Old 07-29-2010, 11:29 PM   #1
subarumafia700
Member#: 150288
1998 Impreza Sedan
Dark Green
Default Clutch issue...random burning clutch smell
So i installed an F1 stage 2 clutch about 3500 miles ago with an F1 11lbs flywheel. Everything was brand new. The clutch is ment for a wrx, but its the same still as my 91 turbo tranny. I also have the 91 master and slave cylinder. I have been noticing a random clutch smell laitly, sometimes after a pull, sometimes just after cruising around and pulling into my parking spot. The clutch pedal seems to sometimes come off the floor a little slower then most times. Where should i start? master is a bit dirty fluids a little dark should i start with cleaning?
subarumafia700 is offline   Reply With Quote
Old 07-30-2010, 02:04 AM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Yea I would start with clean fluid. Dot 3/dot 4 what ever it calls for. Auto parts store cheap stuff works fine. It sounds like your having a hydraulic issue. If the pressure still has issues. I would say master and slave time. It uses a pull style clutch. So the hydraulics is pretty much the only thing to cause this delay in the pedal.
The f1 stage 2 clutch
http://gripforce.com/store/index.php...roducts_id=396
I would say it should be broken in by now 3.5k. Kevlar clutches don't really smell much from my experience. Generally it slips or it works. As well it's pretty cheap of a clutch. Known to have some issues.
I say it a hydraulic issue. The lag time for the clutch to engage is causing extra wear. So fix it soon. Make sure you bleed it correctly.
Old 08-02-2010, 05:50 PM   #3
subarumafia700
Member#: 150288
1998 Impreza Sedan
Dark Green
ok thanks ill try, idk if i can break the bleeders free without breaking them, both slave and master are from a 91 turbo leg, and being that its vermont, rust goes havock
Slipping clutch issue.. with new clutch kit, evsoul Transmission (AT/MT) & Driveline 7 09-05-2006 01:39 PM
Question for STi owners - burning clutch smell from reverse? avatarr Transmission (AT/MT) & Driveline 13 03-23-2004 09:19 AM
Burning clutch smell dragonglen Baja Forum 3 10-28-2003 11:20 PM
the smell of my burning clutch (or lack thereof) RChampion Transmission (AT/MT) & Driveline 4 09-10-2002 01:45 AM
ack! burning clutch = bad smell. Valien South East Region Forum 5 04-26-2002 11:14 PM
