Old 07-30-2010, 11:46 PM   #1
93Bus
Member#: 253530
1993 Impreza
Aqua Frost
Default Which Cold Air Intake is the best for a 1.8L?
So i'm trying to milk as much power as i can out of the little 1.8 in my 93 impreza wagon. I know adding a CAI doesn't exactly mean that i'm gonna have instant power but my questions are ; will it add gas mileage and how much power will it add if any?
OR!
Is it just better to do an engine swap to a 2.2?
Thanks!
93Bus is offline   Reply With Quote
Old 07-31-2010, 10:11 AM   #2
cmiovino
Member#: 134005
2004 WRX Premium
Better to swap the engine to a 2.2... but if you're going to do that, why not just go with the 2.5
Anywhoooo, the CAI is probably not best. You're really not going to any power down low, but up higher in the RPM range, you'll have a little more. Considering the 1.8 isn't powerful in the first place, I'd hate for you to loose power down low.
I mean, you could always just try it, but I wouldn't spend any $300 or something on a new Injen CAI. That would be a waste of money.
Old 07-31-2010, 10:46 AM   #3
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
You could remove the stock airbox, cut the MAF and fit a cone to it. $30, if you don't like it, get a coupler to refit the MAF to the box and put the stock box back on. You will not see a increase in gas mileage with a CAI, you might see less gas mileage because with the car getting more air, it needs more fuel to compensate. With the added air, you will see a noticeable increase in throttle response and your engine will sound a lot louder. Give it a try.
Jessekrs123 is offline   Reply With Quote
Old 07-31-2010, 01:02 PM   #4
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Any modifications to a 1.8L engine will be a waste of money. Don't do any bolt-ons.
LetItSnow is offline   Reply With Quote
Which BIG MAF Intake is the best? Tecate Newbies & FAQs 9 12-14-2009 03:48 PM
which intake is the best and the worst? 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-23-2005 05:52 PM
which cold air intake is the best? chris-man Newbies & FAQs 14 07-05-2005 04:07 PM
What is the horsepower for a 1.8L? 93Scoobster Newbies & FAQs 6 07-18-2003 08:00 AM
Which cold air intakes work with what FMICs? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-15-2002 07:55 AM
