Old 07-31-2010, 12:23 AM   #1
sha-d
Member#: 253098
Default EJ20 to EJ25
So i picked up a 98 LGT a week ago, knowing the engine was out the door. When i bought it, I also got an v1 sti ej20 in the deal.
Question is, Can I swap out the ej25 block and heads for the 2.0 block and heads?
Will I be able to use the ej25 ecu and wiring as i'm only using the block and heads?
Suggestions?
Tips?
Thanks
- Shaddy
sha-d is offline   Reply With Quote
Old 07-31-2010, 12:31 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Unless you are turboing it.....
DON'T DO IT!
You will have the SUCKIEST torque and power band ever....
Nuff Said.
Old 07-31-2010, 12:46 AM   #3
sha-d
Member#: 253098
^I get ya. i do have a gt3076r here needing a new home, but you didnt answer my questions :P
Old 07-31-2010, 12:55 AM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
You may need to swap the crank gear so it matches the original (same teeth count). Most importanly is having the head gear match the same tooth count....
And so long as the crank gear and the head gear match, you have "zero" issues on start up....
Old 07-31-2010, 01:46 AM   #5
sha-d
Member#: 253098
good thinking! i'll compare the two and let you know. I'll also check the "fitting" on both cams to make sure they're compatible
Old 08-02-2010, 08:53 AM   #6
GEE-OTTO
Member#: 201277
2009 Legacy GT
you have a EJ205 so you want to swap your N/A EJ25 for that turbo EJ205? If so you will need a stand alone or find a JDM ECU to match the engine. The Ej25 ECU wont control the turbo, fueling, timing etc that the turbo engine demands or requires.
GEE-OTTO is offline   Reply With Quote
Old 08-03-2010, 05:23 PM   #7
sha-d
Member#: 253098
its actually an EJ20G
ej20 to ej25 ajg10730 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-29-2010 11:06 AM
ej20 to ej25 slvr05rexr UTEC 7 06-19-2007 09:57 AM
EJ20 to EJ25 and trans swap VegasWRX03 Built Motor Discussion 0 02-11-2007 02:07 PM
ej20 to ej25? silverstreakwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-17-2005 12:49 AM
EJ20 to EJ25 donor parts . . ? sparco Normally Aspirated with bolt-on Forced Induction Powertrain 3 01-30-2002 09:07 PM
