Old 07-31-2010, 07:35 AM   #1
Electrik
Member#: 216893
2009 Outback Sport
Obsidian Black
Default Key gets hot
I've got an ''09 OBS. After driving, I'll pull the key out of the ignition, and the metal key is hot. Not the plastic molding, as if the sun was beating on it, but the metal that's actually inside the column. It would seem to me that there's some serious electrical current running thru the igintion cylinder? Is this right? Has anyone else noticed this?
Electrik is offline   Reply With Quote
Old 07-31-2010, 08:45 AM   #2
09WRXME
Member#: 218042
2006 Forester XT
CGM
i got the same thing going on with my 09 WRX, not really sure why other than current is running thru it like your saying. It hasn't caused any issues for me, and i have 9K on the car.
09WRXME is offline   Reply With Quote
Old 07-31-2010, 04:35 PM   #3
09_'preza_OBS
Member#: 220049
2009 Impreza OBS
Obsidian black/dark grey
Yep, '09 OBS here as well, 12,500 miles in and no problems.
09_'preza_OBS is offline   Reply With Quote
Old 08-03-2010, 11:28 AM   #4
peglegsteve
Member#: 209987
2009 Slow WRX
Slower Prius
Mine gets very hot. I've got about 38k on it now.
peglegsteve is offline   Reply With Quote
Old 08-04-2010, 04:30 PM   #5
Baconsnake
Member#: 214880
2009 Outback Sport
Obsidian Black
same here. Don't think it's an issue.
Baconsnake is offline   Reply With Quote
Old 08-06-2010, 04:33 PM   #6
Help I'm Stuck!
Member#: 248293
2010 2.5i hatch
SSM
my 2010 2.5i keys are hot also, I thought it was just from the summer heat.
Help I'm Stuck! is offline   Reply With Quote
Old 08-06-2010, 10:14 PM   #7
Electrik
Member#: 216893
2009 Outback Sport
Obsidian Black
Thanks for chiming in. I remember hearing once "only gets hot when AC is on". I may have to do some testing.
Old 09-03-2010, 11:23 PM   #8
TheMachineHead
Member#: 254430
2011 Impreza OBS
Outback Sport
Same here, 2011 with less than 140 miles and I noticed it today. Even though it was parked in the sun, the car hadn't been running for at least 2-3hrs; I stepped out to move it no more than I'd say 100yds to a choice spot in the shade, and when I pulled the key out I noticed it's was burning.
TheMachineHead is offline   Reply With Quote
Old 09-09-2010, 12:01 AM   #9
cheesehead676
Member#: 257237
2007 Impreza wrx
Rubii
Yeah... Personally I think that is something that would be covered under your warranty. I had a airbag cel come on once and I took it in and they replaced the clock to fix it... I guess my point is the answer may not be very obvious. Good luck you guys!
cheesehead676 is offline   Reply With Quote
Old 09-09-2010, 12:41 AM   #10
Xclusive
Member#: 225704
2010 Impreza 2.5i
You mean the clock spring?
Also, there may be current running through it as a ground or some sort of security system? I don't know this for sure but it could lead to the metal getting warm and I have the same issue so I have a feeling it is not a defect.
Xclusive is offline   Reply With Quote
Old 09-09-2010, 09:34 AM   #11
nobletea
Member#: 169623
2008 2.5i 5d 100k+
Dark Grey Metallic
My 08 is three years old next month, and 77k miles, and my key has always been hot, that I've ever noticed it.
I wasn't concerned. Never had any problems with the car so far.
nobletea is offline   Reply With Quote
Old 09-09-2010, 12:18 PM   #12
nairbmik
Member#: 220259
09 2.5i
SSM
My key gets hot as well, I don't pay much attention to it.
nairbmik is offline   Reply With Quote
Old 09-15-2010, 11:26 AM   #13
davidbengineer
Member#: 248410
I have a 2010 2.5i and also noticed this. I wasn't sure what was causing it and I didn't think anything of it until I saw this thread. I'll have to see if it is only when the AC is on.
davidbengineer is offline   Reply With Quote
Its getting hot in herrrrre mordy_2v Off-Topic 16 04-27-2004 05:00 PM
random question, but do tec IIs get hot White 2.5rs Engine Management & Tuning 2 02-06-2004 01:46 PM
Do the ABS units under the hood get hot? Gravel-Fun Brakes, Steering & Suspension 1 09-18-2003 08:31 AM
Alternator getting hot! kaos200 Electrical & Lighting 0 09-04-2003 03:38 AM
New wheels getting hot (temperature-wise) sumomo Tire & Wheel 6 06-27-2003 02:19 AM
