Old 07-31-2010, 03:41 PM   #1
pseudodigm
Member#: 202891
2004 WRX
Rally Blue
Default Coolant Leak Found - not sure what part is called
Hi all. This solves a bit of a mystery...last time I had my oil changed they told me that my radiator cap was leaking and replaced it. I'd *thought* something was off because I'd smell coolant once in a while but the temp never budged from where it always is.
So today I changed my spark plugs (first time, btw and I owe it completely to Nasioc. Thank you very very much) and after coming home from a spirited run in to test 'em out (yeehaa, nice difference) I smelled coolant. Sure enough I open up the hood and the...well I don't know what it's called, which is why I'm posting. I need to know it's name so I can figure out how expensive it is, how hard it is to replace, or if it'll fix.
In the picture (which isn't my engine, btw) I have coolant in a little pool on that highlighted thing. I don't think it's the cap because I can see teeny bubbles coming from where the lip (the short "tube" that the cap screws on to) meets the..tank thing. I'm such a noob.
Any insight on this is really really appreciated.
Thanks
Rick
pseudodigm is offline   Reply With Quote
Old 07-31-2010, 04:24 PM   #2
quazimoto
Member#: 70395
Its the turbo coolant resovior. You could probably get away with J B weld it if you clean the leaking area real good.
quazimoto is offline   Reply With Quote
Old 07-31-2010, 04:32 PM   #3
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
the gasket is probably squashed. Pull the top off, clean up the gasket and bond with high temp silicone. Or you can upgrade to the new plastic style reservoir relatively cheap in the classifieds
fastnoypi is offline   Reply With Quote
Old 07-31-2010, 04:48 PM   #4
pseudodigm
Member#: 202891
2004 WRX
Rally Blue
I'll clean up the cap but I'm pretty sure I'm seeing micro bubbles at the weld there. It's easy to get to so I'll clean it and JB weld until I can perhaps replace it. Think it's a hard job?
Thanks for the ID btw!
Old 07-31-2010, 06:19 PM   #5
spinningcain
Member#: 176490
2005 STI
Clean it real good and sand the area with some heavy grit paper before you put the jb weld on. And it will most likely hold for awhile
spinningcain is offline   Reply With Quote
Old 07-31-2010, 07:03 PM   #6
pseudodigm
Member#: 202891
2004 WRX
Rally Blue
Ok, I cleaned an sanded it the best I could and JB Welded it, so we'll see.
In the mean time I'll keep a look out for a new/used replacement. A plastic one would be great though, any one have a link or part number? I'm trying to search but I keep running in to people having problems with the paint on theirs.
Old 09-08-2010, 11:37 AM   #7
TBone7281
Member#: 148501
2004 WRX
blue
I have the exact same issue with my 04, and it's definitely not from the cap. I was hoping maybe it was a known issue that maybe had a recall from Subaru, but it doesn't look like it based on my quick search of NASIOC. Did the JB weld do the trick? I'll take a picture when I go down to the garage in a second. I'm about to change the timing belt so I'll be under the hood anyway.
TBone7281 is offline   Reply With Quote
Old 09-08-2010, 02:14 PM   #8
wrxracer519
Member#: 149890
09 Forester
Green
Put a WTB ad here on nasioc and get a new tank from an 06+ wrs or sti. Mine leaked, replaced the tank and no issues since. Should be able to get one for $30 or something.
wrxracer519 is offline   Reply With Quote
Old 09-08-2010, 04:39 PM   #9
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
My 04' constantly has a sweet smell of coolent after a long drive. I have to add a little coolent every oil change but there is never any coolent in the oil or vice-versa.
Maybe this is an issue?
skingfreak is offline   Reply With Quote
Old 09-08-2010, 05:20 PM   #10
TBone7281
Member#: 148501
2004 WRX
blue
Why do 06+ replace their tanks?
Could be, check the top of your tank. Mine leaks, then evaporates from the heat and leaves a funk...
Old 09-08-2010, 05:42 PM   #11
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
the plastic one isnt a upgrade, many change back to the metal one as it doesnt crack as often as the plastic.
scby rex is offline   Reply With Quote
Old 09-08-2010, 05:42 PM   #12
El Guapo
Member#: 234937
2004 STi
20G'd Blue
maybe a propane torch, flux and solder can fix that?
El Guapo is offline   Reply With Quote
Old 09-08-2010, 05:46 PM   #13
El Guapo
Member#: 234937
2004 STi
20G'd Blue
Shame on subaru for not doing their homework. It's 2010 and they haven't gone back to metal tanks
Old 09-09-2010, 01:33 AM   #14
Buffman
Member#: 189212
2002 WRX wagon
I had some coolant puddling on my block, and it appear to be from a small rip some goof ball put in the hose that connects to the metal hard line that goes under the intake. I double worm clamped it for now (had a spring clamp on it) to see if it returns. Probably the same person who ripped the hell out of my inlet tube!
Buffman is offline   Reply With Quote
Old 09-09-2010, 10:15 PM   #15
scby rex
Member#: 104878
02 wrxbastardchild
its called cheaper production cost bucko, 3 part system for a one part system that cost less to produce. Dont be a asshat.
Old 09-09-2010, 10:50 PM   #16
El Guapo
Member#: 234937
2004 STi
20G'd Blue
you said it right there bucko, its a one part system which has less parts to fail. To get hightemp plastic molds for the tanks is probably more expensive to make than stamping the steel parts but in the long run less warranty claims to shell out to the dealerships and parts to stock in the inventory bins.
Don't be a asshat
Old 09-09-2010, 10:55 PM   #17
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
technically its "don't be an asshat"...just being an asshat
scoobystas is offline   Reply With Quote
Old 09-10-2010, 07:10 PM   #18
scby rex
Member#: 104878
02 wrxbastardchild
Don't be a asshat
less parts to fail as theres only one and it does fail more than the cast aluminium ones that have a gasket and steel top. Atleast the older ones can be fixed.
Old 09-10-2010, 11:57 PM   #19
barnburner
Member#: 220484
2003 PSM WRX - Sold
2006 Pink STi
jb weld should only be considered a temporary solution!
I had the EXACT same problem, it corroded all around the joint where the neck meets the tank.
don't even try to fix it, just find a new one.
I picked a mint stock metal reservoir on here for $25 shipped...look around you'll find one.
when I replaced it, just as a test, i bent the neck on the old one and little and sure enough the whole thing snapped right off...there's a lot of pressure built up in that little tank and you don't want that happening during a "spirited drive"!!
good luck with it.
ps- it took me like ten minutes to replace -- only two or three bolts and some hoses
barnburner is offline   Reply With Quote
Not sure what this is? BTM88 Newbies & FAQs 8 08-18-2009 12:05 AM
vf34 problem.. But not sure what it is Llnknown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-03-2008 10:35 AM
Thump heard randomly when downshifting? not sure what it is dave_mtu Newbies & FAQs 15 07-09-2008 12:15 PM
Not sure what part I need... WRXGuyInUSA Transmission (AT/MT) & Driveline 3 06-21-2006 06:56 AM
Not sure what it is??? Detonation, sensor? Help! Silver_04_WRX_SC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-22-2005 12:31 AM
