Old 07-30-2010, 01:25 AM   #1
salvator_rizzo
Member#: 112713
2014 BRZ, CBR Race
Red
Default Bad Compression Numbers after Rebuild EJ251
So I was having a noise problem after I finished rebuilding the motor.
Pretty much everything was done to the motor- resurface heads, full valve and seat surface, new valve stem seals, hone cylinders, recondition rod bearing bores, polish and grind crankshaft, new main and rod bearings, new piston rings, new head gaskets, new timing belt etc etc. A lot of work.
So i had a noise coming from what sounded like the head around cylinder 2 area. I was advised to do a compression test to see if I had a problem with valves or something so I did.
Numbers came back as follows (checked each cylinder twice for consistency):
Cyl #1: 70 psi (not expected at all)
Cyl #2: 100 psi <-- what i thought was the source of noise
Cyl #3: 100 psi
Cyl #4: 130 psi
So... what could possibly be going on? I was expecting cylinder 2 to be maybe around that 90-100 mark based on noise, but 1 and 3 as well?
timing problem maybe? pictures of sprockets :
passenger
driver's (the green spot is marking the alignment mark, ignore marker thats nothing)
crank
please help, this car is driving me crazy
salvator_rizzo is offline   Reply With Quote
Old 07-30-2010, 02:59 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
did you set the valve lash correctly? Are the rockers torqued down all the way/correctly? You can squirt some oil into the cylinder that is low and do another compression test, it it's different....that points to something. I forget exactly what, search on it.
Old 07-30-2010, 11:05 PM   #3
salvator_rizzo
Member#: 112713
2014 BRZ, CBR Race
Red
yea I adjusted the valves just the other day to within spec, so that should be good. Everything was torqued in accordance with the FSM, so I'm pretty sure thats good there. i've heard of putting some oil in the cylinder to check compression, I've give that a shot
Old 07-31-2010, 04:04 AM   #4
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
If you add oil and the compression goes up in that cylinder, it means the rings are shot and didn't seat properly.
rhino6303 is offline   Reply With Quote
Old 08-06-2010, 01:43 PM   #5
nasty_beer
Member#: 60990
adding oil to a cylinder only shoots the comression tester full of oil. What you really need to do is a leak down test to find where your loosing compression.
nasty_beer is offline   Reply With Quote
Old 08-09-2010, 01:18 AM   #6
SeeMonkey
Member#: 204190
Did you break it in with non synthetic oil? I would think you would get some smoke if your rings aren't right.
SeeMonkey is offline   Reply With Quote
No Start After Rebuild, EJ251, Help? salvator_rizzo Normally Aspirated Powertrain 9 08-07-2009 03:39 AM
Compression test done, rebuild needed. toutanje Built Motor Discussion 14 06-11-2008 11:13 AM
Help with WRX Compression Numbers Translation tellravi Engine Management & Tuning 2 08-08-2003 10:55 AM
Compression Numbers? mikesoob7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-09-2001 04:03 PM
Compression numbers oldpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-28-2001 01:34 AM
