Old 08-01-2010, 07:42 AM   #1
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Default Modifying tacho readout
As the title says, does anyone know how you can electronically make the tacho read lower than correct? ie Engine speed is 4000rpm but tacho reads 3000 rpm. I was thinking a resistor I would switch into the circuit or something like that.
Any one have any ideas?
renhoek is offline   Reply With Quote
Old 08-01-2010, 08:16 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The tach uses a pulsed waveform generated by the ECU that varies with RPM. You'd have to build a circuit to intercept and modify that signal, not easy at all and far more involved than just a resistor.
Old 08-02-2010, 06:05 AM   #3
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Oh well, at least now I know.......
Thanks very much for the response.
(1) Recommendation on gauges to match OEM look, (2) tacho guage? f1vlad Interior & Exterior Modification 14 02-09-2006 01:32 PM
what wire on 04 wrx for defi tacho jimtweet Electrical & Lighting 0 12-23-2005 08:19 AM
tacho output for v2 sti KEN WRIGHT Engine Management & Tuning 2 09-28-2003 04:01 AM
Removing Tacho, Speedo, Temp and Fuel Needles silverbetty Interior & Exterior Modification 8 12-30-2002 09:18 AM
Need helpt with Pivot TACHO Lamp WReX_rated Bay Area Impreza Club Forum -- BAIC 3 06-29-2002 07:23 PM
