impreza
Member#: 95516
2011 WRX
not the black piece. the little circles around it. they rattle like crazy. just curious if i can get just this piece replaced.
Old 07-28-2010, 09:25 PM   #3
flightwatch
Member#: 231058
2015 F-150
looks like the clutch assembly
flightwatch is offline   Reply With Quote
Old 07-28-2010, 09:39 PM   #4
altezza2impreza
Member#: 95516
2011 WRX
it only spins on when the ac is turned on so im guessing its hooked up to the a/c?
edit
Old 07-28-2010, 09:51 PM   #5
flightwatch
Member#: 231058
2015 F-150
Yeah...When the a/c is on, the clutch engages to turn the compressor. When it's off the clutch is not engaged and thus just leaving the pulley to spin. You can stand there and watch the clutch engage and disengage as the a/c cycles.
Old 07-30-2010, 06:06 AM   #6
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
Yea, AC compressor clutch assembly. You can replace it. Without removing the comp, but this is not a job for a novice. The part that is actually broke is the return spring. So as long as its fully returning, and you can live with the noise, you should be alright for awhile.
indytruckboy is offline   Reply With Quote
Stuff FS:Oil Gauge, TXS MBC, + some random things pics inside hobbzz MWSOC Private Classifieds 9 05-24-2007 12:14 PM
Stuff FS:Oil Gauge, TXS MBC, + some random things pics inside hobbzz Engine/Power/Exhaust 6 05-24-2007 12:10 PM
help again, in the middle of injector install. pics inside!!! help!!! VajraTLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-01-2006 07:17 PM
Custom Engagement Ring - Pics Inside - Comments Please Keenan Off-Topic 43 02-01-2005 09:12 AM
Friends Highly Modified Black Civic Stolen in Princeton, NJ *PICS INSIDE*Help! KevinWRX Tri-State Area Forum 9 05-14-2003 03:38 PM
