Old 07-31-2010, 02:16 PM   #1
berylthemessiah
Member#: 227205
2007 Impreza 2.5i
CGM
Default Questions Regarding Changing Spark Plugs
Ok so i change my spark plugs today cause i hit 60k and didn't want to pay the dealer to do the check up so i'm doing it myself. While changing the spark plugs i notice something interesting that the front 2 cylinders(i.e closest to the front of the car) had a noticeable amount of oil just inside the spark plug hole, and there was also a noticeable amount of oil on the spark plug boot.
Is this something to be concerned about? or is this normal for a boxer engine.
And my second question is what is the recommend Torque to tighten the spark plugs, i couldn't find it in the manual.
Thanks for the help.
berylthemessiah is offline   Reply With Quote
Old 07-31-2010, 06:43 PM   #2
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
Valve Cover gasket leak, Very easy to do yourself!!
http://www.rs25.com/forums/f105/t512...t-install.html
dstan is offline   Reply With Quote
Old 08-01-2010, 10:34 AM   #3
berylthemessiah
Member#: 227205
2007 Impreza 2.5i
CGM
thanks for the response, and since my car is still under the powertrains warranty im gonna let the dealer ship fix it for now.
Old 08-01-2010, 12:04 PM   #4
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Than that would mean that BOTH valve covers are leaking?
Subyroo2.5 is offline   Reply With Quote
Old 08-01-2010, 01:05 PM   #5
berylthemessiah
Member#: 227205
2007 Impreza 2.5i
CGM
yes both of the front spark plug cover gaskets are leaking
Old 08-01-2010, 10:29 PM   #6
dstan
Member#: 120386
I always replace both sides.
Old 08-04-2010, 11:23 AM   #7
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
What's up with these gaskets? Seems every NA has them leaking
Old 08-04-2010, 12:32 PM   #8
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
it's the material that the tube seals are made from...they warp/deform after years of heating up/cooling down.
treksofar is offline   Reply With Quote
Old 08-04-2010, 10:52 PM   #9
VIsubi
Member#: 187834
06 2.5i impreza
Red
drain oil,unbolt covers,install gaskets, install valve covers and your good to go really. Just be happy its not the head gaskets lol then you'd really be hurting..like a 30 min job for both really. Get the right torque specs.
VIsubi is offline   Reply With Quote
Old 08-04-2010, 11:07 PM   #10
berylthemessiah
Member#: 227205
2007 Impreza 2.5i
CGM
thanks for all the help guys, i got it taken care of at the dealership cause i was still under powertrain warrenty, took them 2+ hours lol
Question regarding changing spark plugs mummer43 Normally Aspirated Powertrain 23 02-27-2010 02:30 AM
Changing spark plugs...need to change all 4? jester696 Service & Maintenance 6 12-22-2008 08:10 PM
Trying to change spark plugs - can't get socket on plug winston856 Service & Maintenance 5 03-18-2008 05:42 PM
Stupid question about changing spark plugs edkwon Off-Topic 6 04-23-2004 10:33 AM
changing spark plugs? racerwad Newbies & FAQs 7 10-23-2000 06:47 PM
